DIY, Replacing Main Relay (AV6) - Honda Accord Forum : V6 Performance Accord Forums
Old April 1st, 2004, 12:07 AM   #1
Honda/Acura Enthusiast
Plumaccordcoupe's Avatar
DIY: Replacing Main Relay (AV6)
Notice: Power to the radio WILL be cut during this procedure, so be sure to remember to back up your presets and find your anti-theft card before starting. Also, I am NOT responsible for any injuries and/or damage that might occur when doing this DIY on your car.
Symptoms of a malfunctioning main relay:
1. After engine fires up normally it just dies instantly.
2. Engine wonít fire up at all, kind of like having no gas in your gas tank.
Repair:
What you will need:
1. Flathead screwdriver
2. A new main relay: Order here
Example part order list (main relay - Illustration #10): Here (1999 AV6 coupe)
Main Relay (1999 AV6 Coupe):
Instructions for replacement:
Step one - Disconnect the car battery.
Step two - Locate the main relay under the driver side foot-well.
Main relay circled in red.
Step three - Unplug the brown plug from main relay.
Step four - Force the screwdriver in between the relay near one of the sliding clips and the metal bracket. Twist the screwdriver and plastic sliding part of the relay will just break causing the relay to fall off the bracket.
Step five - Slide new relay into the top of the metal bracket, pull down until it slides and then clicks in. Plug in the brown plug on the underside of the relay and make sure the tab clicks in.
Step six - Reconnect your battery, set time on your clock and enter your radio antitheft code (if applicable).
Step seven - Start your car to test it and your done .
July Calendar:
Old April 3rd, 2004, 02:17 AM   #2
ponickka's Avatar
can u specifiy where the main relay is located at?? thanx!
ponickka is offline   Reply With Quote Quick reply to this message
Old April 3rd, 2004, 02:19 AM   #3
Senior Moderhater
abram2001's Avatar
Its looks like under the Driver Side foot-well
Old April 3rd, 2004, 03:01 AM   #4
ponickka's Avatar
a wide pix?? perhaps??
Old April 3rd, 2004, 04:23 AM   #5
J30A1 => J30A5 => K24Z3
TH23's Avatar
Nice DIY Chris It will definitely come in handy for a lot of folks out there since the main relay is a very common problem in Hondas.
BTW, I agree with ponickka. Maybe you should put one wide-angle shot of the footwell to show exactly where the main relay is located. I'm a noob and have never looked down there so I wouldn't even know where to start
Old April 3rd, 2004, 09:59 AM   #6
Thanks
It is located just to the right of the steering unit under the foot-well. But your right, it would be easier with a wider angle pic. Iíll take one and add it to the instructions.
I knew I forgot a detail . Fixed
Old April 4th, 2004, 05:24 PM   #7
ponickka's Avatar
plz post pix..thank you!
Old April 4th, 2004, 06:42 PM   #8
Ok ok, I added it . And your welcome .
Old April 5th, 2004, 03:08 AM   #9
ponickka's Avatar
sorry if this is a dumb question, driver side foot well..is that the gas pedal??? or wut not?? plz help..thanx!
Old April 5th, 2004, 03:22 AM   #10
thread killer
^ i think it's under the dash on the driver side
Old April 5th, 2004, 05:26 PM   #11
Yes it is. It says so in the instructions .
Old April 8th, 2004, 09:26 PM   #12
ponickka's Avatar
thanx for all the info
but its seems like my car is gettin worst now..
i have yet to order that main relay ...but like sometyme wen i try to crank up the car to start ...it wouldn't start..now even wid turning the parking light on, it still wouldnt work
but sometyme if i step on the gas pedal couple time prior to turnign the car on..it will actually work..but this is a time to time basics...
so do this really have something to do wid the main relay??
thanx ...any help would be great
Old April 8th, 2004, 10:03 PM   #13
Formerly VTEC-v6!
N54TT's Avatar
http://www.v6performance.net/gallery...sort=1&cat=500
Garage:
  • 2010 BMW 135i (Daily Driver)
  • 2013 Honda Accord 4dr EX-L (Wifey's)
  • 1999 Honda Accord 4dr LX (Beater)
Gone but not forgotten: 2002 Honda Accord 4dr EX-V6
Old April 10th, 2004, 02:27 AM   #14
Don't let that mislead you. I was able to get my car to start by doing odd things to it many times. I was able to put some gas into it once or twice after it wouldn't start and it would start right up without a problem.
Even if the relay isn't the problem you are having with your car it should be the first fix you do to solve the problem. For around $20 bucks and a 5 minutes install it is much easier (and cheaper ) than replacing the fuel pump or and other part related with the starting of your car .
And thanks for the pictures James. They are still about the same as mine but just show the brake pedal. I should have thought of that .
Old April 10th, 2004, 04:39 PM   #15
ponickka's Avatar
thanx for all these input...do u dink i should jsut as my friend (who owns a accord) to let me use the relay switch?? just to see if that's the probleM>?>?
will the v6 fit my i4? i have friends wid v6 and i4..and does sedan and coupe really matter??
Old April 10th, 2004, 11:54 PM   #16
Coupe V6 and Sedan V6 wouldn't matter. But after looking at the part #'s the inline 4 relay has a different part # and also costs twice as much for some reason. So I wouldn't use an inline 4 relay on your V6.
Old April 11th, 2004, 02:15 AM   #17
ponickka's Avatar
mines is a i4..so i can use a coupe i4 rite?? would the ex, lx has any differences??? and would sedan and coupe has difference??
i really wanna test it out , before buyin it.. hehe (i'm really low on cash after wut i spend lately)
Old April 11th, 2004, 02:19 AM   #18
Question one, yes
Question two, no
Question three, no
Old April 11th, 2004, 01:55 PM   #19
ponickka's Avatar
thank you
Old April 20th, 2004, 06:29 PM   #20
Senior Moderhater
abram2001's Avatar
guys, summer time is normally when these relays go hay wire. When the Main Relay for the fuel pump above goes out, you will lose fuel pressure, and your car will litterally gag and die.
This is how you would test to see if your main relay is bad on most hondas, including our accord.
1) Remove the main relay.
2) Attach the battery positive terminal to the No. 4 terminal and the battery negative terminal to the No. 8 terminal of the main relay. Then check for continuity between the No. 5 terminal and No. 7 terminal of the main relay.
- If there is continuity, go on to step 3.
- If there is no continuity, replace the relay and retest.
3)Attach the battery positive terminal to the No. 5 terminal and the battery negative terminal to the No. 2 terminal of the main relay. Then check that there is continuity between the No. 1 terminal and No. 3 terminal of the main relay.
- If there is continuity, go on to step 4.
4)Attach the battery positive terminal to the No. 3 terminal and battery negative terminal to the No. 8 terminal of the main relay. Then check that there is continuity between the No. 5 terminal and No. 7 terminal of the main relay.
- If there is continuity, the relay is OK; If the fuel pump still does not work, go to Harness Test.
The way to do it is the same, but if you look on the relay that chris is holding, the numbers are differant. All you need to do is appropriate the numbers above accordingly to the relay below.
Use this info at your own risk, I got this online, and have not checked the validity of the claims. But let me reasure you a certified mechanic said how to do this.
Old June 8th, 2004, 11:00 PM   #21
Had some questions. Did you need any special tools to get under there? Like a weird Honda screwdriver? And anything else a newbie should know before attempting this? My car hasn't started for a few days now. Seems like the car won't ignite. Battery's good, but just won't start up, just stutters. Hoping this will fix it. Really busy with school and work and stressed with the car to top it off. Thanks in advance for replying.
Silver2000 is offline   Reply With Quote Quick reply to this message
Old June 9th, 2004, 02:56 AM   #22
Nope, no special tools needed. You just need a flathead screwdriver to break the old relay out of the metal bracket that holds it in.
Old July 15th, 2004, 12:50 AM   #23
VTECRACING87
dmxarnold's Avatar
Send a message via AIM to dmxarnold
my car had problems starting replaced the main relay now everything is great no problems so far thanks plum
dmxarnold is offline   Reply With Quote Quick reply to this message
Old August 4th, 2004, 12:33 PM   #24
Drop Dead Gorgeous
Aztro's Avatar
Send a message via AIM to Aztro
My car has been doing something like this recently. It was no gas the first time, but then even with a full tank of gas it was the same thing. It wants to start but it can't, as you said, almost as if there is no gas. Also I noticed that when my engine is warm/hot and I start my car the rpm needle goes low, and sometimes it even goes crazy between 1 and 0. I wonder if its due to the main relay problem as well....
Aztro is offline   Reply With Quote Quick reply to this message
Old August 5th, 2004, 01:09 AM   #25
The warm start problem might not have much to do with the main relay problem. I have had the warm start problem happen a few times since I replaced mine but no where near as bad as before. If or when I figure out what really causes the warm start problem I will let you all know and make a DIY .
You do need to change your relay for the no start problem though .
Old August 6th, 2004, 04:17 PM   #26
Man, that thing was a pain to get out. I tried to get the old (still working) relay out without breaking it, but it was impossible. Then, putting the new one in, it wouldn't slide all the way down on the metal bracket. It's secure, but not like the old one.
krypttic is offline   Reply With Quote Quick reply to this message
Old August 7th, 2004, 02:27 AM   #27
I know, it's a PITA to get the old relay out . The first time I attempted it I couldn't get it out so I just unplugged the wire from the old one and plugged it into the new one. Yeah it was hanging down a bit but at least my car would start up without any problems . On my next attempt I said screw it and broke it off of the metal bracket . Though you shouldn't have any trouble sliding the new one into the bracket. Mine slide right on and won't come off.
Old August 7th, 2004, 02:18 PM   #28
Yeah, I'm thinking that I may have bent the bracket a bit when I was trying to get the old one off. Oh well--it's on there securely, just not perfect.
I'm sure I still have the warm start issue, but I wanted to replace this just in case. It's been five years, and even though it was working properly, it sounds like I would have had problems soon anyway--especially since I live in Arizona.
Old August 19th, 2004, 12:33 PM   #29
VTECRACING87
dmxarnold's Avatar
haha when i had my main relay problem everyone told me it was my distributor caps rotor and wires but after i spent money on magnecor race wires and denso iridium spark plugs it was still having start problems so i talked to plummy and i replaced the main relay. Boom no problems starting for 2 months. Main relay is your problem
Old August 21st, 2004, 01:46 AM   #30
Junior Member
whtaccord's Avatar
Originally Posted by MikeRocka
ight i changed the master relay today, fkn $80 for the relay good thing with this mb i was able to do it myself. lets see if it works, i guess only time can tell...
$80 is like 4 times the amount that it cost through the link Plum provided.
I've had the warm start up problem where the rpms would go up and down and the rpm would go so low a few times that my car almost died. It actually died a couple of times on me over the past half year or so. Every single day, I would encounter the warm start up problem. However, I juust changed my battery this past week to the optima red top, and guess what? no more warm start up problem. Not even one time this whole week.
Some Car
. More to be added.
whtaccord is offline   Reply With Quote Quick reply to this message
Human Verification
