J30 custom, J32A2, J35A* swap - Page 26 - Honda Accord Forum : V6 Performance Accord Forums
Go Back   Honda Accord Forum : V6 Performance Accord Forums > CAR SPECIFIC DISCUSSION > 6TH GENERATION HONDA ACCORD (1998-2002) > 6G HONDA ACCORD PERFORMANCE DISCUSSION
Like Tree7Likes
Old April 17th, 2015, 10:23 AM   #751
I'm planning to build a '02-04 Odyssey block with J37A1 internals, and I have a question about the following information;
Originally Posted by 02AV6 View Post
Option 1
With '01-02 complete MDX block or '02-04 Odyssey complete block (crank/rods/pistons) it is required to purchase 2005 Acura RL pistons (new set $50 each) This is a best option still since these pistons have clearance for large 36mm J32A2 (intake) valves thus no modification needed. Despite the fact they have higher 11.0:1 CR still even supercharger can be used here with low boost up to 7psi intercooled (assuming safe AFR). In addition, if 11:1 CR is too high for you, you can use '03 CL-S pistons with 10.5:1 CR.
Note: Odyssey pistons do not have clearance to fit large 36mm J32A2 (intake) valves. Solution - custom job to increase valve pockets.
BTW, The only advantage to get J32A2 block is due to better cylinder sleeves to withstand heat designed for higher redline vehicle, otherwise depending on the price Odyssey or MDX block are the best bet.
The J35A4 in the '02-04 Odyssey uses FRM sleeves, and I've heard it's not a good idea to run forged pistons in them. So, are the '05 RL pistons forged? What OEM 89mm pistons would be suitable to use in the FRM sleeved J35A4 block? I plan to use the J37A1 heads, I believe the intake valves are 36mm. Is there any other reason why I couldn't run the J35A4 block with J37A1 crank/rods and heads?
Thanks for your help!
jakeordie is offline   Reply With Quote Quick reply to this message
Old April 17th, 2015, 03:40 PM   #752
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
this section is pretty dead...you may or may not get some more answers.....
I'm not an expert but can shed some light
not sure here. from what I read, the older blocks with FRM would have problems...because Honda was still trying to get the formula right?
However, they still use FRM sleeves with Forged internals on their engines. Don't have a definite answer here for you.
** If you can find a J32A2 block, those sleeves are steel. Acura may still have some of those in stock. Other than that it, look in your junk yards, etc.
No sir. They are cast
J32A2 pistons from an 03 Cl-s
J35A3/A4 from a Honda pilot, oddy respectively. Don't know the years right off...
2005 Acura RL pistons --> I run these in my J35A3.
I'm pretty sure, that is going to require some modification.
I may be wrong here, but the water and oil jackets are different on those J37A1 heads and will not line up on the J35A3/A4 block. May also need to do some modification for the timing gears and other stuff?
I think that J37A1 crankshaft may be "shorter" than the J35A3/A4crankshaft. A spacer would need to be machined, if possible??
may even have different type sensors in those heads...??
** We do know for a fact that the 36mm intake valves on a J32A2 head WILL clear the pistons on a J35A3/A4. It has been proven in a real world build by Moneypit.
Old July 13th, 2015, 04:16 PM   #753
Hi. J32a2 and j32a3 are the same?
sasa is offline   Reply With Quote Quick reply to this message
Old July 13th, 2015, 04:32 PM   #754
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
No.
Different sensors, heads (including most of the valve train, if not all of it), crankshaft, Throttle Body...maybe some other stuff also.
Old July 13th, 2015, 10:36 PM   #755
The Jester
Wheel any chance those j32a2 headers bolt up to our j pipes? Or anything im forgetting that says it doesnt?
Old July 14th, 2015, 05:28 AM   #756
Originally Posted by WHEEELMAN View Post
No.
I have j30a4 and want buy only j32a2 block and heads. And use it with j37 crank to build j36 enjine.
And i want to know. j32a2 block and j32a3 are the same or not. beacause in Russia i cant find j32a3 block only j32a2
Old July 15th, 2015, 05:10 PM   #757
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
No, they will not bolt right up.
Old July 15th, 2015, 05:13 PM   #758
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
If you are using a 03 or later Accord, then I don't know if the J32A2 block will line up with the engine mounts in your 7th gen Accord.
I think you could get the J36 (Stroked J32A2) working in your 7th gen Accord, but the wiring/re-pinning may be a pain in the ass.
Old July 16th, 2015, 12:44 PM   #759
Ok) I understand. Thank you)
Old July 21st, 2015, 09:43 AM   #760
This is all intereting
mbelliveau is offline   Reply With Quote Quick reply to this message
Old July 21st, 2015, 09:55 AM   #761
15/15 posts. now I can PM
Old July 21st, 2015, 10:17 AM   #762
accord325's Avatar
Good, now stop spamming the damn site!!!
Point A to B
NA.... Till I Spray
Old October 24th, 2015, 02:14 AM   #763
I have a 4 cylinder automatic 2000 Honda Accord, I'm thinking about doing a J32A2 engine swap. I know how to do some simple stuff like bolt-ons and suspension and brakes. But I think this job I had to pay someone professional to do it. For the people who have done it, how much did it cost in hardware (engine, transmission, ECU, engine mounts, and all other necessary hardware) and labor? I'm thinking maybe $5-6k for this, is this realistic or am I underestimating the cost? Thanks.
inspirecg1 is offline   Reply With Quote Quick reply to this message
Old October 24th, 2015, 11:44 AM   #764
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
You have the wrong platform to start with. Some of the accessories are on the opposite side on your 4 cylinder model versus the V6 model. Going from a 4 cylinder to V6 is TONS of work.
You would at least need to change the following, if not more....
Front Subframe
All front suspension components
Fuse box? not sure if the electrical is the same
also, there is another small electrical box beside the big fuse box. I don't know what that is but it's on the V6 model so you may need that.
ABS module - if you want ABS, you will need to fabricate new ABS lines as well as swap the rear I4 Drum brakes to Disc
Radiator itself; the hose outlets are in different areas on each radiator & Overfill tube is routed opposite way.
Cruise control module - if you want this yes you need to relocate this component, but you could go without this one.
V6 CV Axles
Air Box/Intake : not sure if this would mount up on the I4 engine bay. There may not be any mounting holes in the spots you need. The mounting holes you need may need to be made and a holes cut into metal to route the air intake tubing.
Brake booster and reservoir seem to be in the same spot, so you may be lucky here. But, I don't know if they are the same part? but you got the V6 donor.
You may need the splash guard from the V6 car too> not sure if this is the same or if it would mount up. Again you may need to make your own mounting holes?
You will need the V6 cluster, as the water temp sender in the cluster?(not sure on this term) is different versus the I4 cluster.
Gear shift.
There is a reverse gear lockout feature in the shifter, the wiring may or may not be the same in each car. Wiring issue may pop up on this one.
You will need to have the I4 key re-coded by a Honda dealer to match the immobilizer chip in the V6 ECU.
inspirecg1 likes this.
Old October 24th, 2015, 07:52 PM   #765
Thanks for the detailed reply. Looks like I might not want to start with my car or maybe build the engine for turbo instead. I can see some of the stuff I might be able to side step, for example I could do without ABS, I could learn threshold braking. I never use cruise control on my car even on long drives, I just don't trust it, so that can be removed. Air Box/Intake, would an aftermarket short ram fit? If so, I'll probably go with that. But all the other issues seems like it'll cost a lot of money, especially the front subframe and all suspension components. So I'll really have to price this out and see if it's worth doing.
Old October 24th, 2015, 08:35 PM   #766
Lumpy's Avatar
Your best bet would be to buy mine. I,m selling right now. $7,200. I,m the original owner. Give me your email & I can send you over the info. j32a2 swap w/ CT s/c 8-9psi & ALL of the goodies & supports that go along w/ it. 312whp, 310wtq. Tuned on 93 octane. Full interior daily driver! No accidents. Its posted in the cars for sale section on this site w/ details alsobc33948@aol.com, 941-740-0255 Brad
Lumpy is offline   Reply With Quote Quick reply to this message
Old October 29th, 2015, 02:36 AM   #767
Unfortunately I'm in Nevada, I'm pretty far from you. I don't feel comfortable buying cars without actually looking at the car. Sorry.
Old October 29th, 2015, 08:39 PM   #768
Lumpy's Avatar
Yeah, don't blame you. Just thought you could sell yours for $3000, then buy mine & skip everything & all the cost in between. Although doing it yourself is half the fun. But you wouldn't have to shell out $15000 in aftermarket goodies to get here, lol
Old October 3rd, 2016, 05:04 PM   #769
Ok So i have a 2000 coupe with the j30a1 that i bought a year ago (only put on about 2500 miles). The person i bought it from had the head gaskets timing belt and water pump replaced. at about 4k rpm the timing belt idle bearing bolt was lost and you can all guess the result. Lucky enough there is no piston damage and seems i have only mildly bent the exhaust valves on cyl 1,2,3,4. The question then comes up do i go ahead and to a full motor swap or swap the heads. Im not looking to Get huge numbers by any means however i would like a little more pep.
blade1123` is offline   Reply With Quote Quick reply to this message
Old January 3rd, 2017, 09:43 AM   #770
J35A4...i know the piston change is required when changing geads, but would just putting type-s cams in the j35 heads require the piston change? And also i have searched and searched but whats the J35A4 stock throttle body sixe vs the TL-s from 2002? I believe the TL-S TB is 66mm
Sprofita1 is offline   Reply With Quote Quick reply to this message
Old January 4th, 2017, 03:25 PM   #771
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
Both throttle bodies are 64mm
Which heads are you putting on the J35A4?
Human Verification
