CHECK ENGINE LIGHT: Codes/Resetting - Page 2 - Honda Accord Forum : V6 Performance Accord Forums
Go Back   Honda Accord Forum : V6 Performance Accord Forums > CAR SPECIFIC DISCUSSION > 6TH GENERATION HONDA ACCORD (1998-2002) > 6G HONDA ACCORD TECHNICAL DISCUSSION
Old March 26th, 2007, 11:03 AM   #31
You don't HAVE to change it, but you'd probably want to if you've got an emissions test coming up. It's also gonna mess with your gas mileage too. I'm not sure if you can clean those things out but they're about $100 to replace.
swears is offline   Reply With Quote Quick reply to this message
Old March 26th, 2007, 11:06 AM   #32
honda tech75
juan gonzalez's Avatar
Send a message via AIM to juan gonzalez
Originally Posted by s_dot
I got the P0401 code.. Do I really need to change the EGR valve and How necessary is it???
u probably have to take off ur intake manifold and drill out the egr port it tends to get clogged up to. there is a bulletin on it.
juan gonzalez is offline   Reply With Quote Quick reply to this message
Old April 27th, 2007, 03:17 AM   #33
does anyone have a guide to remove the bulb? i have a p0420 popping up, but i just get annoyed by the light itself.
allday is offline   Reply With Quote Quick reply to this message
Old April 27th, 2007, 05:00 AM   #34
Sifu
Hunsvotti's Avatar
You will spend an enormous amount of effort to remove a light bulb that will tell you of that AND OTHER problems... but you won't fix the problem itself?
Save yourself time and money. Just get it fixed now. That way you don't take a gas mileage hit, the lightbulb turns off, AND you still get a warning if there is some other problem. It's the best solution.
Hunsvotti is offline   Reply With Quote Quick reply to this message
Old May 8th, 2007, 06:02 PM   #35
All Show, No Go!
untitleJk's Avatar
Send a message via AIM to untitleJk
Need Help!
My car has been fine until I got this code.
72.............P0302.............................. ...............Cylinder 2 misfire
Therefore, I went ahead and changed the spark plugs, spark plug wires, and the distributor rotor/cap. The car got a lot smoother and the CEL stopped coming on.
Then all of sudden today, I get this code.
9...............P1381,P1382....................... .........CYP Sensor
after looking it up, its something about the Cylinder Position (CYP) Sensor
"Defective circuit or unplugged/defective sensor".
I have NO IDEA what to do to fix this problem! The car was sputtering on the freeway and it scared the crap outta me. I made sure that the spark plug wires were tightly pushed in and all..
I might need to mention that I'm overdue for a tune-up, currently at 108k waiting for the tuneup parts to arrive from http://www.hondaautomotiveparts.com/.
ANY HELP WOULD BE MUCH APPRECIATED.
untitleJk is offline   Reply With Quote Quick reply to this message
Old May 11th, 2007, 08:48 PM   #36
Low Balla
lambchop4life's Avatar
Send a message via AIM to lambchop4life Send a message via MSN to lambchop4life Send a message via Yahoo to lambchop4life
hi i am pretty new here well i been reading a lot of stuff here and super honda and all the other site seeing what can do to my honda drive, better. love the 9006 to 9005 conversion see great at night. anyways i was wondering anyone els had an evap small fuel line leak near gas tank problem i think it a p1430 code, anyone can help solve this problem it would greatly apreciated, i have a 98 v6 sedan..
lambchop4life is offline   Reply With Quote Quick reply to this message
Old May 11th, 2007, 09:45 PM   #37
hella flush
lilfotoman's Avatar
anyone have the codes for the 7th gen?
Old May 15th, 2007, 01:42 AM   #38
Send a message via AIM to snoopy20
Can you point us in the right direction please? cause I get the same error...I did a search and came up very empty.
80.............P0401.............................. ...............EGR insufficient flow
snoopy20 is offline   Reply With Quote Quick reply to this message
Old May 21st, 2007, 05:22 PM   #39
98 AV6 & 78 280Z
halfcabraley's Avatar
*PLEASE help me if you know anything about this, Im taking a road trip to see my parents and need to leave in a few days*
I knew something would come up eventually in this car, its been too perfect.
VTEC wont engage, or feel like it is engaging at all, so I went and got my codes read from my CEL. The CEL had already been on because the Previous owner put in a non-Honda Catalytic converter.
* 3 Cylinders are misfiring, got the P030X codes for 3 of the them.
* Took my 1 month old spark plugs out and brushed the crap off, put in new ignition wires. Engine still misfires.
* Also got the P0108 code for Man. Absolute Pressure, I have an aftermarket SRI and has worked fine until now.
* P0420 for catalyst efficiency - low bank 1. ?? Could be because its not OEM honda, or it may be clogged.
* I Seafoamed my car about a week ago, I am now kicking myself in the ass. Maybe the foam knocked some grime loose and jammed up my Cat?
ANY help would be great, I need the car running right in the next few days. Also, Ive been driving around [its my daily car] would anyone recommend not doing that? I would love to let it sit until I could fix it but I dont have another car yet. Thanks again - Mat
halfcabraley is offline   Reply With Quote Quick reply to this message
Old May 22nd, 2007, 10:25 AM   #40
Banned
kleptodathief's Avatar
Send a message via MSN to kleptodathief
have u resetted the ecu, unplug negative on the car battery and the CEL still comes back on? u have an obd2 scanner? if not get one on ebay for cheap
gl with the car man.... ps at least ur tranny is fine???
Old July 20th, 2007, 07:29 AM   #41
DTB
DTB's Avatar
Hi everyone, my '00 V6's CEL came on today. Let me ask a question first, when you turn the key to "ON", do you read the CEL immediately or does it come on briefly along with the rest of the dash lights then starts the code flashing sequence then turns solid again?
If the above sequence is correct about the light comes on briefly then starts the code flashing, I have 1 short flash which is P0131,P0132 (Primary Heated O2 sensor circuit low/high voltage. Does this mean it isn't getting enough voltage or too much or does this mean the O2 sensor is on the fritz and needs to be replaced.
If the above sequence is wrong, then I have one long flash and one short flash which would be #11 correct? If so, there is no #11 posted.
Thanks,
Derrick (DTB)
DTB is offline   Reply With Quote Quick reply to this message
Old July 20th, 2007, 08:55 AM   #42
M90SC Boosting 13PSI
NVA-AV6's Avatar
The sensor is behind your crank timing gear, if you are planning to change the timing belt, now is the time since you have to take it off anyway to replace the sensor.
Old July 20th, 2007, 08:56 AM   #43
NVA-AV6's Avatar
I will scan them from my factory manual when I get a chance, I just moved and have not gotten my scanner set up again yet.
Old July 20th, 2007, 09:05 AM   #44
DTB
DTB's Avatar
I went to autozone and had them check the code for my CEL. It came up as a P1491 which is the EGR valve. However, I don't see the flashing of the CEL that indicates this I don't think according to the list printed here, but maybe I am and not recognizing it. Is this a dealer only install item or a DIY project that can be done. If so, what is all involved in the replacement. Is it just a purchase and replacement type deal. I've read about people drilling. I don't want to drill on my engine myself.
Thanks,
Derrick
Old July 30th, 2007, 08:49 PM   #45
V6P Groupbuy Approved
hondaboi's Avatar
Send a message via MSN to hondaboi
Hey derrick, hows everything? I hope things are well with you
back to the topic..I have had a cel code for about 5 months now. I did that jumper thingy and I got a code of 65 which is the secondary o2 sensor.
I did a defouler trick on to the secondary sensor and then I resetted the CEL. I turn the car and it poped back on again.
Now im stuck..is my catalitic converter not working?
My vehicle is a 98 accord 4cyl.
hondaboi is offline   Reply With Quote Quick reply to this message
Old August 13th, 2007, 07:33 PM   #46
hondaboi's Avatar
bump...would anyeone know? ^^^
Old August 13th, 2007, 08:53 PM   #47
NVA-AV6's Avatar
Sorry I did not see this earlier....
What have you done to the car so far?
Anything having to do with your fuel system?
How many miles are on the car?
Have you ever had your O2 sensors replaced?
Old August 15th, 2007, 01:39 AM   #48
hondaboi's Avatar
umm...currently there is a turbo kit.
It has around 129000kms on it (which is around 80000miles).
The O2 has never been replaced...I have a feeling its the sensor. I was quoted around $100cnd for the sensor which is a denso plug and play.
So, basically, I have applied the DEFOULER mod hoping it would solve it..but it didnt. I need to clear this engine light, so that I can take it to emmissions testing and be able to insure the vehicle.
Info on the car:
1998 Honda Accord Coupe EX / 5spd / 4cyl.
Thank you very much for helping me out.. I appriciate it much
Old August 15th, 2007, 05:04 AM   #49
NVA-AV6's Avatar
Yeah, with the turbo kit I would get your AFR checked out, you can "Burnout" an O2 sensor if you run way too rich, the carbon buildup will cause the senson not to read properly. I was on board with replacing the sensor, I just like to make sure that there is not some outside issue causing them to fail. Hate to see $100 in parts and the time wasted due to another problem.
Old August 15th, 2007, 10:04 AM   #50
hondaboi's Avatar
Thanks for the reply. I really thank you for helping me out.
I do think its the sensor...cuz I was running too rich at the beginning...and it probably did BURN it out...
I guess the only way to do it is to replace it...oh well!!! I have to do it
Thank you again, and I will keep you posted...gotta order the part.
Old August 15th, 2007, 10:21 AM   #51
NVA-AV6's Avatar
If you are not getting the factory one, be sure to get eaither a denso or bosch replacement, stay away form Standard Motoro Products and Borg Warner, they are $hit.
Old August 16th, 2007, 03:19 AM   #52
hondaboi's Avatar
Thank you..
I got a quote for $100 for a denso.. so I might end up going with that
Old August 16th, 2007, 05:56 AM   #53
NVA-AV6's Avatar
Thank you..
Old August 20th, 2007, 10:59 PM   #54
hondaboi's Avatar
Well after 100 dollars later....its fixed!!
no more cel!! THanks very very much NAV-AV6!!! I really appriciate the help!!
Old August 21st, 2007, 05:11 AM   #55
NVA-AV6's Avatar
That is what we are all here for, to help each other out.
Old August 21st, 2007, 10:32 AM   #56
hondaboi's Avatar
Yup...thats correct!! I really appriciate the help!!
so I guess now, I have to drive it around first before I can go to the emissions testing right?
Old August 21st, 2007, 10:47 AM   #57
NVA-AV6's Avatar
Why?? The effect should be immediate.
Old August 21st, 2007, 11:20 PM   #58
hondaboi's Avatar
Hmm...ok.
guess, what...my cel poped up again. So I did that pin thing to check the code and it flashes 5 times, and there are no quicker flashes...it just flashes 5 time..
Im going to look to see what the problem is. \
Ok...according to the first page, 5 means this:
5........ P1128,P1129...........Map sensor circuit low/high voltage
what the heck is that? haha...oh my, I better take the turbo out.
Old August 22nd, 2007, 05:08 AM   #59
NVA-AV6's Avatar
Check all of your ground connections, when you replaced your O2 sensor, you may have jiggled another connection lose.
Old August 22nd, 2007, 10:26 AM   #60
hondaboi's Avatar
The installation of the 02 sensor was a plug and play...I didnt even touch anything else.
hmmmm...
Human Verification
