CHECK ENGINE LIGHT: Codes/Resetting - Page 3 - Honda Accord Forum : V6 Performance Accord Forums
Go Back   Honda Accord Forum : V6 Performance Accord Forums > CAR SPECIFIC DISCUSSION > 6TH GENERATION HONDA ACCORD (1998-2002) > 6G HONDA ACCORD TECHNICAL DISCUSSION
Old August 23rd, 2007, 06:06 PM   #61
my CEL just came on and it flashes quick 10 times everytime i turn the ignition on. is that code 1 or 10 ?
dcv582 is offline   Reply With Quote Quick reply to this message
Old August 23rd, 2007, 09:50 PM   #62
V6P Groupbuy Approved
hondaboi's Avatar
Send a message via MSN to hondaboi
Hmm...mine only flashes when I do that jumper thingy.
hondaboi is offline   Reply With Quote Quick reply to this message
Old August 24th, 2007, 05:05 AM   #63
M90SC Boosting 13PSI
NVA-AV6's Avatar
That is a new one on me, usually you have to jump the connector in oreder to get codes from the ECU... Strange.....
Old August 24th, 2007, 07:29 PM   #64
sry for the confusion but its actually the maintenance light.
over 226,000 kms. not sure which parts need checking or replacing. can someone help me out ?
i know theres another thread but i'd rather ask here while i'm at it
Old September 15th, 2007, 11:55 PM   #65
JBT3000's Avatar
OBDII has certain codes that are standard for every auto manufacturer. The knock sensor code is one of these standard codes whether the car has one or not. There are additional codes in the OBDII spec that are manufacturer specific.
JBT3000 is offline   Reply With Quote Quick reply to this message
Old September 15th, 2007, 11:56 PM   #66
JBT3000's Avatar
dcv582 Hold down your odometer trip reset button for 5 seconds while turning your ignition to the on position. Should reset your maintenance light. That light is only there to remind you to get your scheduled maintenance.
Old October 17th, 2007, 06:52 PM   #67
i pulled fuse 13, it resets the CEL. i haven't even done anything to attempt to fix the problem of why it came up in the first place, but the light hasn't come back.
oh well, i'll just keep on driving it.
no car payments is very nice.
uncleben00 is offline   Reply With Quote Quick reply to this message
Old December 6th, 2007, 08:12 PM   #68
dunno if anyone has said it yet...but you can go to Autozone and have them pull your OBD2 codes for free. they give you a print out and all that.
inaccord123 is offline   Reply With Quote Quick reply to this message
Old March 31st, 2008, 10:12 AM   #69
I am a new member of V6P, and I am looking for some help. I have a Missfire in all six cylinders. I have taken it to two honda dealerships, and they don't seem to know what is going on. I have replaced 6 new fuel injectors twice , several fuel filters, and spark plugs, and one new fuel pump. This will fix the problem for acouple of months, but it comes back to the same thing. Help me out. The only mods I have on the car are AEM short ram, and magna flo dual exhaust. The Car is a 2000 Honda Accord V6.
90CRXSi is offline   Reply With Quote Quick reply to this message
Old July 15th, 2008, 08:58 AM   #70
Choc Boy Wonder's Avatar
Originally Posted by JFME View Post
I hope this info helps you, as much as it helped me.
Enjoy!
This worked for me. Thanks!
Choc Boy Wonder is offline   Reply With Quote Quick reply to this message
Old September 7th, 2008, 11:17 AM   #71
Originally Posted by juan gonzalez View Post
u probably have to take off ur intake manifold and drill out the egr port it tends to get clogged up to. there is a bulletin on it.
Wheres the bulletin?
s_dot is offline   Reply With Quote Quick reply to this message
Old September 7th, 2008, 08:39 PM   #72
Here's the instructions: http://www.driveaccord.net/PDF/egr_port_clogging.pdf
swears is offline   Reply With Quote Quick reply to this message
Old September 9th, 2008, 06:00 PM   #73
Originally Posted by swears View Post
thanks a mill!
Old January 17th, 2009, 01:16 PM   #74
got my car check today.. and the code is p1456 ? any idea guys?
eleven11T is offline   Reply With Quote Quick reply to this message
Old January 17th, 2009, 05:07 PM   #75
'EVAP control system leak near fuel tank'
Good luck!
Old February 25th, 2009, 10:19 AM   #76
98' honda accord here. got the code p0505 (clogged or messed up IAC). i was looking at the IAC the other day and idk what kinda screws they use. i wanna take it out to look at it and maybe clean it, but im scared about striping the screws using the wrong screw driver. any suggestions?
defining_karma is offline   Reply With Quote Quick reply to this message
Old February 27th, 2009, 08:46 AM   #77
hello all. my car just threw a po118 code has anyone else had this code given. Any help would be great thanks
00v6AccordSedan is offline   Reply With Quote Quick reply to this message
Old March 11th, 2009, 12:12 AM   #78
P0170 and P0171
Hello guys, my check engine light just came out and these are the codes that it threw out: P0170 and P0171. Car has 125K miles, had the codes reset and the same codes came out again. Can anyone help me out with these 2 codes?
2DRV6 is offline   Reply With Quote Quick reply to this message
Old August 31st, 2009, 04:02 PM   #79
Boriquavtec's Avatar
I never had a problem with premium fuel in my V6 setup, how severe was da reaction in your accord to the higher octane?
Boriquavtec is offline   Reply With Quote Quick reply to this message
Old September 11th, 2009, 01:08 PM   #80
cooler than ice cubes
unducuva's Avatar
Send a message via AIM to unducuva
help me out here to make sure this is correct. got the check engine light diagnostic done at autozone and came up with this:
P2195- O2 sensor before Cat
is this correct????? BTW i have K&N typhoon intake on it. could that be causing it?
unducuva is offline   Reply With Quote Quick reply to this message
Old December 10th, 2009, 07:47 PM   #81
Good to know
Topher88 is offline   Reply With Quote Quick reply to this message
Old January 18th, 2010, 02:21 PM   #82
MasterChiefer21's Avatar
I used the paperclip method and got 8 long flashes and 1 short and then 8 long flashes and 3 short. according to the write up i should have an 81 and 83. I called 2 different mechanics i happen to know and both of them said this code was invalid. Am i supposed to be counting the first flash? am i doing something wrong?
MasterChiefer21 is offline   Reply With Quote Quick reply to this message
Old January 21st, 2010, 08:16 PM   #83
Killa Kali's Avatar
used my scanner to see why my check engine light came on and it came back with P0117...i havent had time to accually get under the hood and check it out and its been a few weeks now and the check engine light has turned itself off without me erasing the code...how much would the sensor set me back?
Killa Kali is offline   Reply With Quote Quick reply to this message
Old September 7th, 2010, 08:11 AM   #84
Are some models different? i got a 2000 accord coupe and i can not find the DLC. The only thing under the dash were the hood release is is a blue socket with 2 plugs in it. One has 2 wires and the second 3. Is it me or am i missing someting here?
DH48 is offline   Reply With Quote Quick reply to this message
Old October 18th, 2010, 05:57 PM   #85
So I jump my DTC and got the following codes from my ABS. What do they mean?
11
12
16
18
81
The light just came on randomly when I was on the highway.
watut is offline   Reply With Quote Quick reply to this message
Old March 19th, 2011, 10:43 PM   #86
Does anybody know how to get rid of the a/t malfunction code and also the p1607 ECM/PCM Internal Circuit Failure
This happen after i swaped the engine from stock to 6 speed m/t j32?
what can this problem be and how can i fix it.
Em2sFinest is offline   Reply With Quote Quick reply to this message
Old May 23rd, 2011, 12:05 AM   #87
Billi Blanco's Avatar
Can anyone shed some light on codes P1362 & P1367? My AV6 is absolutely will not start based on these codes. How do I get to the TDC?
***Update....I am mobile once again! 23 May 11
Billi Blanco is offline   Reply With Quote Quick reply to this message
Old May 25th, 2011, 01:52 PM   #88
No idea about the the 2000 V6 accord coupe DLC ? is there a 16 DLC at all?
Old July 5th, 2011, 09:06 PM   #89
Ok
Davidxp18 is offline   Reply With Quote Quick reply to this message
Old July 5th, 2011, 09:08 PM   #90
Yes very important stuff lol
Human Verification
