CHECK ENGINE LIGHT: Codes/Resetting - Page 4 - Honda Accord Forum : V6 Performance Accord Forums
Go Back   Honda Accord Forum : V6 Performance Accord Forums > CAR SPECIFIC DISCUSSION > 6TH GENERATION HONDA ACCORD (1998-2002) > 6G HONDA ACCORD TECHNICAL DISCUSSION
Old October 18th, 2011, 12:48 AM   #91
Appreciate the codes being posted. This was very helpful recently. Just have to see what's up with my Cat converter now.
Emphasis is offline   Reply With Quote Quick reply to this message
Old January 27th, 2012, 08:34 PM   #92
thanks guys this is a big help
shrek78 is offline   Reply With Quote Quick reply to this message
Old October 26th, 2012, 07:38 PM   #93
P0420? any ideas on what it could be or where to start?
ncosgrove is offline   Reply With Quote Quick reply to this message
Old October 27th, 2012, 11:56 AM   #94
Any symptoms that are happening to go along with that code? It could be the catalytic converter.
Old November 2nd, 2012, 04:50 PM   #95
nothing just the stupid light. im gonna change the o2 sensor and see if that works.
Old November 3rd, 2012, 05:40 AM   #96
very helpful thanks
d-ramey is offline   Reply With Quote Quick reply to this message
Old November 3rd, 2012, 11:40 AM   #97
- Three way catalyst converter Bank 1
- Exhaust tube
- Intake air leaks
- Fuel injectors may be faulty
- Fuel injector leaks
- Spark plugs may be faulty
- Improper ignition timing
- Engine Control Module (ECM)
Changing just the O2 sensor might not solve the problem. I'd start with the easiest checks first.
Old November 3rd, 2012, 06:02 PM   #98
thanks
Old November 12th, 2012, 09:55 PM   #99
I had power steering question for a 2000 Accord. I have seen an o-ring fix for the 7th gen for the whining noise cause by air getting into the system. I can't seem to find a fix for the 6th gen. Any sugestions? Thanks.
bharker is offline   Reply With Quote Quick reply to this message
Old November 23rd, 2012, 11:49 PM   #100
CGcoupe808's Avatar
wow thanks for the helpful info
CGcoupe808 is offline   Reply With Quote Quick reply to this message
Old May 5th, 2013, 08:57 AM   #101
thanks
deemack79 is offline   Reply With Quote Quick reply to this message
Old October 9th, 2013, 05:05 AM   #102
Hello,
i have cleaned my AGR 2 times with grill cleaner.
Since 3 Years all it's OK.
MySynName is offline   Reply With Quote Quick reply to this message
Old March 8th, 2014, 08:25 PM   #103
slowryder88 is offline   Reply With Quote Quick reply to this message
Old November 20th, 2014, 12:58 AM   #104
Cmp sensor A no signal 1382
Uplifted-_- is offline   Reply With Quote Quick reply to this message
Old November 20th, 2014, 12:59 AM   #105
Cmp sensor A no signal 1382 98 accord 4 cylinder , I already replaced distributor and tried resetting alarm but didn't work
Old November 1st, 2015, 04:48 PM   #106
thank you guys
desiredkarma is offline   Reply With Quote Quick reply to this message
Old May 17th, 2016, 10:44 PM   #107
Thanks for sharing this.
Duncan is offline   Reply With Quote Quick reply to this message
Old July 31st, 2016, 07:20 AM   #108
have a code p1107 barometric pressure performance in my honda accord 2001 v6 i have changed map sensor transmission shift sensor new spark plugs and air filter a mechanic told me it was 2nd and 3rd gear shift pressure switches. i changed one but it was running worse than before. dont know what to do any suggestions
christinag is offline   Reply With Quote Quick reply to this message
Human Verification
