| Register | FAQ | Members List | Calendar | Mark Forums Read |
LinkBack | Thread Tools | Display Modes |
#1 |
Hi all,
Recently my comptech supercharger has been making a whistling noise (sounds like a twin screw supercharger whistle) but it only whistles when apply slight pressure to moderate pressure on the throttle. This happened like 2 days ago. Before I would only hear the supercharger whine when I am boosting. Could it be my belt making the noise? Bearings? Vacuum leak? Or something else. any input will be helpful thanks |
| Sponsored Links | |||
Advertisement | |||
#2 |
umm isnt this a wanted benefit ?
#3 |
thing is the whistling noise wasnt there before until 2 days ago... so im wondering if something is wrong.
The whistling isnt insanely loud, sounds like of like the spe helix spacer version 1. |
#4 |
The End.
Vacuum leak it sounds..
#5 |
Super IcyAccord
its broken, you must send it to me for inspection
![]() lol jk, |
#6 |
Bobby Lane Racing
check for leaks from your intake to the throttle body.
#7 |
#8 |
2.3L turbo
is it whistling or is it the bypass valve on the blower?
#9 |
whenever I apply light or moderate pressure on the throttle it makes a whistle. The whistling sounds like it is coming from the blower.
Is this normal? does your supercharger make noise when you are not boosting? |
#10 |
M90SC Boosting 13PSI
Does the sound change with engine RPM?
#11 |
2.3L turbo
Is the whistling high pitched than the SC whine? So if you barely step on the gas it whistles? Mine doesn't do that.
#12 | |
no. the whistling sound is about the same intensity and pitch nomatter how fast you go.
The whistling noise sounds perfectly normal from a supercharged car, but it wasnt there before. So I suspect something is wrong. |
#13 |
I doubt its a vacuum leak, most sound very loud especially a tidle after applying some load. have you checked it out with the hod open and you staring at it? Does it seem like it could be coming from the belts?
I think it might be some of your belts possibly one just starting to wear out try some belt dressin on one belt at a time and see what happens. P/S, alt. belt, and the supercharger belt. |
#14 | |
May be belt noise. My mechanic will look at it next weekend. My belt may be getting old. |
#15 |
6th and BEST Generation
Do you have a boost gauge? That would help identifying a leak of some sort.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#16 |
turns out nothing was wrong...
it was my alternator going bad and making the added whining/whistling noise |
#17 |
┌∩┐(◣_◢)┌∩┐
HAHAHAHA mine did that to Three time s n a month DAMN Sub systems
#18 |
2.3L turbo
good to know your SC is ok. get that alt fixed asap...mine went out on me and i freaked out. car won't go above 40mph, all the lights are whacked out.
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
