Valve adjustment on 3.0 V6 - Honda Accord Forum : V6 Performance Accord Forums
Go Back   Honda Accord Forum : V6 Performance Accord Forums > CAR SPECIFIC DISCUSSION > 6TH GENERATION HONDA ACCORD (1998-2002)
Old August 19th, 2003, 12:18 PM   #1
In Dust We Trust
HondaMatic1234's Avatar
Send a message via Yahoo to HondaMatic1234
Hello everyone,
I couldnt find the right subforum to post this technical question in, so I guess this is as good as any. Someone had posted this message at another forum:
"Is it neccessary to tune valves? How often should they be tuned? The dealership tried to get me to have it done at 45K (now at 60K) but I declined. They wanted $250! Thx, Jacobus"
He is refering to the 3.0 V6 with variable valve timing. I had no idea that this engine required valve lash adjustments. I figured it would have hydraulic self adjusting lifters....but what do I know???? Does anyone have the low-down on this??? I have 80K miles on my coupe now and have never had to do anything to it (just the occasional maintenance). any info would be helpful.
Thanks
HondaMatic1234 is offline   Reply With Quote Quick reply to this message
Old August 19th, 2003, 03:22 PM   #2
293 of 540
Synthetic599's Avatar
Send a message via AIM to Synthetic599 Send a message via Yahoo to Synthetic599
$250! I had to pay $400 to have my valves adjusted! I needed it though because of my new cams.
2001 Firehawk 6spd
Synthetic599 is offline   Reply With Quote Quick reply to this message
Old August 19th, 2003, 03:33 PM   #3
Master Technician
Ei-ccord's Avatar
Send a message via AIM to Ei-ccord
I am not sure of the service interval, or if there even IS one!
The manual I have clearly states, that they need adjusting "when they begin making excessive noise."
And to clear it up for you, there is NO HYDRAULICE SELF-ADJUSTMENT on the J30a1 engines. They are all mechanical adjustments.
CUSTOM-MANIA
909-591-5747
5595 Daniels St. Unit A
Chino, CA 91710
Your one stop shop.
Customs audio, Alarm, Tint, Performance Upgrades, Body Kits, Paint, Suspension, and anything else you can think of!
Old August 19th, 2003, 11:30 PM   #4
just do it yourself, its not hard, just takes a while and you have to manually turn the engine (not fun)
chronicSMOKE is offline   Reply With Quote Quick reply to this message
Old August 20th, 2003, 04:20 AM   #5
Master Technician
Ei-ccord's Avatar
Originally posted by chronicSMOKE on August 19th, 2003 at 09:30 PM
.....you have to manually turn the engine (not fun)
It isn't very hard if you pull the spark plugs out
CUSTOM-MANIA
909-591-5747
Chino, CA 91710
Your one stop shop.
Old August 20th, 2003, 09:52 PM   #6
HONDA_99's Avatar
without plugs you probably can turn crankshaft with your bare hands.
Human Verification
