05 accord coupe 6mt - Honda Accord Forum : V6 Performance Accord Forums
Go Back   Honda Accord Forum : V6 Performance Accord Forums > CAR SPECIFIC DISCUSSION > 7TH GENERATION HONDA ACCORD (2003-2007) > 7G HONDA ACCORD HYBRID DISCUSSION
Old August 7th, 2016, 08:24 PM   #1
05 accord coupe 6mt
Hello all. I just bought a jdm hybrid engine with out knowing it. Now I'm stuck with the engine in my car on the hoist and don't know what to do about the vcm. My original engine doesn't have vcm. Can a blocking plate be made for the side of the head where the solenoid is supposed to bolt to?
Gregj30a is offline   Reply With Quote Quick reply to this message
Old August 8th, 2016, 05:53 AM   #2
Anyone???
Old August 8th, 2016, 06:07 AM   #3
Probably won't work and the transmission won't bolt up.
Old August 8th, 2016, 06:47 AM   #4
The trans bolted up with no probs. it's in the car now actually. Everything bolted up except the solonoid on the side of the head that the new engine didn't come with. So it's in my friends shop on the hoist and can't start engine because of what it's missing or else oil will squirt out the side of the head
Old August 8th, 2016, 07:11 AM   #5
No idea, what is the engine code you are putting in? J3#a#? Could you swap the heads?
Old August 8th, 2016, 08:03 AM   #6
It's a j30a. I may be able to swap the heads. I just bought the engine though and I'm thinking that if I have the vcm block on the side of the head not plugged in with the vcm disabled will the engine run properly. I mean, my cars Ecm doesn't recognize vcm anyway so it would be just there and along for the ride right. Which I'm totally fine with. I just want my car to run. Don't care about having vcm. Would rather not have it
Old August 8th, 2016, 08:45 AM   #7
Jdm j30a. It has no 4 or 5 or any digits after. That's the thing about jdm engines. The codes aren't the same as ours
Old January 27th, 2017, 11:11 PM   #8
Did the M/T end up working on your car and if so what mods did you have to do if any. Thanks
rxdriguez is offline   Reply With Quote Quick reply to this message
Old April 2nd, 2017, 08:29 PM   #9
Sorry for the delay haven't signed in in a while..no mods were required. it all bolted up, only the vtec to i-vtec wiring conversion remains. which i'm still unable to find much info about. anyone out there ever come acrossed this prob???
Old June 12th, 2017, 05:16 PM   #10
poormansr is offline   Reply With Quote Quick reply to this message
Human Verification
