Another BBK option - Honda Accord Forum : V6 Performance Accord Forums
Like Tree20Likes
Old December 28th, 2008, 07:32 AM   #1
M90SC Boosting 13PSI
NVA-AV6's Avatar
Another BBK option
Hey guys, I just got done fabbing up some caliper mounting brackets for Kai (Kschwiggy) and thought I would share
Pair of 05+ RL 4 pot Advics caliper off ebay $200
Pair of rebuild kits from Acura $100 (so they could be powder coated, rubber doesn't like 450F)
Pair of Rotora (RD.40036.A.330.01S) 12.8" rotors (not sure what he got them for)
EBC yellow pads.
These cleared TL Type S 17" wheels with no issues, but will not clear stock 17" due to offset, you would have to add a 15mm spacer to get the stock 17" to clear.
Artema likes this.
Old December 28th, 2008, 08:44 AM   #2
Brad
bdeitemeyer's Avatar
Very nice...
Old December 28th, 2008, 09:10 AM   #3
j35 psi 6sp
capnff's Avatar
how much ya charging for the brackets paul? i want a set
Old December 28th, 2008, 09:20 AM   #4
NVA-AV6's Avatar
Not sure yet, need to figure out materials and machine time.
Old December 28th, 2008, 09:24 AM   #5
j35 psi 6sp
capnff's Avatar
i got ya.. well let me know..
Old December 28th, 2008, 01:36 PM   #6
Toyota/Honda Enthusiast
SableSal's Avatar
Yeah, I would be down in buying some caliper mounting brackets to use those or the TL-S Calipers.
Let us know,
SableSal is offline   Reply With Quote Quick reply to this message
Old December 28th, 2008, 03:01 PM   #7
cna
cna's Avatar
Great work on that
cna is offline   Reply With Quote Quick reply to this message
Old December 28th, 2008, 09:44 PM   #8
NVA-AV6's Avatar
Let us know,
I would need the TL-S calipers and rotors you plan to use, but I am sure I can fab something up.
Old December 28th, 2008, 11:59 PM   #9
Bobby Lane Racing
nighthawk04v6's Avatar
Awesome job Paul. I have a McFaddendales hardware store near by that I utilize to build all the custom bbks aswell. Gotta love the higher grade bolts and hardware. What are you using for the bracket, Steel or Alum?
Old December 29th, 2008, 06:45 AM   #10
NVA-AV6's Avatar
6061 T5 aluminum.
Old December 29th, 2008, 11:53 AM   #11
hey paul, nice work on the BBK.. i'll probably do that after i'm done everything else, unfortunately, not a priority right now.
i decided to track you down on here, i sent you a PM on G7A yesterday, just makin sure it went through.
and since i can't PM on here yet (too few posts) i figured i'd leave a post.
b_beau_09 is offline   Reply With Quote Quick reply to this message
Old December 29th, 2008, 07:54 PM   #12
V6P Official Vendor - Excelerate Performance
Excelerate's Avatar
Send a message via AIM to Excelerate
EBC yellow pads.
These cleared TL A-Spec 17" wheels with no issues, but will not clear stock 17" due to offset, you would have to add a 15mm spacer to get the stock 17" to clear.
Nice work, very innovative. Just a few additional notes for clarification since it will help others out.
1. The ROTORA discs should have the slot facing forward, towards the front of the car.
2. I am pretty certain those are TL Type S wheels. The TL base wheels and TL Type S wheels both clear the factory Brembos available on the TL M/T or TL-S (A/T and M/T both get Brembos). I believe the A-spec wheels are 18".
And if anyone needs the ROTORA rotors we carry that part # in stock. The slotted pair about $320/pair and drilled/slotted are about $350/pair.
EXCELERATE PERFORMANCE - Official V6P Vendor and Honda Performance Parts Specialist!
See our Comptech, ROTORA, Unorthodox Racing, Progress, TOKICO, Innovative Mounts, AEM, P2R, KAIXEN HID, TEIN, Random Tech, Injen, DC Sports, K Sport, Ingalls Sales in
NEW WEB STORE:
AIM: Excelerate04 Phone: 203-483-6100
Excelerate is offline   Reply With Quote Quick reply to this message
Old December 29th, 2008, 08:30 PM   #13
NVA-AV6's Avatar
I did not care at the time what direction the slots were facing, just wanted to do a fitment check. And yes they are the Type S wheels, my bad.
Capnf and Sabel you have PM.
Old December 29th, 2008, 09:27 PM   #14
chiefy's Avatar
very nice paul...
Old December 30th, 2008, 01:17 PM   #15
girl powah!!
03aV6cpe's Avatar
A+ for paul. always being innovative
Old December 30th, 2008, 01:55 PM   #16
J35 6Spd
so when can i come by?? is the 5th in the late afternoon/early evening good?
Old December 30th, 2008, 02:30 PM   #17
NVA-AV6's Avatar
The 5th should be good, just bring your race helemt so when you launch yourself thru your windshield it won't hurt so much
Old December 31st, 2008, 01:30 AM   #18
SableSal's Avatar
PM replied. Thanks!
PS. Any other brand rotors we can use with this? Just curious.
Old December 31st, 2008, 07:03 AM   #19
NVA-AV6's Avatar
Not sure what other rotors have the same specs as far as offset, but you could go larger, say 13", 13.2" by simply adding a spacer between the caliper and bracket.
Old December 31st, 2008, 10:22 AM   #20
Excelerate's Avatar
Didn't say you did care; was just letting others know so when they install them they don't follow that pattern.
NEW WEB STORE:
Old December 31st, 2008, 10:32 AM   #21
Bobby Lane Racing
it also varies between different rotor manufacturers. some have the slots going towards the front,some to the rear. Hence the reason why its always questionable. I have mine going towards the front. I base the direction on the vane and not the slot.
Old December 31st, 2008, 02:22 PM   #22
Excelerate's Avatar
That is correct. It's just ROTORA rotors were referenced and that is what ROTORA recommends. Technically on a disc with a straight vane it doesn't matter which way the slots go but ROTORA recommends they face forward. On a disc with curved vanes it does matter which way it goes so with a ROTORA BBK disc with curved vanes it's important which way the slots face b/c it will change which way the vanes go. Some of the 1 pc 13" BBK disc are straight vane so it may not even matter but I was just was trying to help out and give hte info I had for others.
NEW WEB STORE:
Old December 31st, 2008, 09:33 PM   #23
SableSal's Avatar
Look at what I found!
http://fastbrakes.com/shop/product_i...oducts_id=2062
Old December 31st, 2008, 09:36 PM   #24
Brad
Old December 31st, 2008, 09:45 PM   #25
k24/k20 Turbo coming soon
telele's Avatar
Send a message via AIM to telele
Very strange that this was just listed a day ago on the website that's a steal if they are selling it for the price, I wonder what type of rotors it comes with it.
telele is offline   Reply With Quote Quick reply to this message
Old December 31st, 2008, 10:13 PM   #26
NVA-AV6's Avatar
LOL, ask me if I am at all surprised :rolleye:
Old January 1st, 2009, 05:23 AM   #27
Bobby Lane Racing
nothing surprises me these days paul, i'll still have a good year though and i'm sure you guys will.
Excelerate at $325 for calipers and rotors. And yet the rotora rotors you're trying to sell go for 320 a pair, rotors alone. Explain to me what type of rotors come with the RL kit that makes the cost so cheap.
P.S keep your for sale stuff out of people's discussion threads as that's one of the rules on the forum. Unless someone asked you specifically, it would be way cool.
Old January 1st, 2009, 07:51 AM   #28
NVA-AV6's Avatar
Very cheap rotors that were not originally made for drill/slot, the low end rotors they sell are equivelant to the cheap Autozone or Advanced rotors that are then machined to add the slots/dimples and re-coated, they work, but are not on par with a Brembo, Rotora or Power Slot.
Old January 1st, 2009, 12:19 PM   #29
J35 6Spd
lovely.
add another 320 to the price of that kit when you warp those rotors in a week though
Old January 2nd, 2009, 02:37 PM   #30
Blue in NY
bluek24a4's Avatar
This is pretty cool. Paul, is there anything you can do for the back?
bluek24a4 is offline   Reply With Quote Quick reply to this message
Human Verification
