Hondata FlashPro (07-08 TL/TL Type S) - Page 2 - Honda Accord Forum : V6 Performance Accord Forums
Like Tree309Likes
Old December 19th, 2012, 06:51 AM   #31
M90SC Boosting 13PSI
NVA-AV6's Avatar
I am now armed with the pinouts for the 08 TL, 05 TL and 05 AV6. Will be working on the conversion pinning and if that looks good will be aquiring a 08 ecu to test in my car.
As someone else stated, the older ECUs are made by Motorola and they WILL NOT GIVE ANYTHING TO ANYONE EVER without alot of money, the newer ecu is made by Denso who Hondata has a long relationship with. So we can send as many requests to Hondata as we want, but thier hands are tied by Motorola.
Sonnick, simione, otsb708 and 7 others like this.
Old December 19th, 2012, 07:37 AM   #32
Bobby Lane Racing
nighthawk04v6's Avatar
I've been running a TL S ecu in a 7th gen chassis for more than 2 years. There's alot of repinning and a few wires to add. It's easy to do for anyone who knows wiring. Just don't leave anything to guess cause you can risk frying the board putting power where it doesn't belong. With Hondata's release, jumper harnesses from other companies will follow suit in no time for the ecu conversion.
Old December 19th, 2012, 07:43 AM   #33
SFL AV6
jiga21's Avatar
Update from doug (Flashpro)
"- Why wont this work for the 04-06 Acura TL?
The 07 Acura TL was the first TL to use the CAN programming protocol. This allows the ECU to be programmed in under 2 minutes and easily recover from programming mishaps such a drop in battery voltage or accidentally disconnecting the FlashPro during programming. The 04-06 TL ECUs take much longer to program (making them less suitable for dyno tuning) and are susceptible to damage rendering them unusable should the programming process be interrrupted"
Old December 19th, 2012, 07:46 AM   #34
SFL AV6
jiga21's Avatar
Gonna straight up ask doug about that harness
Old December 19th, 2012, 07:47 AM   #35
frumaroll
six6's Avatar
How easy is this for 8th gen guys
Sent from my SCH-I535 using Tapatalk 2
12' 6-6 coupe- Catless
05 6-6 coupe- Cai,pcds,rv6 j pipe, 3 inch custom exhaust, form n function coilovers. -SOLD
Old December 19th, 2012, 09:35 AM   #36
Sonnick's Avatar
Are there any additional sensors on the J35a8 that would make it difficult to use their ECU on the 7G? I'm also assuming the 07-08 Base TL ECU won't be compatible with the manual cars?
Instagram = j30_allmotor
Old December 19th, 2012, 02:13 PM   #37
SSM_AV6-6
NHB_AV6-6's Avatar
Then I'm Motorola's reckoning, here to end the borrowed time they've been making crappy phones on
Old December 19th, 2012, 03:45 PM   #38
Bobby Lane Racing
The TL-s ecu has an additional ECT sensor, also a fuel pump module.. The fuel pump module is not needed. You should beable to remove the parameter out of the ecu with FlashPro. The temp sensor can be added with a buddy club adapter on the lower hose or TL-s radiator
Sonnick and Atlas.46 like this.
Old December 19th, 2012, 05:15 PM   #39
Sonnick's Avatar
^ You make it sound easy...is it really that easy?
Old December 19th, 2012, 05:22 PM   #40
Correct me if Im wrong, but why wouldnt the auto ECU work? If its getting everything re-written, then I dont see why it would matter. The manual tl-s basemap should essentially allow it to work. Then tweak the basemap for our cars better. Unless the inside of the auto/manual ECU is mechanically different...?
dandaman15 is offline   Reply With Quote Quick reply to this message
Old December 19th, 2012, 05:29 PM   #41
Sleeper
NvrDwn's Avatar
There are no parameters to tune it like that I'm guessing.
Old December 19th, 2012, 06:35 PM   #42
Bobby Lane Racing
What do I make sound easy?
Old December 19th, 2012, 06:43 PM   #43
frumaroll
six6's Avatar
Confirmed with hondata that they have no plans of flashpro for the accords.
Old December 19th, 2012, 06:57 PM   #44
Then we better start working on that TL-S conversion harness. I figured they had little interest based off the responses they gave in the Acurazine thread. Many smart people in our community, it should not take very long.
DjKing07AV6 likes this.
Old December 19th, 2012, 08:00 PM   #45
SFL AV6
jiga21's Avatar
^With you on that note Dan
Old December 19th, 2012, 08:14 PM   #46
NVA-AV6's Avatar
Actually the 7.5 gen came with the second ECT in the thermo housing. Part 7 has a threaded bung for the sensor.
WATER PUMP - SENSOR (V6) 2006 HONDA ACCORD Parts 2DR EX (V6) KA6MT - Genuine OEM HONDA Parts
At guys are screwed yet again, the 07-08 AT has 4 shift control solinoids vs the 3 the 7th gen and 3rd gen TL have. To make matters worse you can't just throw the newer AT in , the engine bell housing pattern is very different so you would also need the 07-08 engine to go with it.
But MT looks pretty damn doable now that I have looked at the diagrams and researched the ther subsystems.
Keit, you are running without the FPCM?
Sonnick, Atlas.46 and invsblduck like this.
How's that hope and change working for you???
Last edited by NVA-AV6; December 19th, 2012 at 08:27 PM.. Reason: Damn dying keyboard on my craptop.
Old December 19th, 2012, 08:16 PM   #47
SK8 OR DIE
invsblduck's Avatar
Epic.
Rockin' a Smalser J36 w/6MT swap
invsblduck is offline   Reply With Quote Quick reply to this message
Old December 19th, 2012, 08:21 PM   #48
Slammed & Stunning
MatthewYu's Avatar
Down
Old December 19th, 2012, 08:26 PM   #49
SFL AV6
jiga21's Avatar
So close
invsblduck likes this.
Old December 19th, 2012, 08:43 PM   #50
Bobby Lane Racing
Yeah I'm running without it. All it does is control low mode for idle cold start. It's for emissions. Without it the pump runs on high like what the 7th gens do already
Most race cars remove it, STIs etc.
Old December 20th, 2012, 11:20 AM   #51
Ilovemyvtx's Avatar
I'm in...
Ilovemyvtx is offline   Reply With Quote Quick reply to this message
Old December 20th, 2012, 12:10 PM   #52
Any chance of making this work on the 2nd gen 6mt j32a2 cl's? At night i pray lol
anthracitetypes is offline   Reply With Quote Quick reply to this message
Old December 20th, 2012, 12:24 PM   #53
Or are we screwed since we arent DBW...?
Old December 20th, 2012, 02:08 PM   #54
Sonnick's Avatar
^ Since the CL-s isn't DBW, I can't see it working. Sorry bud. Don't quote me on it though.
Old December 20th, 2012, 02:58 PM   #55
I no Nintendo
gizmo2003's Avatar
Originally Posted by MatthewYu View Post
I could already imagine vtec..
is it missing it now?
Old December 20th, 2012, 03:25 PM   #56
Slammed & Stunning
MatthewYu's Avatar
Of course
Old December 20th, 2012, 03:53 PM   #57
:// 05 AV6 6MT
ll Diabolic ll's Avatar
< Has money to blow if this ever comes to light.
Sonnick likes this.
ll Diabolic ll is offline   Reply With Quote Quick reply to this message
Old December 20th, 2012, 03:58 PM   #58
✔ Verified Member
otsb708's Avatar
Sonnick likes this.
Old December 20th, 2012, 04:51 PM   #59
Bobby Lane Racing
It is coming to light. Will start being sold jan 2013.
Sonnick likes this.
Old December 20th, 2012, 05:48 PM   #60
SK8 OR DIE
invsblduck's Avatar
^ i think he means harness adapter for the 7 gen
Sonnick likes this.
Human Verification
