Hondata FlashPro (07-08 TL/TL Type S) - Page 20 - Honda Accord Forum : V6 Performance Accord Forums
Like Tree309Likes
Old May 13th, 2015, 11:46 AM   #571
SK8 OR DIE
invsblduck's Avatar
Originally Posted by simione View Post
Correct. It is the exact same 2 pin plug that plugs into the c555 connector
i have an electrical question.
( After reading about hondata pin problems for the CAN high/low lines, i decided to make my own wiring. so i salvaged an obd2 dlc from the yard. once i opened up the c555 junction on the right-dash harness, i realized i needed separate pins for those plugs )
Question: Since i deleted navi and a/c (track build), can i safely remove those related wires from that junction so i can use their pins for the CAN lines to the DLC? Eg., E1-G1 below:
Thanks.
Ps. OEM OBDii pins!
Rockin' a Smalser J36 w/6MT swap
invsblduck is offline   Reply With Quote Quick reply to this message
Old May 14th, 2015, 12:31 AM   #572
ChrisQ80's Avatar
Just want to say thanks on the advice to get a used OBD2 port, and use two OEM wires in place of the crappy ones supplied in the kit. I had a friend install them today and now my Hondata connects every time. I can finally go get my ECU burned to match my vin and go back to one key. lol
ChrisQ80 is offline   Reply With Quote Quick reply to this message
Old May 14th, 2015, 10:56 PM   #573
SK8 OR DIE
invsblduck's Avatar
Anyone? @Paul/Kiet/Ken/Rich/CBUS/Brock/Simi/accord325/oracle/etc Thanks!!!!
Old May 14th, 2015, 11:14 PM   #574
why don't you just cut and solder into the wire on the junction box? That would save you from needing to do those clips.
Old May 16th, 2015, 10:01 PM   #575
SK8 OR DIE
invsblduck's Avatar
Not a bad idea to splice.
I'm not a fan of splicing for some reason though..won't do it unless I have to
Thanks, Ken.
NVA-AV6 likes this.
Old May 16th, 2015, 10:03 PM   #576
SK8 OR DIE
invsblduck's Avatar
I ended up snipping B1 and B2 in the connector diagram above
because they go directly to sensors I don't use (and not to other harnesses or fuses).
B1 is the In-car Temperature sensor ground and B2 is the Sunlight sensor ground.
I got a copy of the Honda Electrical Troubleshooting Manual (ETM) on eBay
and spent most of the day learning to read it and going through related circuits.
weeeeeeee...
</offtopic>
Old September 18th, 2016, 10:00 PM   #577
So what is the easiest way to get a TL-S 6 speed ecu to be keyed to my Accord? Stock ecu no Hondata
gnxpro24 is offline   Reply With Quote Quick reply to this message
Old September 18th, 2016, 10:33 PM   #578
good luck with that. You are going to have check engine lights without the flashpro turning them off. The tls ecu also runs on a totally different system bus. It runs of the canbus line, while the accord runs on a k-line. So its like cable internet vs 56k. And you should be reading my thread. It pretty much supersedes this old one
Exactly what you need to get Flashpro to work on the 6mt Accord 03-07 *Sticky Please*
Old September 18th, 2016, 10:39 PM   #579
Or just get a wrecked tl type s 6mt and swap the whole wiring harness over..... That should work right lol??
thisaznboi88 likes this.
Old September 18th, 2016, 10:43 PM   #580
I understand that, which is why I was going to run the two extra wires from dlc to the green connector so it could be flashed to key the immobilizer.
Old September 18th, 2016, 10:58 PM   #581
you also need to repin about 30 pins and add a connector C since the accord only had 4 of the 5 connectors. again see my hondata thread
Old September 18th, 2016, 11:17 PM   #582
Did all of that. Read the thread as well.
Old December 22nd, 2016, 03:55 PM   #583
Was it ever confirmed if the EGR check in FP actually disables the valve or just the monitor for a CEL?
Human Verification
