Hondata FlashPro (07-08 TL/TL Type S) - Page 4 - Honda Accord Forum : V6 Performance Accord Forums
Like Tree309Likes
Old December 26th, 2012, 08:06 PM   #91
Bobby Lane Racing
nighthawk04v6's Avatar
Paul is right, they aren't good for lowered cars DD as it the j series frames sit very low on the ground.
I'm using a modified steel subframe that relocated the steering rack, and modified suspension mounting points for improved bump steer and suspension geometry/roll center. All my subframe bushings are also solid. And parts of the subframe have Been cut off for weight reduction as well.
Old December 27th, 2012, 08:55 AM   #92
TrakCord
Cubanob247's Avatar
<<<< Thinks about keeping accord now
Cubanob247 is offline   Reply With Quote Quick reply to this message
Old December 27th, 2012, 11:32 AM   #93
M90SC Boosting 13PSI
NVA-AV6's Avatar
^Now with this you could properly tune for E85, get the power out of it without melting down your engine.
Sonnick likes this.
Old December 27th, 2012, 12:03 PM   #94
Do you think that Ethans piggy back that he is making/made will also be capable od running e85 and bigger injectors?
E85 around me is 3.26/gal right now
04 Accord 6-6 Coupe
13s no matter what hp I have
Just an All Motor J30...
Zach @ YCU Dyno Tuning
Old December 27th, 2012, 01:19 PM   #95
Bobby Lane Racing
It takes about 40% more ethanol to make the same power you would get our of traditional gasoline. Unless your fuel system is plumbed for that duty capacity I don't recommend it. If you do however plan on running ethanol on a race car, buy from Sunoco. Not from the pump.
The advantage is cooler combustion but that had to do with the extra fuel needed. That's why you see in major racing that use ethanol they pit way more for fuel now than they use to.
Race gas does the same thing. Cost more though but burns more efficient.
Accord6Speed909 likes this.
Old December 31st, 2012, 08:48 PM   #96
Started making an excel sheet to compare pin outs. Knighthawk does your ecu use 4 or 5 plugs and if 4 which connectors? If I remember right my accord on has 4 plugs.
Old January 7th, 2013, 10:52 AM   #97
J30 LSD
flylow2cre8's Avatar
Well todays the day friends. Lets look forward to seeing good results. Cheers!
Sonnick likes this.
Old January 7th, 2013, 08:09 PM   #98
accord325's Avatar
I am not a Pro Turner or even have a good grasp on Tunning Vehicles. Could someone please tell me why this TL-S ECU + Harness + Flash Pro etc. Is better then the AEM FIC ?
Would they come out to the same price?
Old January 7th, 2013, 08:17 PM   #99
The AEM FIC is like a piggy back, and manipulates the stock ECU to output the parameters that are more desirable. It does this by changing the signals and inputting the parameters that it thinks will result in the desired output.
With Hondata, you are taking an ECU and instead of manipulating it, you are rewriting the parameters so it ALWAYS outputs the values you want your motor to run at. There are many other parameters you can control with this as well, not just AFR, and Timing Advance but tons of different tables. This gives full access to everything we need to make the most power and guarantee it will run the motor the way we need it to.
Sonnick and accord325 like this.
dandaman15 is offline   Reply With Quote Quick reply to this message
Old January 7th, 2013, 08:27 PM   #100
So.. Should I buy a TL-S ECU now?
Accord6Speed909 is offline   Reply With Quote Quick reply to this message
Old January 7th, 2013, 08:30 PM   #101
You should wait
Sonnick and Accord6Speed909 like this.
Old January 8th, 2013, 05:40 PM   #102
accord325's Avatar
Amazing response!!! exactly what I was looking for. Thanks!!!!
Point A to B
NA.... Till I Spray
Old January 8th, 2013, 06:39 PM   #103
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
In regards to the automatic transmission:
I need to use an A/T cause I am paraplegic.
What is the opinion on using an external A/T controller with the set up? ....do-able or no?
** I'm guessing if one could make it work, somehow, someway... the function within the ECU for shifting the tranny would need to be disabled (if possible) so there is no conflict between the ECU trying to shift and the A/T controller trying to do it's thing.
Old January 16th, 2013, 06:26 PM   #104
Can't remember if this was asked already...with this could we also adjust our redlines higher if we got better springs/retainers ect?
KenSchoen is offline   Reply With Quote Quick reply to this message
Old January 16th, 2013, 07:53 PM   #105
^Noone knows how well the bottom-end will handle a higher redline.
FYI, our J30A4/5s have a 1.88 rod/stroke ratio and a redline of 6800rpm and most of the B-series engines are <1.6 r/s and rev to 8000+rpm. It comes down to max piston speed and the strength of the rods and bolts.
EDIT: the rod/stroke ratio isn't the limiting factor for the redline
Old January 18th, 2013, 08:30 AM   #106
Sonnick's Avatar
Where did you get this info from? Apparently the F20C has a 1.82 rod/stroke ratio and revs to 9K (from what I read on 8G Civic)....this potentially means this motor could SCREAM!!! < (again, from 8G Civic).
EDIT: I found the rod length of 162mm on J32a.com and our bore is 86mm, which comes out to 1.88!!!
Instagram = j30_allmotor
Old January 18th, 2013, 09:14 AM   #107
I don't think our oil pumps can keep up with 8-9k rpm.
Old January 18th, 2013, 09:19 AM   #108
Sonnick's Avatar
^ That's an easy fix. S2K oil pump anyone? The K20s use it when they rev past 9K. Not sure if we could, but could potentially be an option. I think the bottom end would go before the oil pump, but (I really have no idea ).
Old January 18th, 2013, 12:58 PM   #109
I misspoke, I don't think the rod/stroke ratio is what sets the redline. Some of the B16s have a r/s ratio of 1.74 and rev to 8000+rpm.
07 AV6-6 SDN (>100K)...rock chips, dings, and rattles!
Old January 18th, 2013, 01:22 PM   #110
Sonnick's Avatar
^ It's not what sets the redline, but from my understanding, it is a way to measure the potential revving capability of a motor. For example, F1 cars have over 2:1 R/S ratio.
Rod to Stroke Ratio - Tech - Honda Tuning Magazine
Old January 18th, 2013, 02:24 PM   #111
J30 LSD
Any Updates?
Old January 24th, 2013, 05:16 AM   #112
quzyq06's Avatar
^ i was wondering the same thing lol
quzyq06 is offline   Reply With Quote Quick reply to this message
Old January 24th, 2013, 06:21 AM   #113
SFL AV6
jiga21's Avatar
^Plus 3
Old January 24th, 2013, 06:53 AM   #114
Bobby Lane Racing
F20/22 use similar oil pump as the k series. The engines are nearly identical. They both are chain driven. You would not beable to mock that up on a J series engine. You can however custom a dry sump pump with the right amount of money
Old January 24th, 2013, 09:56 AM   #115
Originally Posted by jiga21 View Post
^Plus 3
and I will raise you +1
Old January 28th, 2013, 07:26 PM   #116
SSM_AV6-6
NHB_AV6-6's Avatar
Not sure if it hss been discussed. Right now there is what looks like an entire 07-08 TL base being parted out on ebay, including the wiring harness for $125 shipped.
Old January 28th, 2013, 07:32 PM   #117
accord325's Avatar
Hondata has no plans for an Accord Flash. Complete Shame.
I emailed them and all i could do was plead our case.
Do you guys think there is a bigger market for the TL then Accord?
Old January 28th, 2013, 07:41 PM   #118
No, we just got an ecu that is harder to work with. They dont want the possibility of someone bricking their ECU and blaming them. I cant blame them because I know someone eventually would do it. We just need to look at other alternatives, like the ecu swap.
Old January 29th, 2013, 07:20 PM   #119
SK8 OR DIE
invsblduck's Avatar
Answers in the first couple pages of thread.
Apparently more of a technical/political reason and less of a business market one:
As someone else stated, the older ECUs are made by Motorola and they WILL NOT GIVE ANYTHING TO ANYONE EVER without alot of money, the newer ecu is made by Denso who Hondata has a long relationship with. So we can send as many requests to Hondata as we want, but thier hands are tied by Motorola.
Originally Posted by Brock View Post
It is highly unlikely that Hondata will change their FlashPro hardware to support the slower communication protocol. The 04' ~ 06' TL and 7th gen Accord uses ISO9141 and runs at 10.4k bits/second (think dial-up speed). The 07' and later TLs as well as all other later Honda/Acura vehicles use CAN. This runs at 500k bits/second (think broadband speed).
Using the older protocol, it could take 15 minutes to re-flash the ECU. That's like an eternity.
Rockin' a Smalser J36 w/6MT swap
invsblduck is offline   Reply With Quote Quick reply to this message
Old January 29th, 2013, 07:29 PM   #120
Just jump on the reasonably price piggyback lol need more support since that seems to be our only hope for now, besides the AEM fic
Human Verification
