cant drive over 40mph?!?!?!? - Honda Accord Forum : V6 Performance Accord Forums
Like Tree3Likes
  • 1 Post By 06accordcoupe
  • 1 Post By qnzthg89
  • 1 Post By ethanemc505
Old March 11th, 2013, 04:21 PM   #1
my check engine light came on, and the car wouldnt let me drive pass 40mph and wouldnt let me shift pass 3rpm, has this happened to anybody?
cp0805 is offline   Reply With Quote Quick reply to this message
Old March 11th, 2013, 04:25 PM   #2
Sleeper
NvrDwn's Avatar
Have you tried resetting the ecu?
PCDS, Custom 3" exhaust, 3" HFC, 4" CAI, Polished ZDX TB, P&P Intake Manifold, P&P Runners, deleted butterfly valve, UDP, deleted a/c and p/s, 160lbs lighter, and smaller tires.
1/8th mile 9.06 @ 82.31
8's here I come.
Old March 11th, 2013, 06:19 PM   #3
i dont know what or where that is, im a noob when it comes to things like these
Old March 11th, 2013, 06:47 PM   #4
Old Member
Du3ce's Avatar
disconnect your battery for a few minutes then replug it back in
2007 Accord EX-L V6
Old March 11th, 2013, 06:50 PM   #5
wHo BuT mE!!
Get that code checked out. Sounds like possibly a cam or crank sensor.
DoLLa is offline   Reply With Quote Quick reply to this message
Old March 11th, 2013, 07:39 PM   #6
Frank
06accordcoupe's Avatar
Sounds like you're on limp mode. Check the code for the CEL and fix it. :P
Accord6Speed909 likes this.
06accordcoupe is offline   Reply With Quote Quick reply to this message
Old March 11th, 2013, 08:42 PM   #7
alright will do, and also my check engine light has been coming on and off the past couple months, any idea on whats causing that
Old March 11th, 2013, 08:44 PM   #8
I <3 My J30A4
qnzthg89's Avatar
How about you go to an autozone when your CEL is on and get your code read for free and then go from there.
DoLLa likes this.
Old March 11th, 2013, 08:55 PM   #9
it might be your MAF. i turned the car off a couple times and it just reset its self if i recall. but go to auto zone and have them scan it
JetLife is offline   Reply With Quote Quick reply to this message
Old March 11th, 2013, 09:00 PM   #10
Car is in limp mode- turn it on and off till it's not limp..
Accord6Speed909 is offline   Reply With Quote Quick reply to this message
Old March 12th, 2013, 01:15 PM   #11
Alright thanks
Old March 14th, 2013, 06:45 PM   #12
Mr. Detail
Scottwax's Avatar
First guess would be a bad MAF sensor. But that's from 4 1/2 years of owning a Maxima and a knowing a bad MAF kills acceleration and power.
Old March 22nd, 2013, 05:52 AM   #13
wHo BuT mE!!
Update?
Old March 22nd, 2013, 10:29 AM   #14
I've had the same issue before and it was the accelerator app sensor. Cost about around $120 for the part and took me about 20-25 minutes to replace.. not sure if that was the problem he was having..
Old March 22nd, 2013, 11:39 AM   #15
yal
Is the "D" flashing?? If it is then its a transmission sensor
yal is offline   Reply With Quote Quick reply to this message
Old March 26th, 2013, 10:29 AM   #16
Got V10?
6thg3n's Avatar
same ish happened to mine. was driving fine on the hwy then i get an engine light and i cant go past 40mph.
the problem was the APP sensor.
shutted engine off, turned back on, she wasnt in limp mode any more but it kept happening occasionaly til i changed the APP sensor.
good luck
-Current- BMW M6 V10
**SOLD** 2003 AV6. TL-S Cams, U.R Pulley, RL TB -_- , Custom Exhaust.
6thg3n is offline   Reply With Quote Quick reply to this message
Old March 28th, 2013, 10:27 AM   #17
Limp mode
Ethanol is offline   Reply With Quote Quick reply to this message
Old March 28th, 2013, 10:29 AM   #18
Not the maf sensor, somethings tripping ecu in thinking somethings wrong, mabey trans, idk tho
Old March 28th, 2013, 11:34 AM   #19
How's your acceleration? One way to tell if it is the APP sensor is to drive at constant rpms say around 2100-2200 rpm's and you'll notice the rpm kind of flicker and be inconsistent..
Also when it goes into limp mode your CEL should come up.. run the codes and then diagnose...
Old March 28th, 2013, 01:35 PM   #20
I've been in limp mode a million times lol. Most likely APP sensor as others have said. There are two potentiometers in there for safety. If one's position doesn't correspond with the others within about 5% error it goes into limp mode and limits it to 3K rpm and about 20% throttle.
ethanemc505 is offline   Reply With Quote Quick reply to this message
Old March 28th, 2013, 07:35 PM   #21
The best part of having a 6-6.. on/off lol.. kind of like wax on.. wax off.. haha
Old March 28th, 2013, 09:26 PM   #22
check engine light hasnt come on ever since, but i'll talk to my mechanic about the APP sensor, thanks guys
Old May 9th, 2017, 06:31 PM   #23
have an 03 accord v6 and at times it drives perfect. no issues or vibration. then out of the blue it will drop from 65+ mph to around 35 mph like i slammed hard on the brake. afterward it wont go over 40 without hesitation or jerking me down to a lower speed. dont drive it for a day or two and its fine for a day or two then back to the same thing? any ideas?
neterd is offline   Reply With Quote Quick reply to this message
Old May 10th, 2017, 08:37 PM   #24
Mr. Detail
Scottwax's Avatar
Check for engine codes, then plug the code into the search function here. That will get you answers the quickest.
Old May 11th, 2017, 03:23 AM   #25
J30 LSD
flylow2cre8's Avatar
APP SENSOR. Get that replaced asap.
Old May 22nd, 2017, 07:43 AM   #26
first check with the diagnosis of warning light.
Gorg.loes is offline   Reply With Quote Quick reply to this message
Human Verification
