difference between j30a4 and j30a5 - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By Kschwiggy
Old October 17th, 2013, 08:18 AM   #1
Banned
Can someone tell me which is the difference between the j30a4 and j30a5 I know that the a5 have 4hp more than the a4 but is there another difference?
lokyboy69 is offline   Reply With Quote Quick reply to this message
Old October 17th, 2013, 09:23 AM   #2
accord325's Avatar
^ One and Done.
J30A
The J30A displaces 2,997 cc (2.997 L; 182.9 cu in) and is a SOHC VTEC design. Bore is 86 mm (3.4 in) and stroke is 86 mm (3.4 in). Output for the light weight 250 lb (110 kg) J30A1 was 200 hp (150 kW) @ 5500 rpm and 195 lbft (264 Nm) of torque @ 4800 rpm. The J30A4 pushed output to 240 hp (180 kW) and 212 lbft (287 Nm) using a three-way VTEC system, higher (10:1) compression ratio, and a novel exhaust manifold cast as one piece with the cylinder head. It weighs nearly 20 lb (9.1 kg) less and is an inch shorter than J30A1. This version was on the Ward's 10 Best Engines list for 2003 and 2004. The IMA hybrid version was on the list for 2005. In 2006 to mark the 30th anniversary of the Accord, Honda created the J30A5, which boosted output to 244 hp (SAE Net 08/04) and 211 lbft (SAE Net 08/04) of torque. According to Honda, horsepower gains were achieved with extensive improvements to the airflow of the intake and exhaust system.
J30A1
1997-1999 Honda Odyssey Prestige
1997-1999 Acura 3.0CL
1999-2003 Honda Avancier
1998-2002 Honda Accord V6
J30A4
2003-2005 Honda Accord V6
J30A5
2006-2007 Honda Accord V6
2003-2007 Honda Inspire
J30Y1
2013+ Acura RDX (China)
JNA1
2005-2007 Honda Accord Hybrid
Old October 17th, 2013, 10:57 AM   #3
J35 6Spd
^ that Wikipedia entry doesn't really say any differences besides the 4 HP difference.... Also, I don't think the intake and exhaust improvements were made to the internal engine, but to the components that bolt on to the engine.
Internally, the A5 is just about the same as the A4. The A5 has an extra water temp sensor on the coolant pipe manifold where it connects to the radiator hoses. So, the A5 has a slightly different wiring harness to work with the sensor, a different water/coolant manifold, and the extra sensor. I am not sure whether the A5 ecu also has different programming to work with the extra sensor.
Randomhero likes this.
Old October 17th, 2013, 11:49 AM   #4
Banned
Ok Thanks. I have a 2007 accord v6 sedan and I have the j30a4. When I purchase this car it was used with 30,000 miles in 2012. What I want to know is if this is the correct engine that my car will bring from factory the j30a4 or its supposed to be the j30a5?
Old October 17th, 2013, 11:53 AM   #5
Banned
Other thing is that when I purchase this car the used car dealer told me that they change the engine don't know why they dint give me a reason why they changed the engine I suppose that it was broken but the engine they installed used to was this j30a4 what can I do? Can I do a reclaim because they put the engine that was made for the 2003-2005 accord v6 or its the same thing?
Old October 17th, 2013, 01:40 PM   #6
J35 6Spd
The A4 was only installed in cars up to 2005, 2006-2007 models used the A5... so technically the model is wrong. However, it is possible that they swapped in the correct water piping and the extra sensor, so that it works with your wiring harness. Take a look at where the radiator hoses connect to the engine, and see if there are two sensors sticking out of the metal housing. If so, then they swapped the pipe.
The A4 is pretty much interchangeable with the A5 minus some minor details like the water temp sensors, and maybe some others. But, the car should run without problems if the details are accounted for during the installation.
Old October 17th, 2013, 02:14 PM   #7
Czechopino
vasekvi's Avatar
When my timing belt snapped on my 03V6 i replaced my engine for a low mile A5. This was a couple years ago. From what I remember them telling me, they had to reuse my intake manifold. FWIW, this engine feels and sounds exactly like my old one, except I lost a couple City MPG but gained a couple HWY MPG. I wish it was the other way around, smh.
My SSM Sedan Mod Thread
Old October 17th, 2013, 03:59 PM   #8
03 AV6 Coupe
hondav6's Avatar
FYI, the A4 and A5 intake manifolds have different part numbers. I am assuming that is part of the revised intake flow that is associated with part of the 4hp. In reality though, the dyno proves no difference in HP or TQ. Either way they both have the same characteristics, hp and tq curve, sound, redline. IMO it is more of a marketing ploy(excuse) for the higher HP number. The J30A4 is slightly underrated anyway. To say that it originally had 244 SAE HP is more likely.
For arguing the point, you could say that even if the J30A5 had 4 more crank HP, the extra 40lbs negates it as well as having 1 less TQ at 211 vs the J30a4 at 212. its a wash
2003 Honda Accord EX V6 Coupe
Injen CAI
Magnaflow CBE
UR Pulley
Richie's V3 J-Pipe
J35 Magnesium IM
MDX IM Spacer
P2R Thermal Gaskets
TB Coolant Bypass
Innovative 60A Mounts
Koni Yellows/Eibach Pro Kit
TL-S Rear Sway Bar
Neuspeed Strut Bar
Old October 17th, 2013, 04:36 PM   #9
Banned
Ok Thanks people.
Old October 17th, 2013, 07:22 PM   #10
accord325's Avatar
They are so close I personally thought it didn't matter. If the car is running good I wouldnt worry about it. Sorry for the vague link but I didn't know the whole back story.
Old October 17th, 2013, 08:22 PM   #11
Banned
Yes is running very good I have a friend that have a 2006 accord v6 sedan and when I installed my dc sports cai I did a run with him for a test and I was in front of his car like 2 cars and a half and still going I guess is pretty good.
Old October 17th, 2013, 10:20 PM   #12
Mr. Detail
Scottwax's Avatar
Apparently they were going to rate the A4 at 250 hp and require premium. But since the Altima took premium to make 240 hp, Honda decided to rate the engine's power based on what it put out on regular fuel, giving it a competitive advantage over the Altima and the 192 hp Camry which also required premium fuel.
And I'd believe the engines are somewhat underrated. My Accord is every bit as quick as my 255 hp 4AT '02 Maxima (in fact, had a 7th gen V6 Accord pull away from me on a freeway on ramp when I had my 4AT Maxima) despite the Maxima weighing a good 100 pounds less and having 34 lb-ft more torque. Yeah, it had one less gear but still, given a supposed 15 hp/34 lb-ft power advantage, 100 lb less weight (3224 lbs), that should more than make up for the lack of an extra gear.
Now my 6MT '02 Maxima on the other hand...
Old May 1st, 2017, 11:32 AM   #13
Question Looking for an used J30A5 in Cali
Hi there,
I'm new to this forum & I'd like to know if somebody have some input/ advise out there. I'm looking into buying a used in good shape J30A5 engine out there. In in Southern California. Does anybody know anybody? or reputable used engine sellers out there? thank you.
mauscuba is offline   Reply With Quote Quick reply to this message
Old May 17th, 2017, 04:43 PM   #14
Smile j30a5
Originally Posted by mauscuba View Post
Hi there,
I have a buddy with a j30a5 , still in his 06 accord 6 speed , he has plans of going j32 so he might be interested in selling his engine.
v6Tweezy is offline   Reply With Quote Quick reply to this message
Human Verification
