Different swap motor combination and MT Transmission *Sticky* - Page 2 - Honda Accord Forum : V6 Performance Accord Forums
Like Tree23Likes
Old February 22nd, 2016, 09:16 PM   #31
Okay updated again. I am not going to bother with the j35a7 since it looks like you need to swap in different cylinder heads or figure out a way to disable vcm
sasa likes this.
Old February 23rd, 2016, 03:45 AM   #32
gerzand,
So, to build j36 i need j35a6 block. Right, and all (sensors, transmission are the same?)
J35a6 and j32a3 are the same block.
In Russia i can find only j35a6 or j35a8 block
sasa is offline   Reply With Quote Quick reply to this message
Old February 23rd, 2016, 08:59 AM   #33
Originally Posted by sasa View Post
gerzand,
It is the same general block layout. I have not checked the intermediate (axle) shaft bolt pattern, but yes the bell housing should match up based on what thisaznboi88 was shown by his friend who used it, and what I subsequently researched and found photo evidence of (from many ebay engine auctions online currently).
I think there is a great chance that it will work... but you can check for your own proof regarding the intermediate shaft.
sasa likes this.
gerzand is offline   Reply With Quote Quick reply to this message
Old February 23rd, 2016, 09:09 AM   #34
If you use everything off of the accord it should match up. He did have to change the coolant crossover pipe and themo stat housing to the accord because it was different
sasa likes this.
Old February 23rd, 2016, 10:28 AM   #35
I can buy this https://www.avito.ru/kirovskaya_obla...35a6_675457370
Old February 23rd, 2016, 10:36 AM   #36
Wow, that block has ALOT of oil sludge buildup!
sasa likes this.
Old February 23rd, 2016, 10:46 AM   #37
Its Russian gazoline =)
And change oil every 9k miles =)
So, should find another?
Old February 23rd, 2016, 10:48 AM   #38
gerzand,
So, if i buy this block i should have any probles to build j36, right? =)
I think may be i should build only j33, but some inside of me say that you need j36 =))))
Old February 23rd, 2016, 10:53 AM   #39
Cool =)
Old February 23rd, 2016, 10:53 AM   #40
You will need to evaluate the condition of the cylinder walls to see if a hone will be sufficient. Also, please have it cleaned lol.
Old February 23rd, 2016, 10:55 AM   #41
gerzand,
you will need a j37 crankshaft/ j37 rods / and j32/j35 pistons but no issues aside from figuring out all of the bearing and piston ring clearances!
Or bore it to 90mm and make a j37!
Old February 23rd, 2016, 11:34 AM   #42
I have j37 from zdx rods and crankshaft, TB and IM, and J35a8 heads and pistons. Now i should decide. Build only j33, or buy this block and build j36.
If this block the same as j32a3, it will be great =)
Old February 23rd, 2016, 11:35 AM   #43
The first J36 engine in Russia =)
Old February 23rd, 2016, 11:56 AM   #44
OMG that engine looks horrible. Does it at least come with the main bearing caps? It needs to be hot tanked and maybe check the bore. Then hone it.
Old February 23rd, 2016, 02:30 PM   #45
No, only block =)
Old February 24th, 2016, 05:34 AM   #46
Carpe Diem
ikethegreat's Avatar
Sasa, make a build thread.
Old February 24th, 2016, 07:45 AM   #47
Can you explain what do you mean. My english is not very well
So, the j35a6 block 100% match to my trany? And i buy It and no problem with sensors place e. t. c.
And what about fly wheel and clutch. I guess stay with stock from j30a4/j32a3
Old February 24th, 2016, 07:48 AM   #48
He is saying to start your own thread rather than using a thread hoping to be a sticky.
Old February 24th, 2016, 08:04 AM   #49
New own post?
Old February 24th, 2016, 08:10 AM   #50
New own post?
make your own thread and document with picture of all the stuff you collected and how you build your engine.
sasa and ThatDesiKid like this.
Old February 24th, 2016, 08:19 AM   #51
Ok
What do you think should i buy j35a6?
This block in another town, and i cant compare both blocks, j30a4 and j35a6
And a little afraid about it if j32a3 and j35a6 are different
Old February 24th, 2016, 08:23 AM   #52
The block works. I just posted a picture of it on my friend car. The only difference is the compression ratio, but since you are using different piston it should not be a problem
&mpt=[CACHEBUSTER]">
Old February 24th, 2016, 08:36 AM   #53
Its very cool Thanks
Yes, i will use RL (Legend) pistons.
thisaznboi88, Thank you very much for Help and all Thank you too.
Now i want to find j35a6 shortblock and build my j36 engine.
Its only what i need.
I have ZDX crank and rods, j35a8 heads, ZDX TB and IM, Legend pistons
Old February 24th, 2016, 08:41 AM   #54
take a piston of the legend piston. I want to see if there is any difference between its USDM counterpart
Old February 24th, 2016, 08:44 AM   #55
https://www.drive2.ru/l/7915936/
Look this
And this
https://www.drive2.ru/l/3307245/
Old February 24th, 2016, 08:53 AM   #56
This is difference between Inspire UC1 with i-vtec engine j30a5 and accord j30a4 engine
Old March 1st, 2016, 04:50 PM   #57
J35a8 direct drop in and has LSD in J32a3 version 2 block 2007-2008, J35a8, and maybe J37a variation **unknown**
Borrowed from Paul
belt housing part number to get it to fit j35a8 block 21000-RAT-305
J32a3 version 1 2004-2005 direct drop in and has LSD for motor J30A4, J30A5, and J32a3 version 1
Can we clarify this section?
21000-RAT-305 is the bell housing required to mount any 7th gen Honda/3rd gen TL manual transmission to the J30 and J32A3 04-06 engine blocks.
21000-RDE-305 is the bell housing required to mount any 7th gen Honda/3rd gen TL manual transmission to the J32A3 07-08 engines, the 05-08 RL J35A8, and the 07-08 TLs J35A8 engines.
Can someone check my work? Or am I misunderstanding what you posted Ken?
Old March 1st, 2016, 05:07 PM   #58
Corrected information has been updated. Thanks for looking out Matt
Old March 1st, 2016, 05:33 PM   #59
M90SC Boosting 13PSI
NVA-AV6's Avatar
Just a FYI for all, NEVER buy a block without the original bearing caps. The bearing caps and block a line bored/honed at the factory as a "matched" set, using bearing caps from a different block will be "bad" as they will not be matched and can end you up with all kinds of bearing clearance issues....
CBUS-AV6MT and sasa like this.
Old March 1st, 2016, 05:39 PM   #60
Thanks for chiming in Paul. Glad to have another expert in the thread. Please point out any errors you find.
I might be hitting you up when my clutch goes bad for a transplant
Human Verification
