Different swap motor combination and MT Transmission *Sticky* - Honda Accord Forum : V6 Performance Accord Forums
Like Tree23Likes
Old February 21st, 2016, 09:12 AM   #1
So I am going to make a thread that tells you exactly what motor and transmission combination that will work for the accord 03-07 v6 if you want to swap it. I am tired of people sending me PM. Now start reading or have something read it to you, and learn.
Engine
Accord 03-05 stock motor J30A4 (direct drop in, swap intake manifold if AT)
The J30A4 pushed output to 240 hp (180 kW) and 212 lbft (287 Nm), compression ratio (10:1)
bore 86mm x stroke 86mm
Accord 06-07 Stock motor J30a5 (direct drop in, swap intake manifold if AT)
output to 244 hp (SAE Net 08/04) and 211 lbft (SAE Net 08/04) of torque, compression ratio (10:1)
JDM inspire engine 2003-2007 J30??
2997 cm3 / 183.6 cui
Horsepower net:
184 kW / 250 PS / 247 hp (JIS net)
Torque net:
296 Nm / 218 ft-lb
Compression ratio 10.5:1
Acura TL j32a3 2004-2006 (direct swap, swap intake manifold if AT)
Output is 270 hp and 232 lbft (315 Nm) @ 3500-5500 rpm
rating system changed in 2006 So 258 hp 232 lbft (315 Nm) @ 3500-5500 rpm. Same engine block just now underrated
bore 89mm x stroke 86mm
Acura TL J32a3 07-08 *I call this version 2 because of the changes in the bellhousing (not a direct fit, must swap in bell housing from Accord gen8 accord 2008-2010, must repin the injectors or use stock 270cc, and also must swap IM if AT)
SAE **new rating system* corrected hp for the 2006-2008 TL is 258 hp 232 lbft (315 Nm) @ 3500-5500 rpm
2003-2006 Acura MDX J35a5 (not a direct fit, must swap in bell housing from Accord gen8 accord 2008-2010, must repin the injectors or use stock 270cc, and also must swap IM if AT)
Displacement: 3,471 cc (3.471 L; 211.8 cu in)
Bore and stroke: 89 mm (3.5 in) x 93 mm (3.7 in)
Power: 255 hp (190 kW) @ 5800 rpm
Torque: 250 lbft (340 Nm) @ 3500 rpm
** Note no oil jets on the J35a5, Credits goes to Michael William Gonsalves for the pix
&mpt=[CACHEBUSTER]">
2005+ Honda Odyssey Van, LX, EX, 2005 Honda Pilot J35A6 (direct drop in with some modification to the coolant crossover pipe/passage {must switch over from the accord}, must repin the injectors or use stock 270cc, and also must swap IM if AT)
Power: 255 hp (190 kW) @ 5600 rpm
Torque: 250 lbft (340 Nm) @ 4500 rpm
Compression: 10.0:1
2005-2008 Acura RL, 2007-2008 Acura TL Type-S
J35a8 (not a direct fit, must swap in bell housing from Accord gen8 accord 2008-2010, must repin the injectors or use stock 270cc, also must swap IM if AT)
Power: 286 hp (213 kW) @ 6200 rpm[2]
Torque: 256 lbft (347 Nm) @ 5000 rpm[2]
J35z motors. Unknown and oil pump sensor is different from the stock location. Would not recommend using if possible
J35y motors. Unknown and oil pump sensor is different from the stock location, also now have direct injection. Would not recommend using if possible
J37A variation. Unknown if they are direct drop in for now. Might be if they have the same bellhousing as the TL-s and gen8 accord. Would not recommend using if possible
Frank motors
J30 Block + J35 crank and rods = J32 - 3.2L displacement **you get to keep stock block for inspection**
J30 Block + J37 crank and rods = J33- 3.3L displacement **you get to keep stock block for inspection**
J32/J35 Block + J35 crank and rods = J35- 3.5L displacement
J32/J35 Block + J37 crank and rods = J36 - 3.6L displacement
J32/J35 Block bored to 90mm + J37 Crank, Piston, and Rods = J37- 3.7L Displacement
MT Transmission
J30a4 and J30a5 direct drop in but does not have LSD for motor J30A4, J30A5, and J32a3 version 1.
Borrowed from Paul photbucket
J35a8 direct drop in and has LSD in J32a3 version 2 block 2007-2008, J35a8, and maybe J37a variation **unknown**
Borrowed from Paul
belt housing part number to get it to fit j35a8 block 21000-RDE-305 **Correct as of 3-1-16
J32a3 version 1 2004-2005 direct drop in and has LSD for motor J30A4, J30A5, and J32a3 version 1
OEM piston info
4-06 TL pistons for a 10:1 compression ratio
03 CL-S pistons for a 10.5:1 compression
05+ RL or 07+ TL-S pistons for 11:1 compression. They are also factory forged to save weight, not for strength. This is why people with j35 cannot run high boost for long before they crack a skirt.
More updated info on piston here
89mm K-series pistons and J32/j35 compatibility - AcuraZine Community
** If planning to go boost I recommend a CR of 9.5:1 and possibly 10:1 with forged piston. The main thing is to prevent detonation. Don't worry about timing advance, you can just crank up the PSI to make up the difference. stock piston/ rod combination will work, but I am unsure of the longevity.
Also I am not responsible if the motor and trans combination does not work. I have researched all this crap and spent a butt load of time on it. So you're welcome!!
Note all motor swap will run on the J30 ecu, but they may or may not lean out depending on the modification that you have done. It is recommended that you run the correct ecu with the motor, or just get hondata flashpro. Flashpro will give you more option vs running the stock ecu especially if you want to run larger camshaft or go boost.
My personally recommendation is get to hondata flashpro first. Everything else can be bought at a lower price since the price of engine and transmission will always lose value over time. Flashpro and the ecu harness new do not get cheaper because hondata has a monopoly **until K-tuner comes out with something**. If you see a flashpro for cheap in the FS you buy it, there are probably 500 flashpro units floating around for the accord and TL. There are thousands of engine that you can choose from and they number keep growing everyday since people do get into accidents and total their cars.
Old February 21st, 2016, 09:43 AM   #2
some very good and detailed info there.
thisaznboi88 likes this.
2006 accord v6 6mt
one of the best sleepers on the road
j32a3
accordlyfe is offline   Reply With Quote Quick reply to this message
Old February 21st, 2016, 10:03 AM   #3
Ken for mod!
Sticky plz.
Old February 21st, 2016, 11:55 AM   #4
I thought it was 04-06 TL engines and trans that work
Old February 21st, 2016, 03:39 PM   #5
I asked him about 06. Something changed with the ecu so we weren't positive what else changed.
Old February 21st, 2016, 03:40 PM   #6
fixed the info. turns out the bell housing the same as the accord. So it will work. 04-06 will work with the accord trans
Old February 21st, 2016, 04:42 PM   #7
07J30's Avatar
Here's a question. I'm gearing up for a j36 build. Reading through my shop manual for the 6-6 accord to front load all the info. Can I use the tolerances for the block/rotating assembly listed in the manual for the build or should I be looking at the mdx manual for those tolerances?
Old February 21st, 2016, 04:59 PM   #8
probably the mdx for the crank bearing and tolerance. I think they might be the same though, but cross ref it.
07J30 likes this.
Old February 22nd, 2016, 08:59 AM   #9
Very usefull information =) Thank you.
I want to add about j30a5 engine from Inspire UC1. It have CR 10:5 the pistons are different, its like RL pistons for j32.
And main its have i-vtec and vtc system. ECU are different and have not manual transmission only at with tiptronik. If you want swap from Inspire you should swap it with at and ecu =)
And rods with stiffening plate
sasa is offline   Reply With Quote Quick reply to this message
Old February 22nd, 2016, 09:17 AM   #10
Thank you. I also find it impossible to respond the all the PM's across different websites and facebook.
The J35a5 and j35a6 are NOT direct drop in. They have the (newer) bell housing change as found in:
J35a5+
J23a3 v2 ONLY
all J35z
all J35y to date
all j37a to date.
"+" should be read as "and newer in order of last digit in the engine code"
gerzand is offline   Reply With Quote Quick reply to this message
Old February 22nd, 2016, 09:20 AM   #11
J35a5+
J23a3 v2 ONLY
all J35z
all J35y to date
all j37a to date.
So, what block should i use for j36. J35a5 older?
Old February 22nd, 2016, 09:22 AM   #12
gerzand, if i use j35a8 block, can i do custom plate to conect block and transmission?
Old February 22nd, 2016, 09:27 AM   #13
Updated the info on the j35a6. Waiting for my friend to message me back on which mdx/odyssey he got his J35 from.
Old February 22nd, 2016, 09:38 AM   #14
You could, but it would require a crankshaft spacer for the flywheel and therefore is not worth the effort.
It would be better to get a the proper transmission, or swap the clutch case housing (also known as a bellhousing to some, but in the case of a Jseries it is integrated into transmission casing and holds fluid. It is compatible with all jseries 6mt internals across all models (aside from AWD models) and is swappable if it is hard for you to obtain a full transmission from the USA due to freight costs or taxes)
Old February 22nd, 2016, 09:53 AM   #15
MT transmission its very big problem =)
We have only bellhousing from at transmission.
I have all to build j33, but want j36
Old February 22nd, 2016, 10:21 AM   #16
Andy do you have any picture of the belt housing for the J30a4/5 - j32a3 version 1 vs a j35a8? I am not sure the image I posted are correct.
Old February 22nd, 2016, 10:28 AM   #17
And j35a5 pics please =)
Old February 22nd, 2016, 11:06 AM   #18
pa1nt13aller's Avatar
I didnt know the J35a5 was a direct bolt on to our manual trans...damn will for sure do that next if my j32a3 block goes out.
Old February 22nd, 2016, 11:09 AM   #19
I think that is up for debate based on gerzand's post.
I was under the impression it was but hard to argue with one of the resident experts.
Old February 22nd, 2016, 11:26 AM   #20
I am waiting on confirmation. It could have been the J35a4. You just need to swap the cylinder head.
Old February 22nd, 2016, 11:51 AM   #21
Thanks for the respect man. While I can be wrong at times, I don't think I am this time :wishes:
I saved this fact to permanent brain memory long ago.
This tells a big story for the j35a5. Check out the bolt pattern:
Buy $1300 2003 Acura MDX AT TRANSMISSION,MILES=148k,WRNTY=3M 101551-1 Sale
Old February 22nd, 2016, 11:54 AM   #22
There is more to it than that, but yes ive done it.
Old February 22nd, 2016, 11:56 AM   #23
yeah I am waiting in on friend. He has done it and also did something with the cooling pipe and stuff. Didn't want to add too much detail yet, unless I know for sure what he did.
Old February 22nd, 2016, 12:02 PM   #24
Your pictures are out of order in post #1 of this thread btw. The Gen 2 (newer bellhousing/clutch case) jseries blocks are a symmetrical pattern. From what I see, you have the picture captions reversed.
Old February 22nd, 2016, 12:04 PM   #25
just saw this question lol. See answer above.
Old February 22nd, 2016, 12:07 PM   #26
Could you please clarify which heads you are thinking of with which block? I can then give you the 100% correct answer with no wait.
Old February 22nd, 2016, 12:07 PM   #27
Fixed!
Old February 22nd, 2016, 03:30 PM   #28
soo my friend has a J35a6 on his accord... Da fk? Bolt on to the tranney, but needs to tweak a few things
Old February 22nd, 2016, 04:23 PM   #29
Now I'm so confused.
I was definitely thinking of the j35a4 which isn't on your list.
Old February 22nd, 2016, 08:48 PM   #30
well ive figured it out:
j35a4 is of course the 1g/crank trigger/oil pump/cams/multiport-head design and old bell housing.
j35a5 is indeed a 2g electronics but with the newer bell housing pattern.
j35a6 and j35a7 are both 2g electronics and go back to the old bell housing. You may ask why...and my guess is because the odyssey uses a strange looking auto transmission that was probably too costly to re-tool for a change in the bellhousing. The benefit is that the j35a7 does have piston crown oil squirters and fits 7g accord v6 factory transmissions. The bad part is that if you plan on using a j35a7 longblock, you might as well throw away the rear head because it has VCM integrated into it.
j35a8 and j35a9 both use the new bell housing.
This was all backed up by extensive photo evidence of casting numbers.
thisaznboi88 and sasa like this.
Human Verification
