TL Trans swap no reverse lights - Honda Accord Forum : V6 Performance Accord Forums
Old December 30th, 2016, 09:07 AM   #1
Alright so back last spring I swapped in an 05 acura tl LSD 6 speed tranny into my 07 6-6 accord. Went to get the car inspected yesterday and no reverse lights. Checked the bulbs, and the fuse. Both good. I'm thinking it has something to do with the back up light switch. Should I order another for a TL? or should I order one for an accord? I can't seem to find a part number for the accord to cross reference if they are the same part or not and I'm wondering if they do differ and if I need the accord switch to make it work.
They're both a $20 part so I guess I could order both and return the one that doesn't work. I'm worried neither will work though and I might have to wire it manually with some sort of toggle switch for reverse.
Let me know your thoughts. Any help would be great thanks.
7.5GenV66MT is offline   Reply With Quote Quick reply to this message
Old December 30th, 2016, 09:29 AM   #2
07J30's Avatar
they are the same part number, i cross referenced them on oemacuraparts.com you can get either and prob solve your problem.
#15 in the pic
http://www.oemacuraparts.com/auto-pa...n-case-v6-scat
AGENT J: full bolt ons...flashpro tuned by Dom.
Old December 30th, 2016, 09:40 AM   #3
Sweet! I'll pick one up on lunch then. Thanks man!
Human Verification
