my bolt on - Page 2 - Honda Accord Forum : V6 Performance Accord Forums
Like Tree2Likes
Old February 3rd, 2017, 05:21 AM   #31
The Jester
Originally Posted by accord325 View Post
Rev hang....maybe intake leak?
Would depend when the hang is, if the hang is only when the clutch is off and stops hanging once the clutch starts engaging, intake leak. If the rev hang continues as the clutch starts to engage or persists after, bad clutch.
No reason for the revs to drop real quick if the clutch isn't doing anything.
Originally Posted by Rich01 View Post
Find a hill and gun it going up, you'll know
This oughta work, find a decent hill, be in not the highest gear you could be (wouldn't be trying this in 4+ at 45ish)(maybe 2-3, don't remember what 2nd/3rd goes up to on MT)(point is you don't want to be at 2krpm and trying to floor it, nothing'll move even with no clutch) then floor it and see if rpms go up without speed doing the same thing. You'll notice the tach needle jump up then down, maybe a few times. Up as it slips, down as it's catching. If you are paying attention to the road and not tach/speedo, just plant your smartphone somewhere and record.
MT guys lmk if i'm backwards on being in a lower gear. I might be backwards on that where if you're in a higher gear and gun it usually the car just wouldn't move, vs with crap clutch it'll rev, but that sounds like it'll hurt the engine with a good clutch.
Intake leak usually happens when people install spacers the first 2-5 times. Most definitive sign of it is a pulse after letting off the gas, on gas no clutch at 5k (or something), let off gas, drops to 3k, still off gas jumps to 5k again. Can always confirm by spraying carb cleaner around the gaskets from the runners up.
Old February 7th, 2017, 07:37 PM   #32
Rev hang as in when flooring and right after i shift (let off clutch pedal and step on gas) rpm stays or slowly climbs like ur spinning ur tires very hardbut ur not and then rpm rises to redline.
But either way i think my clutch is still stock and is slipping a bit at 150,000. Seems like it was a hwy commute car too perhaps judging from the previous owner of how many yrs and miles they had it.
530av6 is offline   Reply With Quote Quick reply to this message
Old February 7th, 2017, 07:43 PM   #33
clutch is done for.
Old February 8th, 2017, 05:15 PM   #34
It seems to be fine after i beat on it for a while tho.
Old March 6th, 2017, 06:05 PM   #35
So after installing the 1.6" manifold spacer and hacked up my 4" cai into 4" to 3.5", itpulls better and i can def feel the torque difference. I guees every car will respond slightly differ to different mods.
Old March 18th, 2017, 07:10 PM   #36
So i put back in my stock jpipe and the car feels much more torque in the midrange qnd much more responsive but top end power towards redline has been decrease. What a big difference
Old March 24th, 2017, 04:30 PM   #37
The Jester
If the clutch is slipping you wouldn't be able to feel the extra torque anyway...
Swap your clutch before you get stuck with no traction.
Old March 24th, 2017, 05:09 PM   #38
07J30's Avatar
I can give u a good deal on a factory clutch/pp/flywheel used only 6k miles.
AGENT J: full bolt ons...flashpro tuned by Dom.
Old March 24th, 2017, 10:07 PM   #39
Im broke now though lol. But i barely drive my car. Been sitting mostly and ive only put about 3000 miles on it in 7 months.
Old March 26th, 2017, 01:06 PM   #40
07J30's Avatar
Well let me know i Might b sitting on it for awhile. Everyone on fb thinks i wanna give it away for $150, *******s.
thisaznboi88 likes this.
Human Verification
