my bolt on - Honda Accord Forum : V6 Performance Accord Forums
Like Tree2Likes
Old January 29th, 2017, 10:55 PM   #1
my bolt on
I have searched and that all these boltons adds power and their dyno graphs.
List of mod is
Rv6 pcd
X jpipe(3rd cat delete)
2.5" straight through tsudo catback
What i cant get over my head is how in the heck with these mods that i lost to a buddy's 06 accord coupe v6 manual all stock? Well not lost but he hang with me. We did 2 rolls at 20 mph and he was right beside my rear quarter panel and even more confuse right when ahifting into 4th he started creeping up on me too. How come i am not feeling or seeing the power.plus i was on 87 if that makes a difference too.
My car burns a little bit of oil tho but all compression are good too. I did it with engine warm.
Cyl-psi
1-205
2-217
3-210
4-220
5-210
6-215
Any thoughts here???
I recently added a j35 manifold from '10 tl and intake.planning to smooth runners next.
I remember reading a thread about the manifold spacer that he talks to these j series guys who has done experiment and testing and stuff that it doesnt make power or gains with full exhaust or something. I cant find the forum
530av6 is offline   Reply With Quote Quick reply to this message
Old January 30th, 2017, 06:42 AM   #2
Are you auto? Lol if that is the case a MT will beat you stock At dyno around 190 while a 6mt is around 210-220
Old January 30th, 2017, 01:21 PM   #3
Lol my bad. No mine is a manual too. Mine seems to lag power big time under 4k rpms like no torque.i thought my exhaust was maybe too much free flowing?
I just dont get it. Am i missing something. Oil level is good, air filter is good abd my spark plugs are still new. Could it be a bad lazy sensor like o2 or crank or cam or iat? Perhaps my tps or my aps?
Old January 30th, 2017, 01:25 PM   #4
I felt a loss of power n torque right after putting jpipe and pcd. That it doesnt pull as good as stock did but now im just use to it. Been lazy to try to put stock parts back in to feel the differ
Old January 30th, 2017, 03:21 PM   #5
not enough exhaust velocity. Try resetting the ecu. Unplug the battery and plug it back in 10 mins later
Old January 30th, 2017, 04:51 PM   #6
I've had all my mods for couple of months now and ive reset it like 5 times already and just reset it today again too. No difference.
Old January 30th, 2017, 05:04 PM   #7
yeah.. i don't know. his spraying a 25 shot. lol
Old January 31st, 2017, 02:13 AM   #8
No all stock. He just bought the car. What the heck is wrrong with ny car lol
Old January 31st, 2017, 07:50 AM   #9
Lol. try putting stock pre-cats back in. Stock intake ?
2006 accord v6 6mt
one of the best sleepers on the road
j32a3
accordlyfe is offline   Reply With Quote Quick reply to this message
Old January 31st, 2017, 07:55 AM   #10
accord325's Avatar
Stock wheels?
Old January 31st, 2017, 02:02 PM   #11
Stock wheels on 225 contipro contact tires. Might have to do with exhaust velocity or a slow lazy sensor. Doesnt seem like anyone have this experience. And besides i think my clutch is still stock at 150000 miles. Sometimes i get rev hangs in between shifting. Already did cvd
Old January 31st, 2017, 02:14 PM   #12
Just wondering how are you passing smog with PCD in california?
Old January 31st, 2017, 05:09 PM   #13
Oh i dont lol. I put it on after i bought the car from dealer and tag was already paid for.
Old January 31st, 2017, 05:34 PM   #14
replied to your PM message. There seems to be a lag in the system. But you should have 2 PM
Old January 31st, 2017, 06:13 PM   #15
Would timing jump or skip a tooth or so result in a cel or still run good?
Old January 31st, 2017, 06:15 PM   #16
it won't run good. you will have a multiple misfire and you will have a bent valve.
Old January 31st, 2017, 06:37 PM   #17
Hmm so guess not.
Old January 31st, 2017, 06:40 PM   #18
How would i tell if a ign coil is going bad or weak spark? Ive did the unplug per coils and it changed in idle so all is good. And ive read about testing each coils for ohms and every one is at 1.94 ohms. How would i go about testing the upstream 02 cuz i know downstreams barely ever go bad right.
Old January 31st, 2017, 06:42 PM   #19
My car idles good and throttle acceleration seems responsive too tho.
Old January 31st, 2017, 06:46 PM   #20
Another thing when i got it stock before and after doing the cvd on stock motor, i could chirp 2nd gear good both before and after. Buy when putting ocd and jpipe or nowadways, i can barely skirt 2nd. Only very little and i get rev hangs between shifts from redline. My clutch might still b stock at 150000 and seems like my car wwqs mostly hwy miles and u cand see all those cracks and rock chips from hwy trips
Old February 1st, 2017, 02:55 AM   #21
So i just recently came across a thread about camshaft swap and came upon reading that he wqs suggested to not use or install pcd recommended by richie becuz he notice a huge drop in torque with a full exhaust system.
Old February 1st, 2017, 08:06 PM   #22
On a stock J30 those exhaust mods maybe too much. IIRC Sonnick and those other guys mainly saw gains up top. However, before returningto stock cats, add the IM spacer. That has been proven to produce the most torque on our engines. P2R still makes them.
Old February 2nd, 2017, 12:16 AM   #23
I do indeed have the 1.5" spacer and studs and bolts and the thermo gasket. Just havent put the spacer on yet cuz im gonna have to adjust my intake higher. I agree that the mods shoukd have help power up top but it seems like it didnt help me in this case since mu buddys stock av6 kept up.
Old February 2nd, 2017, 12:32 AM   #24
Plus all my plugs are white too meaning im running lean? Theyre not like pure white but are whitish. No low coolant.
Old February 2nd, 2017, 12:38 PM   #25
The Jester
1.5 will be way too tall... you need that cut in half.
Old February 2nd, 2017, 12:42 PM   #26
gotta prop the hood up
Old February 2nd, 2017, 12:45 PM   #27
The Jester
I meant for power, not hood.
Old February 2nd, 2017, 05:42 PM   #28
accord325's Avatar
Rev hang....maybe intake leak?
Point A to B
NA.... Till I Spray
Old February 2nd, 2017, 09:15 PM   #29
Yeah ill prop the hood up. And as for rev hang its almost like a slipping clutch. Hard to tell.
Old February 3rd, 2017, 04:05 AM   #30
Find a hill and gun it going up, you'll know
oraclem19 likes this.
J36 (NVA-AV6) TUNED (Domgsr-t)
Human Verification
