J37 Intake Manifold and Throttle Body - Honda Accord Forum : V6 Performance Accord Forums
Old May 4th, 2017, 06:13 PM   #1
This came in the mail today from Bernardi Parts. Total cost with shipping: $436.59
Part Numbers:
Manifold: 17160-RK2-A00
Throttle Body: 16400-RK2-A01
AccordFire is offline   Reply With Quote Quick reply to this message
Old May 6th, 2017, 05:19 PM   #2
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
Bore out that T/B 3mm or 4mm moar!!....
Old May 6th, 2017, 08:26 PM   #3
I don't have the means to bore the TB. Keeping it as is. Its the latest version TB: GMD8C.
I have P2R TB spacer and manifold spacer and gaskets, and vibrant coupler with an AEM V2 intake. And I am getting PNP runners next week.
What else do I need for the manifold to transplant it onto a J30A4 with a manual transmission and butterfly valve?
I am going to get this top plate kit from a 2010 Accord for my J37 Manifold.
Part Number: 17140-R72-A01
Is there anything else that I need with the manifold other than the top plate kit? Do I need the EGR Pipe? Do I need any bolts?
Here is the diagram for the Honda plate and manifold and Acura plate and manifold.
Honda Accord J35Z3 used for a Honda Top Plate:
http://www.hondapartsoverstock.com/p...0-R72-A01.html
Acura TL SH J37A4 used for an Acura Top Plate:
https://estore.honda.com/acura/parts...n=&b=E++03&dl=
Old May 12th, 2017, 05:48 PM   #4
0VM66T's Avatar
I only use 1 P2R thermal gasket for the manifold spacer and have it on the top and stock gasket on the bottom. I read on one of the IM spacer threads about someone's experience with the bottom thermal gasket getting deformed.
3.5" Custom SRI, 3.7 Intake, Intake spacer, Throttle body spacer, Throttle body coolant bypass, Check valve delete, Synchromesh, HFPC & XLR8 V2, Jpipe, Stock exhaust minus mid-muffler, TLS sway bars, Grom mp3 adaptor
0VM66T is offline   Reply With Quote Quick reply to this message
Old May 14th, 2017, 08:03 PM   #5
The Jester
Yup, too much heat getting trapped, putting it on top prevents direct contact with the runners which lets it stay cooler, while keeping your IM just as cool.
Don't worry about porting the TB. Apparently there's only about 2mm safe zone of porting anyway, and unless your build is 450-500+ there's no need.
If you do want to however, I've done port and polished TBs for that generation.
I can't find my pictures of that TB finished since it's a rare job, but yeah that one is out 2mm, with a polish before machining, then a final surface polish after machining, with the spindle cut down, the screws shortened, then we finished that wih a polished and knife edged center plate to go with the PnP manifold, and PnP runners.
Old May 14th, 2017, 09:56 PM   #6
I'm not going to port my throttle body. I have P2R spacers on the IM and TB.
Human Verification
