Launch X431 Tool - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By 0VM66T
Old May 6th, 2017, 11:36 AM   #1
Launch X431 Tool
Has anybody ever used a Launch X431 iCarScan Bluetooth Tool and app to swap an Accord V6 ECU to a TL Type S ECU so that an engine management system can be added? The tool allows you to register your vehicle VIN number into the new TLS ECU, disabling the immobilizer as required to swap the ECU. The ECU swap is required to add engine management (Hondata or KTuner). This seems like the easiest method that I can find to accomplish an ECU swap from home, without going to the dealership. This seems about as easy as it gets.
https://www.amazon.com/Launch-diagno.../dp/B016U74RX2
https://www.youtube.com/watch?v=gVwkVLX_8D8
AccordFire is offline   Reply With Quote Quick reply to this message
Old May 8th, 2017, 05:28 PM   #2
0VM66T's Avatar
I recently went the Fly100 2nd Gen route which was over $100 more and not plug-n-play. I had to get a tech from overseas to remote login to change the registry to get the correct menu to show up.
I also bought a small tablet for $200 to run the software But after all that it works great ��
I looked at some of these other options but did not see anyone here having used them and went the Fly route.
If you try one, let us know how it goes.
Another option would be to see if thisaznboi88 can loan you his Fly100. He did an ECU swap for me before I bought my own Fly100.
thisaznboi88 likes this.
3.5" Custom SRI, 3.7 Intake, Intake spacer, Throttle body spacer, Throttle body coolant bypass, Check valve delete, Synchromesh, HFPC & XLR8 V2, Jpipe, Stock exhaust minus mid-muffler, TLS sway bars, Grom mp3 adaptor
0VM66T is offline   Reply With Quote Quick reply to this message
Old May 8th, 2017, 07:16 PM   #3
Fly100 works for me but I had to use a windows XP netbook. I did not try to use the emulator on windows 10 since I couldn't get it to work on 7 or 8
Old May 11th, 2017, 03:32 AM   #4
J30 LSD
flylow2cre8's Avatar
I recently purchased a genuine gna600 kit from a previous Honda tech on eBay. If you lived close to me in Georgia I could assist you with this. Hope you can get it to work.
Old May 14th, 2017, 11:32 PM   #5
I think this X41 Tool will work. I will let everybody know.
Old May 17th, 2017, 02:07 AM   #6
I spent 200 hours the beginning of the year hacking a launch x431 pro2 tablet.
Bense is offline   Reply With Quote Quick reply to this message
Old May 17th, 2017, 12:45 PM   #7
Bense, why did you hack the x431 tablet?
I just want to change the Vin on a TLS ECU so that I can add Engine Management.
Old May 17th, 2017, 02:52 PM   #8
Because that's what my customer brought to me and said he wanted hacked.
Human Verification
