Make her Stop Moaning - Power Steering Pump TSB DIY - Honda Accord Forum : V6 Performance Accord Forums
Old February 15th, 2010, 08:25 AM   #1
Czechopino
vasekvi's Avatar
After I replaced my alternator, my power steering started moaning and groaning especially when cold. I figured that it was because I was manhandling the power steering pump to get the belt back on. So I did some research and found the HondaTSB 07-086. I did the job which took all of 5 minutes, and the power steering pump finally shut the hell up. Cost is around $5.00 for the parts.
The TSB is for all 7th Generation V6 Accords
Parts and Tools Needed.
1. O-ring - Honda Part Number P/N 08206-9002
2. Genuine Honda Power Steering Fluid - H/C 3747284
3. Shop Towel
4. 10mm wrench
5. Bottle of Corona Extra and lime wedge (Optional)
Here is the O-Ring.
The Power Steering Fluid
Here is the inlet joint bolt you will be removing
Step 1.
Place shop towel under the inlet joint to catch the fluid that will come out when you remove the joint.
2. Use 10mm wrench to remove bolt from inlet joint
3. Separate the coupler
4. Remove old O-Ring from the inlet hole. My old one was black and the new one was red.
5. Install the new O-ring to the inlet hose coupler
6. Reinstall the joint and tighten the bolt.
7. Check the power steering fluid level and add fluid if necessary.
8. Start the engine and turn the steering wheel lock to lock to verify that the noise is gone.
9. Stop engine and check power steering fluid again.
10. Move on to doing more fun things to your car..... like installing Hybrid mirrors or getting your mud guards painted body color.
11. Install lime to neck of Corona bottle as shown, if you have not done so already.
My SSM Sedan Mod Thread
Old February 15th, 2010, 03:57 PM   #2
Damn You All !!!
VTEC4ME's Avatar
Send a message via AIM to VTEC4ME
Awesome write up.
Step 5 is a must!
VTEC4ME is offline   Reply With Quote Quick reply to this message
Old February 15th, 2010, 07:21 PM   #3
paperboy42190's Avatar
when i turning my steering wheel all the way to the right, and then go in reverse, i get some weird "creaking" sounds. it doesnt happen when my steering wheel is turned to the left, nor does it ever happen when i am going forward. and this is intermittent too, its happened in cold and hot weather, at random times. its not a big deal so i havent taken it to a mechanic, but anyone have any ideas?
Nighthawk Black Pearl 2007 Acura TL Type-S
paperboy42190 is offline   Reply With Quote Quick reply to this message
Old February 16th, 2010, 01:30 AM   #4
Quicksilver
davesv6's Avatar
mine does the same exact thing only, it happens going forward too, and only to the right also. idk what it is. like my steering column needs lube or something.
davesv6 is offline   Reply With Quote Quick reply to this message
Old February 16th, 2010, 02:08 AM   #5
nice to know im not alone on this problem =D
Old February 16th, 2010, 08:23 AM   #6
original member!
Nittanys1's Avatar
good job on the write-up...I wish we had known about this before replacing the entire PS pump and nothing got better......
Ohh and we threw out the "old" PS pump!!! DAMN!!!
Old February 16th, 2010, 08:50 AM   #7
Banned
Lxcord's Avatar
how many quarts of pwr steer fluid is needed to change out the fluid? like a drain and refill ?
Old February 16th, 2010, 09:41 AM   #8
-Gene
phunctional's Avatar
nice! i really like # 10
phunctional is offline   Reply With Quote Quick reply to this message
Old February 16th, 2010, 09:42 AM   #9
i dont think you ever need to drain and fill on power steering fluid for pretty much the life of the car.
Old February 16th, 2010, 10:07 AM   #10
Quicksilver
davesv6's Avatar
same here, but i still want to know what the problem is, and how to fix. its annoying to have noises like that ya know.
Old February 16th, 2010, 12:11 PM   #11
yea....u think replacing the O ring in this thread will help any?
Old February 16th, 2010, 12:15 PM   #12
Czechopino
vasekvi's Avatar
I would replace the O ring if you notice a buildup of dirt and grime around where the coupling is, indicating a seal that needs to be replaced.
Old February 16th, 2010, 08:44 PM   #13
aRod914's Avatar
i also have the same issue...although mine only makes that noise when i turn to the left...never did get it checked out by the dealer, but im so used to it now, i hardly notice....
BTW...thanks to the OP...this was a great DIY..I will do this over the weekend, my car has been moaning since i bought it back in 2006. Dealer never knew where the sound was coming from...
aRod914 is offline   Reply With Quote Quick reply to this message
Old February 16th, 2010, 10:12 PM   #14
Quicksilver
davesv6's Avatar
i hope it helps. im doing it tomorrow after class. we will see. btw, did you know there is 2 different O rings...?? didnt know that until i went ot the dealer to buy the part. im gonna change them both.
Old February 17th, 2010, 12:34 AM   #15
Banned
Lxcord's Avatar
hmm owners manual says every 35K miles, its in the schedule
Old February 17th, 2010, 01:48 AM   #16
Old February 17th, 2010, 01:50 AM   #17
lemme know if it solves the problem. if it does, i'll do it. if not, i may consider the power steering fluid drain and flush
Old February 17th, 2010, 02:27 PM   #18
apparently its even easier for the 4 cylinders
Old February 17th, 2010, 06:43 PM   #19
Quicksilver
davesv6's Avatar
hey bro, well i did the O ring today. Just the one thats in the OP, and the noise went away. but i still have air bubbles in the fluid, so im gonna try to find time to change the other O ring and see what happens.
Old February 17th, 2010, 10:22 PM   #20
V6GreenMachine's Avatar
I thought i was the only one with this problem! Im glad to hear that im not the only one with an embarrassing sound every morning when i show up to work haha! Ill be fixing it this weekend!
V6GreenMachine is offline   Reply With Quote Quick reply to this message
Old February 18th, 2010, 11:09 AM   #21
Quicksilver
davesv6's Avatar
ok, status update. i didnt change the other ring yet, but last night i read over my repair manual, and i didnt bleed the system by "turning it lock to lock several times to get the air out of the system". i had only done it one time. so this morning i went and did what it said to do, no more air bubbles in the fluid, and no more creaking noise. im happy now.
Old February 18th, 2010, 01:14 PM   #22
sry but how do u bleed the power steering fluid? >.< and thx, im gonna do the o-ring too!
its #11 right? http://www.hondapartsnow.com/diagram...-06-466307.png
and whats the 2nd O-ring? what # is it?
Old February 18th, 2010, 01:40 PM   #23
o man guess what i just found
gonna replace o ring and the whole plastic thing and hope it helps with the creaking
Old February 18th, 2010, 02:17 PM   #24
wow i just looked at the pic...its not broken at all and its only supposed to be held on by 1 screw on 1 side....FML i fail so bad.
bought a new one for nothing, lol
Old February 18th, 2010, 02:27 PM   #25
original member!
Nittanys1's Avatar
return it...
Old February 18th, 2010, 02:29 PM   #26
FML!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old February 18th, 2010, 02:33 PM   #27
original member!
Nittanys1's Avatar
wow dude that blows...try using some needle nose pliers to get it out...
Old February 18th, 2010, 02:38 PM   #28
i'll see if i can get my hands on one.
Old February 18th, 2010, 02:46 PM   #29
hm i dont think that little area is enough for needle nose pliars to grab it out. anyone here around riverside who has a drill can help me drill this thing out?! please?
Old February 18th, 2010, 02:54 PM   #30
-Gene
^^ omfg lol you got horrible luck sorry to hear
Human Verification
