what will happen if i overfill my manual transmission fluid - Honda Accord Forum : V6 Performance Accord Forums
Old June 12th, 2010, 07:49 PM   #1
FG4
Batmobile's Avatar
Exclamation What will happen? Overfilled manual transmission fluid
Hey guys i own a 05 av6 6mt and i took my car to jiffy lube to have them change my engine oil and transmission fluid. As soon as i left i felt my clutch acting funny but i had taken my car to the track 5 days ago so i didn't make anything out of it.I then took off to school and 4 hours later i came out and i checked underneath my car for oil leaks and i spot a bunch of puddles all over my car. I then drive off the parking lot and on second gear half throttle my clutch slips, like if it was in neutral. It is now 9:30 and i cant do anything about it so i drive home and park my car jack it up and the first thing that came to mind was oil leak. The whole bottom of my car was dripping with oil. I couldn't spot anything but my friend johnny came to conclusion that it was tranny fluid. So next day 7am took the car back to jiffy lube and they checked it out they said oh its just tranny fluid they might have over filled it with pump and i told them to drain the fluid and fill it on top where 3/8 plug is at and guestimating 3 qt came out when they drained the tranny oil not considering what had come out on the road and at school. They filled it back up with the 2.3 - 2.6 and i was off. So now the clutch still slips and while in gear half throttle i sometimes feel that the pedal and the gear lever will vibrate then i let go of gas and then it stops. So i need to know if my clutch is going out because of wear and tear or if its going out because of them overfilling my transmission.
btw: i dont know where the tranny spew hole is at but I have read that sometimes it spews into the clutch housing and soaks the clutch in oil. Dont quote me on this
Batmobile is offline   Reply With Quote Quick reply to this message
Old June 12th, 2010, 11:20 PM   #2
FG4
Batmobile's Avatar
Anyone?
Old June 12th, 2010, 11:32 PM   #3
man off all the places you took your car too.. Jiffy lube... don't you watch dateline? Car comes in perfectly fine and next thing you know BAM its dead.
Anyways. Was it slipping before? Did you use honda OEM MT tranny fluid? Or did they use some water down crap. How many miles on the car?
thisaznboi88 is online now   Reply With Quote Quick reply to this message
Old June 12th, 2010, 11:54 PM   #4
iVTECaddict's Avatar
The transmission fluid has nothing to do with the clutch.
iVTECaddict is offline   Reply With Quote Quick reply to this message
Old June 13th, 2010, 12:49 AM   #5
FG4
Batmobile's Avatar
It was not slipping before i don't know if it was coincidence but it started after i left jiffy lube . When they overfilled it they used some "powerslot" generic brand then i made them put OEM. 72,000 miles on the car
Old June 13th, 2010, 12:57 AM   #6
FG4
Batmobile's Avatar
Here is a vid of me in 6th gear all three times that i push on gas pedal is on half throttle. The car revs but it doesn't go anywhere, mph does not go higher
&mpt=[CACHEBUSTER]">
Old June 13th, 2010, 12:58 AM   #7
FG4
Batmobile's Avatar
then where is the spew hole?
Old June 13th, 2010, 01:44 AM   #8
i thought MT, you cant overfill? well.... 4 banger you just keep filling until it comes out and plug the hole.
i think it could likely be that they spilled the oil in the clutch area so now the clutch is oily thus slipping... b/c the clutch area isnt exactly air tight, if there was oil all over the place, might be some on the clutch.
asnstyle22 is offline   Reply With Quote Quick reply to this message
Old June 13th, 2010, 04:42 AM   #9
M90SC Boosting 13PSI
NVA-AV6's Avatar
There is a breather tube inside the trans which is where excess fluid would come out, this fluid can then easily get on the clutch causing slipping and fouling the clutch with trans oil. Basically Jiffy Lube owes you a clutch.
Old June 16th, 2010, 04:02 PM   #10
FG4
Batmobile's Avatar
proof, you the man Paul
So jiffy lube got the job clutch job quoted at 650 at their mechanic shops and they said that the most they will give me is 700 for the job including auto parts clutch. I demanded the work be done at Honda but they declined me to fix it there because it was going to be too much. am i out of line to demand that my clutch be replaced by honda with oem parts when i still had original clutch?
Old June 16th, 2010, 04:29 PM   #11
NVA-AV6's Avatar
Ohh I think it may be time for the family lawer to write a letter to jiffy lube, just get everything well documented and keep the parts, that clutch looks like it would have had ALOT of life left to it.
Old June 16th, 2010, 07:34 PM   #12
BLCKFLSH's Avatar
Jiffy Lube should not get to choose who fixes it, or how much it costs. Jiffy lube needs to make sure it's emplyees know what they're doing, so this wouldn't happen.
BLCKFLSH is offline   Reply With Quote Quick reply to this message
Old June 17th, 2010, 03:17 AM   #13
^ i agree.. they break it they bought it, cant be going around breaking bmws and offering ford as replacement... yea...if they **** your car up during a simple oil change that they do all day long, i would seriously bring into question the competence of their "mechanic"
Old June 18th, 2010, 03:55 PM   #14
FG4
Batmobile's Avatar
Hey Paul, do you think that you can show me where the spew hole is at?
Old June 18th, 2010, 06:05 PM   #15
NVA-AV6's Avatar
See that metal cover next to the starter hole being held on by one 10mm head bolt, it is behind that.
Old June 19th, 2010, 01:18 AM   #16
FG4
Batmobile's Avatar
Is this the cover that you are talking about Paul?
Old June 19th, 2010, 03:34 AM   #17
NVA-AV6's Avatar
Yup
Old July 11th, 2010, 12:37 PM   #18
I'm curious, how is it possible to overfill the MTF when the instructions tell you to fill it until it starts to come out of the fill plug? Unless you used the wrong fill hole, you'd literally need to use a positive displacement pump and cap it really really fast, by which time you should have realized you were doing it wrong...no?
N4TECguy is offline   Reply With Quote Quick reply to this message
Old July 11th, 2010, 12:43 PM   #19
Pew Pew Pew
SnOoZeR's Avatar
Send a message via AIM to SnOoZeR
for the v6 you dont fill it til it comes out the fill hole cause the fill hole is on top not like other manual trans.
SnOoZeR is offline   Reply With Quote Quick reply to this message
Old July 11th, 2010, 03:31 PM   #20
✔ Verified Member
otsb708's Avatar
2.6 quarts is what my owners manual says.
Old July 11th, 2010, 04:59 PM   #21
Interesting...so no way to check the level, but if you don't get the level right, you could cook the gears/syncros or the clutch. Wonder which brilliant engineer thought of this idea.
Old July 12th, 2010, 07:28 AM   #22
johnb35711's Avatar
Send a message via AIM to johnb35711
Same engineer that included the check hole.
johnb35711 is offline   Reply With Quote Quick reply to this message
Old July 12th, 2010, 09:10 AM   #23
pawel's Avatar
There is actually a screw you take out on the front of the case and fill it in till its starts coming out. It's a tinny screw i think 10mm wrench size.
pawel is offline   Reply With Quote Quick reply to this message
Old July 12th, 2010, 07:00 PM   #24
So then why don't people just fill it through the check hole
Old July 12th, 2010, 07:17 PM   #25
FG4
Batmobile's Avatar
check hole is on side and in small spot so kinda difficult to fill through there
Old July 13th, 2010, 07:49 AM   #26
✔ Verified Member
otsb708's Avatar
Originally Posted by N4TECguy View Post
So then why don't people just fill it through the CHECK hole
because it isnt the FILL hole....
Old July 21st, 2010, 04:53 PM   #27
drzchulo147's Avatar
Send a message via AIM to drzchulo147
Originally Posted by otsb708 View Post
because it isnt the fill hole....
:d:d:d:d:d:d:d:d:d:d:d:d
Originally Posted by NonovUrbizniz
Well if you want to manually retard the timing then you just rotate the distributor towards the retard... IE You standing in front of the car.
drzchulo147 is offline   Reply With Quote Quick reply to this message
Old July 21st, 2010, 04:54 PM   #28
:d Nice response.
Old August 4th, 2010, 08:20 PM   #29
FG4
Batmobile's Avatar
Thanks guys for all the help, Specially to Paul
Court ruled in my favor, Got my Money Back!!!!!!!!!!!!!!!!
Old August 4th, 2010, 11:02 PM   #30
paperboy42190's Avatar
congrats! and shame on jiffy lube!
Nighthawk Black Pearl 2007 Acura TL Type-S
paperboy42190 is offline   Reply With Quote Quick reply to this message
Human Verification
