06 V6 Accord - Replacing power steering pressure hose - Honda Accord Forum : V6 Performance Accord Forums
Old July 23rd, 2012, 09:21 AM   #1
Grohe's Avatar
Need to replace item #4.
How hard of a job is this to do? Any special info/instructions I need to know.
2006 Honda Accord EX-L V6
Grohe is offline   Reply With Quote Quick reply to this message
Old July 23rd, 2012, 01:21 PM   #2
VTEC PWNES ALL
2muchbass's Avatar
thats not an easy fix brah i think the steering rack has to be dropped i paid a shop to replace mine a few years back
2muchbass is offline   Reply With Quote Quick reply to this message
Old July 23rd, 2012, 03:50 PM   #3
BLCKFLSH's Avatar
The technical way to change it, is to unbolt the rear engine mount, and pull the hose out from under the mount. If you are very careful, and take your time, you can bend the metal part just enough to wiggle it through the mount without unbolting it. I did everything from above, because it's just impossible to see anything from under the car. I suggest using a line wrench to remove the flare-nut on the rack, and changing the o'rings on the pump end of the hose and the pressure switch.It's not an easy job. Removing the brackets that hold the hose is difficult, and putting them back on is even harder. Any questions?
BLCKFLSH is offline   Reply With Quote Quick reply to this message
Old July 24th, 2012, 09:32 AM   #4
hiphop23j's Avatar
im having the same problem..my hose went bad and on long drive it leaks and falls on the headers and makes a smokey funny smell
hiphop23j is offline   Reply With Quote Quick reply to this message
Old July 26th, 2012, 10:47 AM   #5
Grohe's Avatar
It actually wasn't too bad to replace. Hardest part was just getting the lines in/out. Had to bend the end of the new one a little bit to fit it under the motor mount. Took less than 2 hours as well.
EDIT: Just make sure you get new O-Rings.
Old August 7th, 2012, 10:05 PM   #6
I recently tackled this job. Had to take the rear motor mount and mount bracket out to expose the hose and replace with relative ease. I tried bending and wiggling at first but it turned out to be more work than to just take the mount parts out.
salvageland is offline   Reply With Quote Quick reply to this message
Old August 16th, 2012, 01:37 AM   #7
I did my last year. It costed me $97 for the part. taking the hose out was't a problem because i can bend it however i want. but putting the new one in took me hours. trying to remove right front wheels sneaking it in from a side but still didn't work. I ended up having to take out the engine mount.
in the middle of the work i wished i had paid $100 to my mechanic to do the work for me. lol
jdmlover is offline   Reply With Quote Quick reply to this message
Old September 4th, 2012, 08:52 PM   #8
hbkxham is offline   Reply With Quote Quick reply to this message
Old September 7th, 2012, 11:08 AM   #9
It was a huge pain in the ass.. Did it a few months ago. Had to do what was posted above. Take the rear motor mount out.. Jacked up the engine and it wasn't so bad after that.. It was getting to that point that took forever.
Good luck.. Take your time and try not to get frustrated.
RabidTrout is offline   Reply With Quote Quick reply to this message
Old September 7th, 2012, 03:19 PM   #10
I was on the same page. I once thought it would be impossible to put it in after a few hours of trying. I finally set my mind to do whatever it might take. The whole process took me 5 hours in total. =[
Old September 7th, 2012, 11:13 PM   #11
BLCKFLSH's Avatar
The fact that I had bent the old line with no regard to how it looked when I got it out, and it didn't have any kinks in it, led me to believe I could get the new one in without damaging it. It took me about 2 hours, but most of that was spent trying to get one of the mounting brackets (the one closest to the rack fittings) back on and bolted to the frame. I almost just left that bracket off, but I was determined to get it done.
Old April 11th, 2013, 04:56 PM   #12
Careful in this install - catastrophic results
I just had my Honda Accord V6 2006 Power steering recall fixed. I came home and the car caught fire about eleven minutes after I parked in my garage. About 200k damage right now. Investigators say the probable cause is failure to follow installation procedures and clean up the fluid sprayed during installation. My advice - clean up the fluid if you have to do it yourself. This is a project that can have catastrophic results. Good luck.
rocroc is offline   Reply With Quote Quick reply to this message
Old April 11th, 2013, 05:00 PM   #13
No, no, no. Please do not use a work around on this procedure. See my post.
Old April 11th, 2013, 06:03 PM   #14
nismoasfuh's Avatar
JESUS! too bad same thing happened to me, i posted in the recall thread about the **** job they did. i drove my car maybe 1 min after the recall and steam was bellowing from my car. pretty ironic that i went to prevent my car from catching on fire and they made it extremely possible. there was old ps fluid literally everywhere in my engine bay. i was so upset over it, i went back, *****ed at them, and they just offered a car wash. i said how about an engine bay cleaning
Old April 11th, 2013, 09:20 PM   #15
Important to Know
That is very important to know. If the Honda procedure for doing the recall or if the parts themselves are defective then Honda is responsible. If the mechanic does the recall wrong then the dealership is responsible. Perhaps both. Any others out there with a similar experience?
Old April 11th, 2013, 10:13 PM   #16
Mr. Detail
Scottwax's Avatar
Wow, no fires before the recall but after? Crap.
Old April 12th, 2013, 08:22 AM   #17
Mines not leaking, and I'm not touching it unless it does.
200366HFP is offline   Reply With Quote Quick reply to this message
Old April 12th, 2013, 09:23 AM   #18
Old Member
Du3ce's Avatar
ditto
2007 Accord EX-L V6
Old April 13th, 2013, 06:20 PM   #19
BLCKFLSH's Avatar
I was thinking about asking them to give me the new redesigned hose, so I could install it myself, so as not to let the lazy idiots at the local dealership touch my car. It's a shame you can't trust them to do a job correctly.
Old April 13th, 2013, 07:30 PM   #20
X2 - Let me know if they do, I would do the same, just to have it on the shelf if it ever starts to leak.
Old April 13th, 2013, 10:50 PM   #21
nismoasfuh's Avatar
They do a fine job of properly installing it, just not a clean one. I have yet to take degreaser to my engine bat, only reason it needed it though was honestly from this recall.
Old April 14th, 2013, 06:48 PM   #22
BLCKFLSH's Avatar
I'll probably still let them change the hose. But now I know to clean up the mess they'll probably leave. My engine bay has only dust on it at this point, and I want to keep it that way. I enjoy working on MY car, because I know I'm not going to look like a grease monkey when I'm done. I would have probably enjoyed being a mechanic, if everyone else's engines were as clean as mine.
Old April 14th, 2013, 06:58 PM   #23
BLCKFLSH's Avatar
Thing is, you can do it without making a huge mess. I unbolted the end at the steering rack first, and let the fluid drain into a pan before unbolting the pump end. I had already drained and replaced the reservoir, before working on the high pressure line, so there was only fluid draining from that line, when I disconnected it. The dealership knuckleheads probably do it with everything full.
Old April 16th, 2013, 09:41 PM   #24
not only happens to accord's
civics have same problem, yesterday a friend had that problem the result in the picture.
pollo is offline   Reply With Quote Quick reply to this message
Old April 23rd, 2013, 12:58 AM   #25
Ouch ^
As for installing the hose, I have also done it without touching the motor mount, by bending the new hose slightly
mc1114 is offline   Reply With Quote Quick reply to this message
Human Verification
