Bye Bye EGR....... - Honda Accord Forum : V6 Performance Accord Forums
Like Tree3Likes
Old June 2nd, 2009, 06:55 PM   #1
M90SC Boosting 13PSI
NVA-AV6's Avatar
Bye Bye EGR.......
Well, not exactly, but damn close enough. As we all know the EGR system robs some power by injesting hot/dirty exhaust gases directly back into the intake. We can't remove the valve without throwing a code and we can't block it without throwing a code. If we block it the ECU throws a "Isufficent Flow" code as well as the ODB emissions monitor will show error since the ECU actually detects the lean out caused by the EGR opening and flowing exhaust back, and this is the key, the ECU does not care weather it is hot exhaust or cold/clean intake air. So I decedied to machine out a EGR Bypass Adaptor that allows us to connect eaither a breather filter or a hose connected back to the breather fitting on the intake. I just came back from a 50+ mile test drive with no codes thrown and for good mesure before I left on the drive I reset my ECU and emmissions monitors after the drive I checked and the EGR emissions monitor was happy with the bypass, so this will not effect passing emissions, and probably will pass visual if you hook a hose back into the intake.
Thanks to Shonda for jogging my brain and getting me to think of this.........
This will also work for 6th gens and K-series although the bypass connection is in a different place for Ks......
Old June 2nd, 2009, 06:59 PM   #2
v not some model, my girl
99v6sedan's Avatar
saweet! paul you are having too much fun with that milling machine. lol
my car is going to need this. my CEL has been on for a while because of my EGR.
Old June 2nd, 2009, 07:01 PM   #3
So what all needs to be done to install this?
Old June 2nd, 2009, 07:02 PM   #4
NVA-AV6's Avatar
Pull the two stock studs that hold the egr valve on and replace them with longer bolts.
Old June 2nd, 2009, 07:05 PM   #5
SC J32A3 Accord
Any difference in power feel? I think this would be very beneficial to us with FI.
Keep on innovating Paul!
SleekAV6 is offline   Reply With Quote Quick reply to this message
Old June 2nd, 2009, 07:05 PM   #6
Nate and I were just talking about this the other day.
Old June 2nd, 2009, 07:48 PM   #7
nice
Old June 2nd, 2009, 08:10 PM   #8
99VTECCoupe's Avatar
Send a message via AIM to 99VTECCoupe
And what does the PCM do when it notices that the exhaust gas temp is way too high? It's probably going to pull timing which decreases power, right?
99VTECCoupe is offline   Reply With Quote Quick reply to this message
Old June 2nd, 2009, 08:43 PM   #9
NVA-AV6's Avatar
It does not mesure exhaust temp, and how would not ingesting hot exhaust gases cause higher exhaust temps?????
Old June 2nd, 2009, 08:56 PM   #10
There's no EGT sensor on these cars? I didn't know that.
EGR lowers the combustion temperature. I believe this is because the exhaust gas can absorb greater specific heat. EGR also tends to make the engine more efficient because it allows advanced timing (lower temp = less preignition tendency) and less throttle loss (less power available at part throttle = higher throttle angle).
Isn't the EGR turned off at full engine load anyway? I've never done anything with a Honda engine at work, but all the GM/Chrysler/Ford engines have zero EGR flow at anything above like 90% throttle.
edit - I understand what you're trying to do, but it doesnt really work on modern cars with modern electronics and variable EGR. The EGR is off at full throttle so it only 'robs' power at part throttle, which in turn actually (and counterintuitively) makes the engine more efficient (better gas mileage). So unless you're a part throttle racer unconcerned with fuel economy, EGR is one of those things that does very little harm aside from a little more carbon deposits upstream of the cylinders. EGR does take a lot of power out of diesels and older gasoline engines, but in the modern ones it really makes no difference. I appreciate you trying to do new stuff and you've done a lot of bad ass things on the J series, but IMO this does more harm than good. However, if Honda uses the EGR at full throttle (unlike every other gasoline engine I've ever tested/instrumented), this is all wrong.
Old June 2nd, 2009, 08:59 PM   #11
- Leo
03_AV6's Avatar
wow, finally. Ive been wanting to eliminate or some how modify the EGR for a while now. Nice work Paul!
Old June 2nd, 2009, 09:10 PM   #12
chiefy's Avatar
wow paul u r the best... what all is needed to get this done?
spool or be schooled!
Old June 2nd, 2009, 09:28 PM   #13
resident noob
quick kid 87's Avatar
so with this, the exhaust gases still get recylced but never make it into the intake manifold, only fresh air does? If i am correct here with my intrepretation of this, where do the recylced gases now go? If i'm way off please tell me.
Also, i too was under the impression that no exhaust gasses get recylced during full throttle? is that true?
quick kid 87 is offline   Reply With Quote Quick reply to this message
Old June 2nd, 2009, 09:30 PM   #14
v6COMPTECH's Avatar
Originally Posted by chiefy View Post
wow paul u r the best... What all is needed to get this done?
really wat do wee need to do for this ..? Gain hp or decrease ?
03 ACcord 6 Speed ///
100 wet shot N0S
v6COMPTECH is offline   Reply With Quote Quick reply to this message
Old June 2nd, 2009, 09:41 PM   #15
EGR =/ DEI
http://www.autoblog.com/2007/11/16/a...ust-injection/
Old June 2nd, 2009, 10:07 PM   #16
Honda Rookie
pbook4g5's Avatar
Nice work Paul. What do I need to do to get you one for me? I have two extra EGR valves....
Also, we need to discuss the J37 or whatever the current popular/good build is... I've got the itch...
Car runs amazing, by the way... constant 37 mpg now. Love it.
“Success is 99 percent failure.”
- Soichiro Honda
Old June 2nd, 2009, 10:10 PM   #17
can u get me one for the k24 prettty please
mec33 is offline   Reply With Quote Quick reply to this message
Old June 2nd, 2009, 10:11 PM   #18
- Leo
03_AV6's Avatar
lol at DEI
Old June 2nd, 2009, 10:20 PM   #19
hmmm what next?
shonda1989's Avatar
paul make another i want one just let me know via PM.
Old June 2nd, 2009, 10:51 PM   #20
3.56thgen's Avatar
ummm...I need that lets test that on my car
3.56thgen is offline   Reply With Quote Quick reply to this message
Old June 2nd, 2009, 11:29 PM   #21
CRV_33's Avatar
Great job to NVA-AV6 and Chris
Old June 2nd, 2009, 11:48 PM   #22
The End.
IcyAccord's Avatar
Can I buy one.. lol
Old June 3rd, 2009, 12:00 AM   #23
FAILLLLLLLL
whiteV6penguin's Avatar
wooot something for the 6th gen too!
whiteV6penguin is offline   Reply With Quote Quick reply to this message
Old June 3rd, 2009, 12:11 AM   #24
MoneyPit's Avatar
yes, the EGR is off at both idle/WOT on these cars. the bypass paul has machined WILL allow for smoother (not higher) power delivery though midrange throttle %, but like you mentioned, it will be useless at WOT.
MoneyPit is offline   Reply With Quote Quick reply to this message
Old June 3rd, 2009, 12:22 AM   #25
x2
Old June 3rd, 2009, 04:04 AM   #26
NVA-AV6's Avatar
I will make these avalible to whoever wants one, the cost will be $100 shipped which will include new correct legnth bolts and new EGR valve gaskets. The inlet will be 1/2" hose mipple so you can connect it with eaither a simple breather element or route a hose to the intake. I will pull together a step by step when I install one on Kai's car this Satruday. The hardest part of the install will be removing the existing studs, you have to take the two nuts and lock them against each other on the stud by tightening them against each other and then trun them out like bolts. Anyone interested please PM me.
7.5GenV66MT likes this.
Old June 3rd, 2009, 04:05 AM   #27
NVA-AV6's Avatar
Yes, just make sure I know it is for a K, the hose nipple has to be machined in a different location.
Old June 3rd, 2009, 04:06 AM   #28
NVA-AV6's Avatar
Originally Posted by IcyAccord View Post
Can I buy one.. lol
Yes, and I know I still have to pull out that cam and make the jig for machining a CL-S one for you...
Old June 3rd, 2009, 04:07 AM   #29
NVA-AV6's Avatar
LOL, I knew you were going to say that.
Old June 3rd, 2009, 04:09 AM   #30
NVA-AV6's Avatar
Great, I figured you would eng up just a little shy of J36/J35 MPGs, give me a call and we can discuss Stage 2...
Human Verification
