Small Questions Thread (Search First, Then Come Here) 7G Edition - Page 19 - Honda Accord Forum : V6 Performance Accord Forums
Like Tree20Likes
Old April 5th, 2014, 11:05 AM   #541
Nam
nanana's Avatar
Engine light came on last night and turned itself off this morning. What can it be? I already tighten the fuel cap.
nanana is offline   Reply With Quote Quick reply to this message
Old April 5th, 2014, 11:14 AM   #542
Czechopino
vasekvi's Avatar
Go to am auto parts store and have them scan your ecu. You may have to wait for the light to come back on. It could be many different things
Sent from my Samsung GALAXY S4 using Tapatalk Pro
My SSM Sedan Mod Thread
Old April 11th, 2014, 08:39 PM   #543
Nam
nanana's Avatar
Turned out the engine light was caused by a loose fuel cap, tighten the cap and it was okay. Now the DRL appears the dashboard Low and high beam work, but the DRL does not. Advice?
Old April 12th, 2014, 11:02 PM   #544
Murders23's Avatar
Anyone know the weight of the 06-07 7th gen 6speed wheels?
Murders23 is offline   Reply With Quote Quick reply to this message
Old April 13th, 2014, 12:09 AM   #545
Mr. Detail
Scottwax's Avatar
I believe the stock 16 x 6.5 wheels are around 25 lbs? So the 17" wheels, maybe a bit more.
Old April 17th, 2014, 09:43 AM   #546
Murders23's Avatar
I thought they were less. Any one else know?
Old April 24th, 2014, 02:30 PM   #547
clinn57's Avatar
Mine does the same thing sometimes. It's usually a cat code that goes away on its own.
clinn57 is offline   Reply With Quote Quick reply to this message
Old April 29th, 2014, 03:41 PM   #548
05 accord v6 m6
170k
Replacing the timing belt and well i messed up, have done them before and no problems, oh well time to fix my mistake. Anyways lost compression in 4 of 6 cylinders. Should I replace ALL VALVES? does anyone have a goto parts list such as intake, exhaust, manifolds, gaskets etc. and the corresponding part numbers?
Any help would be much appreciated.
Damian989 is offline   Reply With Quote Quick reply to this message
Old May 12th, 2014, 05:17 PM   #549
IIRC it's around 24-25 lbs per wheel.
Murders23 likes this.
03EX is offline   Reply With Quote Quick reply to this message
Old June 13th, 2014, 01:03 PM   #550
Hey guys,
Anyone know if tokico blue struts are the same for V6 sedans and coupes?
6MTACCORD is offline   Reply With Quote Quick reply to this message
Old June 13th, 2014, 01:41 PM   #551
Honda enthusiast
michaellowrider's Avatar
same for all 03-07 accord iirc.
Old June 13th, 2014, 01:41 PM   #552
The name is Z
CrackerTeg's Avatar
Originally Posted by 6MTACCORD View Post
Hey guys,
Yes.
Old June 13th, 2014, 01:43 PM   #553
Originally Posted by CrackerTeg View Post
Yes.
Thank you guys!!
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Old June 18th, 2014, 09:50 AM   #554
Very good information in this thread, have learned a lot already
MTV6SEDAN is offline   Reply With Quote Quick reply to this message
Old June 22nd, 2014, 12:02 AM   #555
When your HVAC temp is set to Lo, is the A/C being used at all? The temp feels surprisingly cold for not having the A/C turned on. I'm thinking the compressor has a variable setting or something.
nuron is offline   Reply With Quote Quick reply to this message
Old June 30th, 2014, 04:40 PM   #556
05accord6spd's Avatar
Hi v6performance im just wondering if you guys think this sounds like a tyranny mount is broken. When i go around an inclined turn(roundabouts/entering a gas station or driveway) i get a knocking under my arm rest/shifter. it sounds just like when i had a engine mount out only not in the front of the car its right under my seat/armrest/shifter.
local shop says nothing is broken and that it was my exhaust hanger, (its not because the exhaust hanger has been without a rubber piece for about 7 months)and the noise had just started a few days ago after a day of heavy driving.
also when my engine mount was broken the same shop said it was not.
let me know what you think and is it possible to replace a tranny mount without a lift or does the trans need to be dropped!
Old July 15th, 2014, 03:42 AM   #557
Anyone know if spare buttons for the key fob can be ordered? Mine are faded and I would like to change them.
Old July 15th, 2014, 06:45 AM   #558
Carpe Diem
ikethegreat's Avatar
The buttons are part of the "guts" of the key so no. You would have to get a whole new key.
Old July 15th, 2014, 11:30 PM   #559
Found it on Amazon.
Keyless Replacement 4 Button Case and Button Pad Compatible with Honda Remotes OUCG8D-380H-A by Discount Keyless http://www.amazon.com/dp/B00L4HJBVW/..._K9FXtb1V558J9
They're cheaper on eBay too
Old July 16th, 2014, 06:59 AM   #560
Carpe Diem
Glad I was wrong. I might have to get one as well, my buttons rubbed off a while ago.
Old July 16th, 2014, 04:54 PM   #561
Yeah I picked this up along with a flip key shell. All I have to do is transfer all the inner guts over and I'll have a brand new key.
Old July 18th, 2014, 12:44 AM   #562
stalloutboy's Avatar
TL-S sway bars or aftermarket?
Sent from my SCH-I535 using Tapatalk
stalloutboy is offline   Reply With Quote Quick reply to this message
Old July 18th, 2014, 04:14 AM   #563
The Jester
Budget choice: TL-S
Customizable choice: Aftermarket
If you haven't upgraded them before, go with TL-S in one of the known pairings so you don't over or under stiffen either end of the car. And save a few hundred.
Be sure to get the polyurethane bushings of matching diameter. Major increase in stiffness.
stalloutboy likes this.
Old July 19th, 2014, 02:54 PM   #564
Someone with an 8th gen is selling their jpipe. I was wondering if the 8th gen jpipe would fit my 7th gen? Did a little research couldn't get an answer. Sorry if this is a stupid question lol
Old July 20th, 2014, 03:05 AM   #565
Did my window regulator just go out? I was rolling up the passenger Window and heard a pop. The window no longer goes up or down, but I can hear the motor.
Edit: Windows regulator cable had snapped.
Old August 7th, 2014, 07:19 PM   #566
Vtec_Sheikhani's Avatar
So i have a 06 v6 auto and i was trying to change the tranny filter and i couldn't seem to fit a ratchet and a socket on the bolt for the life of me it just wouldn't fit. How did you guys manage to fit one down there? I tried every single ratchet/socket combo i could come up with, even tried one of those joint sockets and it wouldn't work.
Vtec_Sheikhani is offline   Reply With Quote Quick reply to this message
Old August 7th, 2014, 09:04 PM   #567
I also tried to remove the ground cable and same issues with trying to fit a socket down there.
Old August 20th, 2014, 02:34 PM   #568
When I gut my pre cats will I throw any codes? If so how do pcds not throw codes or do you just clear them.
Old August 20th, 2014, 03:09 PM   #569
Honda enthusiast
I think it will throw cat codes. I've heard spark plug defoulers can be used with the o2 sensors to fake the ecu.
Old August 23rd, 2014, 12:48 PM   #570
Went to 3in single exhaust and now I'm throwing code p0497? evap system pressure something. Is this common?
Human Verification
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Holaimbrent96
