Small Questions Thread (Search First, Then Come Here) 7G Edition - Page 21 - Honda Accord Forum : V6 Performance Accord Forums
Like Tree20Likes
Old January 28th, 2015, 06:23 PM   #601
05accord6spd's Avatar
Originally Posted by CrackerTeg View Post
What sedan rear lips? OEM/HFP? Doesn't exist. If you're talking about aftermarket, get an aftermarket lip for the coupe. It'll fit better than an aftermarket one for the sedan.
everything aftermarket looks fairly terrible, i was thinking mugen, or what ever you guys with inspire conversions use from the sedan.
Old January 28th, 2015, 07:35 PM   #602
The name is Z
CrackerTeg's Avatar
Mugen or modulo are the ones you're thinking of. Still won't fit right on the coupe though.
Old January 30th, 2015, 08:28 AM   #603
Mr. Detail
Scottwax's Avatar
Is there a full front strut bushing kit for our cars? Or is it a piece meal thing where everything is only available individually? My left front one is going out, lot of clunking lately. Debating whether or not to have just that fixed or bite the bullet and also do a mild drop on my car.
Old February 2nd, 2015, 11:01 PM   #604
Strath's Avatar
What is the exhaust size to the muffler on a 2003 v6 auto ex-l? I've heard it's 2.5", some others say 2.25 and then some say 1.75
This would help me out a lot.
Strath is offline   Reply With Quote Quick reply to this message
Old February 5th, 2015, 07:43 PM   #605
Mr. Detail
Scottwax's Avatar
2.5 to 2.25 seems to be the most accepted size if you stick with duals, single, 3" all the way.
Old February 27th, 2015, 01:51 PM   #606
stalloutboy's Avatar
My clutch randomly got mushy? And it's hard to put into gear when i stop and try to go back into gear. I know that points to the slave/master cylinder but was wondering if the cold could be the culprit? Because it drives fine once I'm already in gear.
stalloutboy is offline   Reply With Quote Quick reply to this message
Old February 27th, 2015, 03:15 PM   #607
I currently have $300 in eBay bucks and am considering purchasing some aftermarket side skirts since I can't find any OEM ones..(03 04 05 Honda Accord Coupe HFP Style Side Skirts 2003 2005 2004 | eBay).
What do you guys think? How much would painting run at a shop?
Millie_13 is offline   Reply With Quote Quick reply to this message
Old February 27th, 2015, 04:31 PM   #608
aka swollpatrol
Wolfy47's Avatar
^^Save your pennies and just look harder. Once you get those flimsy aftermarket ones painted you're going to be close to the same price as already painted oem ones.
Wolfy47 is offline   Reply With Quote Quick reply to this message
Old February 27th, 2015, 04:49 PM   #609
Ok so I went to bleed the clutch and I did all of the steps and no fluid came out when I loosened the bleeder valve?
Old February 27th, 2015, 07:59 PM   #610
But I have $300 in free eBay bucks so essentially I won't be paying for the skirts, just painting. decisions..
Old March 1st, 2015, 12:07 PM   #611
are people still making brackets to install rl calipers. also the bracket to move the rear caliper out more to fit pilot 12.8inch rotor on the rear.
Also is there a upgraded caliper we can swap to the rear?
Old March 2nd, 2015, 10:29 AM   #612
Carpe Diem
ikethegreat's Avatar
RL caliper brackets
Fastbrakes Accord,TSX with Acura RL caliper adapter kit
Rear caliper relocation brackets
Fastbrakes 1998-2007 Accord rear 12" upgrade big brake kit
Old March 2nd, 2015, 12:36 PM   #613
Nice I saw that one for the rear brakes wonder if I call in they will sell just the bracket I don't really want those rotors. Is there still any problems with front rotors not fitting properly leading to shaking. Or was that from people using 350z rotors. Thanks for the links
Old March 3rd, 2015, 07:03 AM   #614
Carpe Diem
I use 350z rotors and they fit fine.
Old April 1st, 2015, 08:20 PM   #615
*scratch that prices seem to have dropped dramatically on tl shawd parts*
*The throttle body was close to 400$ at one point? its listed at 148$ new?*
any ways, whats better zdx or tl shawd 3.7 im.
might match the runner side to some pnp runners.
one is magnesium and ones aluminum right?
Old April 21st, 2015, 06:33 PM   #616
I cant get the hoses off the tb and i pulled seriously hard on them, should i just cut them off?
they will not pull of on both ends meaning from the throttle body or to where they connect to the coolant system.
cant tell if they are factory or not but it looks like i need to cut them.
any help?
Old April 22nd, 2015, 02:57 PM   #617
any help?
Usually when I'm having trouble removing stubborn rubber hoses from steel nipples a pair of pliers will break them loose. Grab onto the rubber tube where it overlaps the metal nipple and twist the rubber like you're trying to unscrew it. Usually you can get enough force to break the bond/seal, and then you can pull it off.
Good luck!
Joe
'06 Accord Coupe EX-L V6-6MT - Alabaster Silver Metallic
'06 CR-V EX-AT - Nighthawk Black Pearl
Previous Hondas
'83 Accord Hatchback
'96 Civic Coupe EX I4-5MT - Milano Red (Love this color!)
'98 Accord Sedan EX I4-5MT - Taffeta White
'01 Accord Sedan EX I4-5MT - Naples Gold Metallic
jfuredy is offline   Reply With Quote Quick reply to this message
Old April 23rd, 2015, 09:33 AM   #618
Calm like a bomb
StevilKnievel's Avatar
any help?
1 drop of pb at the end of the hose where it touches the piping. Slides right off. Had to do the same thing last week.
Old April 23rd, 2015, 06:26 PM   #619
does the tl shawd top plate come with a gasket or do i need to order one for my im thats coming in the mail.
Old May 7th, 2015, 01:02 PM   #620
What's the best for the price gasket set? Replacing heads on my car and figured Id do all of the gaskets when I have everything off.
Old May 12th, 2015, 09:14 AM   #621
I'm Deleting the breather tube and I'm wondering what size double sided nipple/barb I should get for the colant line that runs with the tube and for the 3.7tb collant line delete.
Old July 17th, 2015, 12:06 AM   #622
aka swollpatrol
Wolfy47's Avatar
Does anyone know off hand if there is any SRS equipment other then the buckle on the drivers side side airbag equipped EX?
Old July 18th, 2015, 08:37 PM   #623
Mr. Detail
Scottwax's Avatar
Is your SRS light staying on? Easy way to figure out if it is the buckle that is the problem. Put your seatbelt on first, if the light doesn't stay on after starting the car, the problem is the buckle and since it is part of the seatbelt system, Honda warranties it for the life of the car.
Old August 24th, 2015, 10:14 AM   #624
Ok I'm getting an APP sensor code and I can feel subtle shaking under acceleration. I was about to replace the part until I remembered that I removed my butterfly valve actuator and then reinstalled it but I'm not sure if I lined the gears up correctly when I put it back on. Could this possibly be causing my app sensor code? And if it is how do I correctly install the butterfly valve actuator?
Sent from my VS880 using Tapatalk
Old August 25th, 2015, 10:58 PM   #625
Nothing??
Old August 25th, 2015, 11:07 PM   #626
JDM UC1
toinkee69's Avatar
nothing, figure it out yourself. lol.
Old August 25th, 2015, 11:20 PM   #627
Your parents didn't love you as a child did they?
Old September 17th, 2015, 03:26 PM   #628
Nam
nanana's Avatar
Cruise button stop working for no reason. Click on it, the light shows, but as soon as I let go, it turns itself off. Anyone with the same problem?
nanana is offline   Reply With Quote Quick reply to this message
Old November 11th, 2015, 06:57 PM   #629
http://www.ebay.com/itm/2007-ACURA-T...lVMmZT&vxp=mtr
do we have this on our cars? ive never noticed one before.
Old December 18th, 2015, 01:12 PM   #630
Headlight Issue
Sometimes when I turn my headlights on, one of the low beams stays off.
If I turn the headlights off and on again, most times I can get both lights to come on.
I purchased the car a month ago and the PO had Silverstars in in the low beams.
Any ideas?
Thanks!
fadumpt is offline   Reply With Quote Quick reply to this message
Human Verification
