any tips/recommendations before installing TL-S sway bars? - Honda Accord Forum : V6 Performance Accord Forums
Old May 27th, 2017, 04:01 PM   #1
picked up everything based on the sticky Threadon DA.net:
Front Sway (27.2mm): TL Type-S 6MT (solid)
51300-SEP-A21 - SPRING, FR. STABILIZER - 1x
51306-SEP-A01 - BUSH, FR. STABILIZER HOLDER - 2x
51308-SDA-A00 - BRACKET, FR. STABILIZER - 2x
Rear Sway (20mm): TL Type-S 6MT (use this if you ARE upgrading the front sway bar)
52300-SEP-A11 - SPRING, RR. STABILIZER - 1x
52308-S3M-A00 - HOLDER - 2x
52306-SEP-A11 - BUSH, RR. STABILIZER HOLDER - 2x
also, got a DC Sports Front strut bar. actually saw DreaminAccord selling his engine cover and really liked his
i will be installing Front Strut Bar myself as it pretty simple and i've done them in the past on other cars
the Front/Rear Sway Bars will be installed when i get my Compliance Bushings done soon. The front one will be free and rear will be $60 totaling about $600ish
do i have everything i need? are there any greases, lubricants that i'm forgetting that isn't included? thanks in advance for your help
BTW, if anyone wants to know what i paid in 2017 since there are a lot of people who did this many years before, will gladly take a pic of what i paid in CO
Old May 27th, 2017, 08:26 PM   #2
That's awesome! I'm about to buy a used TL-S Rear sway. Waiting on a used front one to show up. either on the forums or in the junkyard
LTFA182 is offline   Reply With Quote Quick reply to this message
Old May 27th, 2017, 09:22 PM   #3
I would grab these rear sway bar links with your TLS bars. Nice buy.
https://www.heeltoeauto.com/fastline...links_cl9.html
AccordFire is offline   Reply With Quote Quick reply to this message
Old May 27th, 2017, 09:24 PM   #4
Does that strut bar fit a 3.0 6 speed coupe? I want.
Old May 27th, 2017, 09:27 PM   #5
Forget the compliance bushing. Get a whole new control arm:
https://www.heeltoeauto.com/camber-k...har.6979..html
Old May 28th, 2017, 08:03 PM   #6
If you need to replace the compliance bushing, get these:
https://www.heeltoeauto.com/bushing-...ring.pr.1.html
Old May 29th, 2017, 12:08 AM   #7
Mr. Detail
Scottwax's Avatar
Had the same set-up on mine (including the DC Sport FSB) and after several months ended up getting the Progress 24 mm rear bar to stiffen the rear even more and reduce under steer. Rotates almost as well as my G35 (Hotchkiss bars on it) does.
But compared to stock the TL-S bars are a big upgrade.
Old May 30th, 2017, 08:31 AM   #8
...how much did you pay?
Old June 6th, 2017, 07:07 PM   #9
thanks!...good luck with your Search TLS Sway Bars are hard to come by in CO.
appreciate it, i'll look into it after i get the bars installed
from what i read, 4 Door and 2 Door is different and not interchangeable
i'll look into it after i get the bars in but from what i've read, the Sway Bars make a huge improvement which is what i'm hoping for...if i had enough to grab these...i would probably look into another performance upgrade 1st probably
i'm gonna stick with OEM on this one but thanks!
Old June 6th, 2017, 07:18 PM   #10
i'll have to consider that Scottwax...Hotchkiss makes some great suspension parts...had them on my old ride and was happy with them
long story short, there's 4 Acura dealerships within Denver area...i checked with the 2 biggest and decided to go w/the 2nd since they were:
$132.10 savings...both offered a 10% discount and i would recommend asking because it never hurts
Old June 11th, 2017, 03:32 PM   #11
Mr. Detail
Scottwax's Avatar
Hard part is dropping the back of the subframe to remove the front bar and put in the new one. Rear one is pretty straight forward.
Debating adding adjustable end links to mine.
Human Verification
