Drive Cycle.. 2003 Honda Accord Coupe v6 EX - Honda Accord Forum : V6 Performance Accord Forums
Old August 9th, 2007, 05:59 PM   #1
KSU Owls
Clemson538's Avatar
Send a message via AIM to Clemson538
So i had a load of work done on the infamous transmission.. picked it up today.. took it for emissions.. and it failed because it said the OBD was not ready to determine the pollution stuff.. And that it needs to go through a Drive Cycle before it can determine this.. Does anyone no how many miles our Drive Cycle is so i can put some miles on it and get it back to emissions.. since its up Aug 23.. Much Appreciated
Clemson538 is offline   Reply With Quote Quick reply to this message
Old August 9th, 2007, 07:56 PM   #2
original member!
Nittanys1's Avatar
100-500 miles?
Old August 9th, 2007, 08:09 PM   #3
KSU Owls
Clemson538's Avatar
Originally Posted by Nittanys1 View Post
100-500 miles?
anything less broad.. i was hopin like 75.. i look in the manual and searched the net but nothing
Old August 9th, 2007, 08:10 PM   #4
original member!
Nittanys1's Avatar
just keep driving the car around...im not sure on the amount you will need...
Old August 9th, 2007, 08:28 PM   #5
Andrew's Avatar
I would agree with the above 100-150 miles, during a drive cycle certain criteria and conditions have to be met and tests have to be completed.
Andrew is offline   Reply With Quote Quick reply to this message
Old August 9th, 2007, 08:37 PM   #6
KSU Owls
Clemson538's Avatar
Alright.. I'll put some city and highway miles on it tomorrow.. gotta get it retested soon..
Old August 9th, 2007, 09:43 PM   #7
I feel da need 4 6-speeds
flyvtec's Avatar
I'm thinking full to empty gas tank is a drive cycle.
Old August 10th, 2007, 04:51 PM   #8
Andrew's Avatar
Well a full drive cycle really depends on how long you drive the car in a trip, once the car meets certain enabled criteria and certain conditions and tests have to be run and completed. It usually takes 3 trips, the car has to reach operating temperature each time and then shut off and then repeated two other times. And once this is done a drive cycle is completed, it all depends on how much and how long you drive a day.
Old August 10th, 2007, 05:42 PM   #9
honda tech75
juan gonzalez's Avatar
Send a message via AIM to juan gonzalez
he is right . it could take one day or a year. it has to meet a certain criteria it could depend were u live climate.
juan gonzalez is offline   Reply With Quote Quick reply to this message
Old August 10th, 2007, 08:23 PM   #10
Pilot & Accord
TonyWare's Avatar
Found this by googl-ing "drive cycle", hope it helps:
Most OBD II ("On-Board Diagnostics II") diagnostic monitors will run at some time during normal operation of the vehicle. However, to satisy all of the different Trip enable criteria and run all of the OBD II diagnostic monitors, the vehicle must be driven under a variety of conditions. The following drive cycle will (theoretically) allow all monitors to run on (??) vehicle. (Note: Drive cycle specifics vary by vehicle!)
  • Ensure that the fuel tank is between 1/4 and 3/4 full.
  • Start cold (below 86F /30C) and warm up until engine coolant temperature is at least 160 F (typically requires at least one minute; up to 3 minutes).
  • Accelerate to 40-55 MPH at 25% throttle and maintain speed for five minutes.
  • Decelerate without using the brake (coast down) to 20 MPH or less, then stop the vehicle. Allow the engine to idle for 10 seconds, turn the key off, and wait one minute.
  • Restart and accelerate to 40-55 MPH at 25% throttle and maintain speed for two minutes.
  • Decelerate with using the brake [or the clutch!] by coasting down to 20 MPH or less, then stop the vehicle. Allow the engine to idle for 10 seconds, turn the key off, and wait one minute.
TonyWare is offline   Reply With Quote Quick reply to this message
Old August 10th, 2007, 11:32 PM   #11
KSU Owls
Clemson538's Avatar
Cool ill try it.. thanks guys.. sounds tedious lol..
Old August 13th, 2007, 11:26 PM   #12
KSU Owls
Clemson538's Avatar
well i put about 100 miles on it.. bout 70 highway.. 30 city.. took it for emissions today.. and it passed with no problems.. thanks for the input guys!
Human Verification
