Eibach Prokit published stats - Honda Accord Forum : V6 Performance Accord Forums
Go Back   Honda Accord Forum : V6 Performance Accord Forums > CAR SPECIFIC DISCUSSION > 8TH GENERATION HONDA ACCORD (2008-2012) > 8G HONDA ACCORD WHEELS, TIRES, & SUSPENSION DISCUSSION
Old February 5th, 2008, 01:48 PM   #1
J35Z3,J37A1,C32B,F20C
JimK's Avatar
part number 4076.140. From Eibach's site: 1.2 inch drop front, 1.0 rear.
(ordered mine today from Summit $247.39, they are a back-order item there as well as Jegs, probably 3-4 weeks)
JimK is offline   Reply With Quote Quick reply to this message
Old February 5th, 2008, 04:36 PM   #2
250 isn't bad at all hopefully ill order a set soon all i have to do is find a good installer in my area, do my fellow new yorkers know of a place?
kpulse is offline   Reply With Quote Quick reply to this message
Old February 5th, 2008, 07:31 PM   #3
Ignition_key's Avatar
Send a message via Yahoo to Ignition_key
So Im assuming this is purely for looks? Will it give any performance benefits to the Accord?
Ignition_key is offline   Reply With Quote Quick reply to this message
Old February 6th, 2008, 06:56 AM   #4
JimK's Avatar
70% looks, 30% performance. Lowering springs will result in less body roll and nose dive and better aerodynamics at high speed.
Old February 9th, 2008, 05:29 AM   #5
You cant lower it to 1.5" from the front?
Old February 9th, 2008, 01:30 PM   #6
JimK's Avatar
H&R Sport springs #51856 1.5" drop front, 1.3" back.
Old February 9th, 2008, 02:31 PM   #7
Hank4444's Avatar
Send a message via AIM to Hank4444
How much space between the body and wheel on the Eibach Prokit? Pictures yet?
Hank4444 is offline   Reply With Quote Quick reply to this message
Old February 9th, 2008, 11:45 PM   #8
jnguyen is offline   Reply With Quote Quick reply to this message
Old February 9th, 2008, 11:46 PM   #9
Old February 9th, 2008, 11:48 PM   #10
I think if you want to run 20's the eibachs are good..if you want 19's then I would go H&R
Old February 12th, 2008, 01:49 PM   #11
bowman96's Avatar
jnguyen or anyone, how is the ride quality any different w/ your springs, which are you running? Does it look like it affected the camber or anything else?
bowman96 is offline   Reply With Quote Quick reply to this message
Old February 13th, 2008, 08:00 AM   #12
JimK's Avatar
I had Eibach Prokit on my '03 (main reason I've ordered them for my '08). I don't think ride quality suffered at all and I stayed with the stock shocks. You will need to have the wheels aligned and cambered adjusted. I had some slight visible negative camber but tire wear was pretty even. I expect my experience with the '08 will be similar. My springs won't arrive until March.
Old February 13th, 2008, 09:37 AM   #13
Question
Where could this be done? And how much does it run?
Also will this affect warranty on car?
Old February 13th, 2008, 12:09 PM   #14
JimK's Avatar
almost any shop that regularly does alignment and suspension work. I spent about $350 last time. It will not affect warranty on the car unless one of your oem shocks fail which is highly unlikely with a modest drop and a high-quality progressive rate spring like Eibach Prokit.
Old February 15th, 2008, 07:50 AM   #15
bowman96's Avatar
HFP suspension?
Not to get off the eibach chat too much but does anyone know wether there is going to be HFP suspension for the sedans? I have seen a couple of posts about it, just wondering if anyone has any solid intel about it coming out or not?
Old February 16th, 2008, 08:23 AM   #16
JimK's Avatar
HFP springs for the coupe will be out in April, I'm told. Not sure why you couldn't put them on a sedan. Drop will probably be about .8" so I suspect they'd work OK.
Old February 27th, 2008, 09:59 AM   #17
JimK's Avatar
still waiting for my Eibach's...anybody gotten their's yet?
Old February 29th, 2008, 05:39 AM   #18
Sonny's Avatar
I'm hoping K/W comes out with a coil-over kit or maybe H&R
Sonny is offline   Reply With Quote Quick reply to this message
Old February 29th, 2008, 06:54 AM   #19
JimK's Avatar
got apost-card from Summit, ship date for Eibach's pushed back to 3/11....
Old February 29th, 2008, 12:23 PM   #20
do the new accords need a camberkit?
popdakebin is offline   Reply With Quote Quick reply to this message
Old March 4th, 2008, 01:47 PM   #21
helloooo buddyyy
mrjhnguyen's Avatar
Send a message via AIM to mrjhnguyen
wondering if the push date is the same for the sportlines. or is the prokit the only springs they have so far?
mrjhnguyen is offline   Reply With Quote Quick reply to this message
Old March 4th, 2008, 04:26 PM   #22
JimK's Avatar
I believe I read that somewhere. The Prokit on my '03 did not.
I don't know if Sportlines are even available yet. I looked at clearance of the upper A-arm, it's gonna be tight with a drop, especially with more negative camber. I wonder if that's why the delay in releasing the springs. we'll see....
Old March 10th, 2008, 12:13 PM   #23
bowman96's Avatar
Anybody have pics of sedans lowered on 19's yet? If you know please leave any info about the mods (H&R, Eibach, etc.) Any pics would be appreciated.
Thanks
Old March 20th, 2008, 07:10 AM   #24
JimK's Avatar
revised ship date: first week of April.
meanwhile, collegehillshonda.com has the HFP suspension, looks like it is springs and shocks.
Old March 31st, 2008, 02:30 PM   #25
2GR-FSE
i want to see better pics of this.. my friend wants this
HPSPower is offline   Reply With Quote Quick reply to this message
Old May 4th, 2008, 01:40 PM   #26
Senior Member
chaqui74's Avatar
Is that Accord still in the new lot and its already lower?
Originally Posted by jnguyen View Post
Old June 7th, 2008, 07:14 AM   #27
TranceField's Avatar
Look good... I should have some pix of my Accord with 20inch rims and the Eibach lowering springs... got the springs for 222.00 :P
TranceField is offline   Reply With Quote Quick reply to this message
Old June 17th, 2008, 12:06 AM   #28
Im lookin' into the Eibach springs as well as 19" Stern ST-1 BLACK. (19x8.5 front & 19x9.5rear). That drop is sick tho.....
Kkerns281 is offline   Reply With Quote Quick reply to this message
Old June 17th, 2008, 12:07 AM   #29
Trance- where did you pick up the eibachs from for $225? did that include S&H?
Old July 26th, 2010, 07:06 PM   #30
kkerns,got a pic of this set up?
Flyin' Taco is offline   Reply With Quote Quick reply to this message
Human Verification
