Go Back   V6 Performance.net Forums > CAR SPECIFIC DISCUSSION > 6TH GENERATION HONDA ACCORD (1998-2002)
Register FAQ Members List Calendar Mark Forums Read
Advertise on V6P.net
Thread Tools Display Modes
Old October 1st, 2009, 08:48 PM   #1
MikeyMikeCG2
3.5L s/C'd 6 Speed
MikeyMikeCG2's Avatar
Trader Rating: (0)
Send a message via AIM to MikeyMikeCG2
p0505 Idle Control System Malfunction
it seems since the swap, i fix 1 thing, something else becomes a malfuction
car jumps from 1,000 rpm-2,000 rpm on a slow rev/drop pattern..
should i straight up replace idle control sensor on the throttle body or could cleaning it possibly help?
♠ F**K the Rainbow ♠ 3.5L Six Speed SuperCharged Accord ♠ lol @ traction ♠
MikeyMikeCG2 is offline
Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Google Submit to Yahoo! This Submit to Technorati Submit to StumbleUpon
Old October 1st, 2009, 08:54 PM   #2
shonda1989
hmmm what next?
shonda1989's Avatar
Trader Rating: (2)
check for a vacuum leak in the hoses and by the vacuum connector. then clean the IAC also check the TB butterfly valve for debris.
shonda1989 is offline   Reply With Quote
Old October 1st, 2009, 08:56 PM   #3
6thaccord98
Trader Rating: (0)
you can clean it and may be help but after you clean it try to test the AIV is it fail or no.
6thaccord98 is offline   Reply With Quote
Old October 2nd, 2009, 03:39 AM   #4
NVA-AV6
M90SC Boosting 13PSI
NVA-AV6's Avatar
Trader Rating: (15)
Shonda is right on, check for any vacume leaks first. There is also a adjusting screw on the TB that you might have to tighten a little bit more.
NVA-AV6 is offline   Reply With Quote
Old October 2nd, 2009, 03:51 AM   #5
Accord_V6_400m
yaaaaaaaaaaaaaaaaaaaaaay!
Accord_V6_400m's Avatar
Trader Rating: (23)
Just check for leaks, get news gaskets for everything so TB gasket IACV gasket, possibly IM gasket too, but doubt its the problem. maybe you switched the plugs on the sensors? The TPS and MAP sensor plugs are interchangeable and don't throw up a CEL when switched up at least most of the time it doesn't. The MAP sensor has the grey plug going to it and theblack one is the TPS sensor.
If you think its the IACV try taking the intake off and pluging up the hole for the IACV and see if that affects anything.
In general I would clean out the IACV too just to be on the sure side.
Accord_V6_400m is offline   Reply With Quote
Old October 4th, 2009, 09:58 AM   #6
honda98accord
Trader Rating: (0)
I also left my intake air temp sensor unplugged after working on my car one day and it caused this exact same code and problem. Don't ask why that would happen but i plugged it back in cleared the code and it fixed the problem. So maybe check and make sure there isn't a broken wire there or that the sensor is malfunctioning.
honda98accord is offline   Reply With Quote
Old October 4th, 2009, 05:34 PM   #7
MikeyMikeCG2
3.5L s/C'd 6 Speed
Trader Rating: (0)
any chance this could be cause by bad gas?
I ask because a friend of mine has an 09 civic. he lives in the same apartment complex as me and we use the same gas station, both 93 octane.
and his car does the EXACT same thing now..
possibility its the gas? or just coincidence?
MikeyMikeCG2 is offline   Reply With Quote
Old October 4th, 2009, 06:09 PM   #8
NVA-AV6
NVA-AV6's Avatar
Trader Rating: (15)
Very good possibility.....
Old October 5th, 2009, 12:14 AM   #9
jbisselwhiteav6
jbisselwhiteav6's Avatar
Trader Rating: (0)
I am having a similar problem after doing my swap so I wonder
jbisselwhiteav6 is offline   Reply With Quote
Old October 29th, 2009, 09:45 AM   #10
Icedragon
Trader Rating: (0)
I occasionally have the same idle problem, but without the CEL. Have you guys found a solution?
Icedragon is offline   Reply With Quote
Old November 14th, 2009, 03:04 AM   #11
v6powerice
Banned
Trader Rating: (0)
dam
v6powerice is offline   Reply With Quote
Old November 20th, 2009, 12:33 PM   #12
accordv6_619
Trader Rating: (1)
i have the same problem after chargeing a fuel injector
accordv6_619 is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
