| Register | FAQ | Members List | Calendar | Mark Forums Read |
Thread Tools | Display Modes |
#1 |
99% OEM
Cut Open Magnefine Transmission Filter (PICS)
Well after I changed my tranny filter today, I decided to cut the old one open to see how effective or necessary it really was. This was the first tranny filter installed on my car at 31K along with a tranny cooler and tranny fluid change. It was placed after the cooler but right before the oil goes back into the tranny. Now my car has 58,800 miles. Here are pics of inside the filter after about 28K miles.
The Magnefine filter consists of 3 parts: ![]() I actually didn't know it had another paper filter element other than the advertised magnetic filter. Was it brown when it was new? (Note that the black chunks on top are just plastic shavings from me cutting the filter). ![]() And now the good stuff... The top part of the filter is magnetized. As you can see, it has attracted a lot of metal shavings from the tranny fluid. (Again note the large chunks of black you see are just the plastic shavings from me cutting through the filter). Look at all the fine metal shavings stuck to the magnets! ![]() ![]() ![]() ![]() Well, there you have it folks! I guess it really wouldn't hurt to have a tranny filter. Otherwise all that junk would be going right back into your tranny! Magnefine claims you should change the first filter at 15K miles, and then every 30K miles thereafter. However, seeing at how this filter looked at 28K miles, I think it could have gone a little longer. Magnefine claims that these filters have a safety by-pass feature which allows fluid to "by-pass" the filter just incase it becomes clogged. So there's nothing to worry about. After opening this filter up, I like the Magnefine filters even more. Not only do you get the paper element filtration of the Perma-Cool filters, but you also get the extra magnetic filtration that finely separates metal shavings in the tranny fluid. The filter is designed so the tranny fluid goes through the magnetic filtration first, then through the paper filter element. Last edited by wcbcruzer; September 4th, 2005 at 07:48 PM.. |
#2 |
Banned
when i get a complete fluid drain and flush about 120$service cdn. funds...do they rplace the stock tranny filter??? how bout if theres excessive atfz tranny fluid? is that hurting my already weak tranny? i think they put in too much fluid...reading is way above the 2 notches...thanx if u can rply
#3 | |
99% OEM
How many miles do you have on your car? I was going to do a complete tranny flush myself for $150. However, I happened to call the Honda dealer and the service tech. told me that it was just another way of dealerships ripping you off. He said that you really don't need to do a "flush." He said just do a drain and refill every 15K miles and you will be fine. If your fluid is really dirty, I would just keep changing it out every 2-3K miles until it begins to get clean. It costs about $16 to do a drain and refill yourself and it's easier than changing the motor oil! Our cars don't have a stock tranny filter. The only thing we have is a magnetic oil drain plug in the tranny and when you take that out you'll see how much metal shavings it attracted. You shouldn't have excessive tranny fluid, or any type of excessive fluid for that matter. To check your fluid, have the engine hot but not running and make sure you parked on a flat surface. If there's too much. Just grab a 3/8" ratchet and put a oil drain pan under your tranny and drain some fluid out. Do a little at a time! And keep checking the fluid level as you go. By the way, I tell everyone this... Please take the used oil to Autozone or Wal-mart to drop off. Don't pour it in the dirt behind your shed in your backyard! Here is the tranny fluid drain bolt on the v6. ![]() Last edited by wcbcruzer; September 4th, 2005 at 11:05 PM.. |
#6 | |
V Go SoCal Drivers V
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#7 | |
#8 |
99% OEM
Yeah, if you look right above the tranny dipstick, there is a light bronze colored bolt (it's pretty big bolt) that says "ATF." From the factory they're torqued pretty tight though, so you might want to have a breaker bar handy to open it. I circled it in this pic:
#13 |
wcbcruzer: some guy on v6p bought magnets then put it onto a metal strip and wrapped it around his tranny filter. I totally forgot about it until you brought up your magnefine tranny filter that has a built in magnet =).
#15 | |
, bought it online the strongest magnet in the world lol it's called Neodymium-Iron-Boron bought it off this site here: neodymium magnet it should work =), since the magnet is super strong dun dun dun |
#16 | |
"TEAM ANO??? TEAM PAKSIW!!!" .::TP-CG2::. JDM Theory::MemoryFab To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#17 |
upgraded intake system
would you guys recommend this magnefine filter? or the b&m remote filter? which one is better? i'm leaning towards the magnefine because it's got the built in magnet to attract the metal shavings.
#18 |
99% OEM
If you read my first post in this thread, you'll know that I recommend the Magnefine. Perma Cool, B&M, etc. filters are good too. But in my opinion, the Magnefine is just much easier to install, takes up less space, and offers better filtration. But with the Perma-cool, it has a port where you can install a temp. gauge. So it's more convenient.
#22 | |
99% OEM
Check out this thread. I added some pics of where I installed my filter (last page). http://www.v6performance.net/forums/...596#post755596 Last edited by wcbcruzer; September 7th, 2005 at 11:32 PM.. |
#23 |
yea, i saw that earlier today, searching through v6p =). I'm thinking about buying the magnefine, but i already have the relocated filter mount in place. So i'm going to try the external magnet *shrugs* should work.
edit: and thanks for cutting the filter up lol, at least the filter is doing the job! ![]() |
#24 |
Something Something Darkside
Nice post.
#26 |
Banned
dam i shud get my magnefine filter installed ! its just sitting in my room ...i only go the BM tranny cooler installed(no inline filter) ....just the clogging issue worries me... i shudder to think how much metal shavings i'd get!!!
#27 |
inline filter cut open??????????
wow dont know where to start, after readig the thread about cutting open an inline filter i had to say something. that was a picture of a magnefine filter assembly and he spent the time to cut it open. sorry to let you know alice but if you use a little elbow they unscrew at the top actualy about 2mm up from where it was cut. then you can clean them out and reuse, or you can just back flush them and hope for the best. as far as people talking about extra magnets in the pan did you know that presure and shift solinoids contain magnets in them. not a bad idea but for youre own good keep them away from the solinoids it could cause disruption and eventualy burn up a clutch pack.
i like the magnefine filter set up, easy to install, easy to clean, the best part is the fact that when they get restricted the plastic "spring/tentioner" lets the fluid countinue to flow. the only thing i dont like is that there is no way to tell when it is restricted. ford requires an inline filter installed after every transmission overhaul or replacement, the ford filter costs about 75-85 dollars funny thing is if you pull the ford sticker off of it it says magnefine, and you get the exact same filter for about 10-12 dollars online. that for the complete cartridge i am stll trying to find the filter by its self it cant be more than 5-8 bucks. |
#29 |
From their website:
Magnefine In-LIne Filter Magnefine Filter Qty: Price: $16.00 Size: 3/8", 5/16", or 1/2" Smart Connects: 3/8", 5/16", or 1/2" Note: "Smart Connect" fittings are only suggested if a hose section is not available for installation or if you are doing a hard line install.. So what size fitting is needed for a 2000 AV6? The High Performance model gots an optional bracket. Anyone done the Magnefine Transmission Filter lately or will be doing it? I wanna see how it looks in the engine bay or relocated to a good spot. |
#30 |
I would like to do this to a 7th Generation.
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
