Header install on a 4cyl 5th Gen? - Honda Accord Forum : V6 Performance Accord Forums
Go Back   Honda Accord Forum : V6 Performance Accord Forums > CAR SPECIFIC DISCUSSION > 5TH GENERATION HONDA ACCORD (1994-1997) > 5G HONDA ACCORD 4-CYL GENERAL DISCUSSION
Old February 21st, 2007, 11:12 AM   #1
SIR Bound....Slowly
Thundagoose's Avatar
I picked up some DC Sports header for my 5th gen EX and im reading through the intructions it came with and i look under the car and the hood and they are nothing alike.. the kit says i need to move my oxygen sensor but it doesnt come with the relocation harness and there is no bolt up for a o2 sensor on the new headers.. im thinking the o2 sensor is on the cat itself and all i gotta do is unbolt the header from the cat, and from the block and that should be it.. Can anyone verify this? sounds like this install shouldnt take more than 10 Min
Thundagoose is offline   Reply With Quote Quick reply to this message
Old February 21st, 2007, 02:37 PM   #2
(つ◕‿◕)つ*.★.*.★.* .★.
Red02AccordV6_2's Avatar
Headers will take about 45mins for a 4cyl. The O2 sensor is about 9 inches foward (towards the front of the car) from the cat. When you remove your header, you'll have to disconnect the wiring for the o2. If you have long arms, you can disconnect it from the top. That's all I remember from when I help my friend swap headers on his h22.
Old February 21st, 2007, 02:45 PM   #3
SIR Bound....Slowly
ok ive been under the car, almost got the header off but i didnt have socket long enough to unbolt the downpipe from the catpipe.. the o2 sensor is like you said about 9in from the cat but it turns out i am unbolting the pipe that connects right before the o2 sensor so i dont have to mess with the o2 sensor at all.. My only concern is getting the manifold out of their with the stock downpipe cause the bolts that connect the manifold to the downpipe are on the the bottom side and can not be reached so im hoping i can just jog the whole manifold/downpipe out of the engine bay while still bolted together..
Old February 21st, 2007, 07:05 PM   #4
CG5
ccordex00's Avatar
Send a message via AIM to ccordex00
-unplug the o2 sensor
-remove the heat shield
-carefully remove the cable that goest thru the hole of the heatshield
-undo the o2 sensor be carefull not to bang it
-use some wd40 to undo the bolts that hold the stock header
-undo the bolts (make sure you don't remove all the bolts from the headers ) that connect the header (oem) with the downpipe
-after you undo the downpipe/header section remove the remain bolts from the oem header (keep the gasket you will reuse it)
-remove the bracket that hold the o2 sensor cable
-go under the car and remove the remain bolts that connect the header and the cat
-bolt you header and plug the extension to the oxygen sensor at the end of the header (i think they come after the flex pipe, before the catback)
-some people compain about a weir sound after installing the header it just happened to be the cat converter heatshield ...bang it a lil' so the sound won't bother u
-that's it!
ccordex00 is offline   Reply With Quote Quick reply to this message
Old February 21st, 2007, 11:11 PM   #5
SIR Bound....Slowly
well.. thats what my instructions say that came with the headers lol.. But i dont have that setup.. Im having a very hard time doing this.. most of my bolts are completelty frozen (Would need a torch to take off) and ive broken 3 sockets lol.. the 10 min job i thought it was gonna be earlyer is now a 9 hour+ job lol.. stupid bolts
Old February 22nd, 2007, 08:46 AM   #6
SIR Bound....Slowly
Ok.. So this morning i went to home depot and rented a sawzall grinder and chopped the secondary pipe in half so i could pull out the old manifold.. After that the instalation went really smooth.. So now here's my new problem.. I started the car up..took it out for a test drive and when i accelerate the exhaust sounds like its going directly into a tin can instead of the stock exhaust.. I know everything is tightened up but this thing sounds terrible.. Anybody have any ideas on what could be the problem? if there is one?
Old February 22nd, 2007, 12:44 PM   #7
SIR Bound....Slowly
ok.. went down to the muffler shop and it turned out to be a leak .. they put in a gasket and it runs great now
Old February 23rd, 2007, 12:46 AM   #8
CG5
ccordex00's Avatar
yep do it one and do it right sometimes exhauts parts get very tricky. Last week my exhaust gasket looked like a swiss cheese....make sure you get some gaskets handy in case something happen'
Old February 26th, 2007, 03:08 PM   #9
SIR Bound....Slowly
Figured id post some before and after shots
Before
After
Old March 6th, 2007, 10:46 AM   #10
hotaccord243's Avatar
Send a message via AIM to hotaccord243 Send a message via MSN to hotaccord243
It looks nice, btw, i had to do the same thing when i installed my headers in ages ago, it sucked but it seemed to be the only way to do it, like you said
hotaccord243 is offline   Reply With Quote Quick reply to this message
Old May 8th, 2007, 10:36 PM   #11
I was looking at the same headers... but, which ones are better and why?
DC Sports Headers Brushed Stainless Header 4-2-1 Two Piece
OR
DC Sports Headers Ceramic Header 4-2-1 Two Piece
21172 is offline   Reply With Quote Quick reply to this message
Old May 9th, 2007, 09:44 AM   #12
SIR Bound....Slowly
I dont think one is better than the other. On the stainless steel header, a lot of people use those for show, but the flange on it rusts really bad and the stainless from what I hear heats up the engine bay a lot more . The ceramic I think is still a good look, keeps things cooler a little under the hood, and doesnt rust anywhere on it
Old May 10th, 2007, 02:55 PM   #13
So how would it be a different amount of heat since the OEM looks the exact same? Isn't it stainless too? I'm weary about the ceramic cause of temp differences as far as weather goes and the possibility of cracking. I guess I'll go and get those SS Headers. Thx 4 the advise.
Old May 11th, 2007, 12:46 AM   #14
SIR Bound....Slowly
the stock manifold is cast iron.. not stainless steel
Old October 14th, 2007, 12:45 PM   #15
x3
crazybluecivic is offline   Reply With Quote Quick reply to this message
Old October 14th, 2007, 12:46 PM   #16
nice bay
