a/f gauge installation - Honda Accord Forum : V6 Performance Accord Forums
Old January 4th, 2004, 10:10 AM   #1
What color is the o2 senor wire that goes to the ecu? and where is the ecu? driver side next fuse box?
Old January 4th, 2004, 11:42 AM   #2
ecu is under the carpet on the passenger side kick panel. As for the o2 sensor, I cant help. I would say, check the haynes manual.
laststarburning is offline   Reply With Quote Quick reply to this message
Old January 4th, 2004, 09:24 PM   #3
I dont see why it should be very much different, but the O2 sensor should be right before the cat. Follow the wires up to a wheather-pac connecter. Peel the plastic back a little and you want to splice into the WHITE wire. You probably have 4 wires, but the white is the right one.
I dont have a 5g, but thats how my 6g is. Most H/A are the same anyway.
r.j-lo is offline   Reply With Quote Quick reply to this message
Old January 5th, 2004, 03:03 AM   #4
kick panel is the panel that u put ur foot on when in the car?
Old January 5th, 2004, 03:17 AM   #5
yes. my car o2 sensor wire is white also. Just checked manual. If I were to locate the ecu, will the white o2 wire be connected to the ecu?
Old January 5th, 2004, 11:03 AM   #6
Shifting 5 Gears Baby !!
cowgodv6's Avatar
the ECU is where the passengers lie their feet
not the floorboard /
the kick panel is right underneath the glove box
you'll need a screw driver and a wrench
you have to pull back the carpetting like 2.5 feet back
there are like 10-12 bolts
good luck
My Rides :
95 Accord EX-R V6 ( C27M5 ) 5 Speed feels so good !!!
93 Civic Si Coupe ( D16Z8 )
92 Civic LX 4 door Winter Beater - Wife`s winter car (scrapped)
92 Accord EX - Winter Beater
Old January 5th, 2004, 11:07 AM   #7
cowgodv6's Avatar
to short the ECU to get or clear the codes, there is a plastic clip right underneath the glove box ... mine was orange ( not green like most manuals say )
- have the car off -
- short it out with a paperclip and turn on the ignition after
- count the amount of check engine flashes
as for the O2 sensor, you have to jack up the front end of the car to get to it ... most of the time there is a little built up of crap in the connector - just clean it and you should be fine ...
if not and you need to replace the O2 sensor, it's a very heavy cost
Old January 5th, 2004, 03:10 PM   #8
My question is where is the o2 sensor located inside the car. The white wire must be connected to something in the cabin. I already know where the o2 sensor is outside.
Old January 8th, 2004, 09:27 PM   #9
Couldnt tell you for sure. If you have a Helms or a Haynes manual, you can follow the schematic back to see where it goes, but I just did mine in the engine bay.
Old January 11th, 2004, 01:50 PM   #10
how to do you remove the passenger side crapet near the ecu? I got all the fastener out but the carpet still won't come out because it seems like it is connected to the driver side around the console.
Old January 11th, 2004, 03:42 PM   #11
nevermind, i got it out.
Old January 11th, 2004, 04:12 PM   #12
bryan <3's bomex
mastadulog's Avatar
Old January 13th, 2004, 11:22 PM   #13
Heres a pic of my gauges, that little button on the dash is for my fog lights
a/f gauge installation-gauges.jpg
Bender is offline   Reply With Quote Quick reply to this message
Old January 13th, 2004, 11:33 PM   #14
what gauge is that above ur a/f gauge?
I think u can do better with ur fog light switch. I mount mine into where the OEM fog siwtch slot near the clock
Old January 13th, 2004, 11:34 PM   #15
Thats a negative there, im missing that part of my center consol b/c someone broke into my car, i already tried lots of ways, no dice.
Old January 13th, 2004, 11:36 PM   #16
The gauge above is an Oil Pressure gauge
Never buy mechanical, i had it leak once and oil dripped down my doors hehe
Old January 14th, 2004, 07:26 AM   #17
bryan <3's bomex
mastadulog's Avatar
looks nice
Old January 14th, 2004, 12:31 PM   #18
Originally posted by mastadulog
looks nice
Old January 14th, 2004, 02:14 PM   #19
how many wires goes out of your oil pressure gauge? How did u install it?
Old January 14th, 2004, 04:23 PM   #20
Is that the Autometer bezel? I have tried every frickin pillar/bezel Next Level Motoring offers and EVERY ONE of them SUCKS!!! I need a replacement. I wanted the full pillar, but oh well.
Old January 14th, 2004, 09:30 PM   #21
I didnt install it, my cousin owns a performance shop and did it for me. I dont like drilling into the oil well :-/
And it is an autometer pod
