1994 Accord transmission problem - Honda Accord Forum : V6 Performance Accord Forums
Old May 1st, 2011, 03:02 AM   #1
Hey guys, I acquired a 94 Honda Accord EXr (2.2L, 4 cylinder automatic) today. It has ~ 200 000 KM on it. When driving, it drives ok (shifts a little rough). Only when I come to stop at a red light and go again, the car either won't shift out of first gear or the transmission slips (can't go faster than 30). If I pull over, turn the car off and back on again, it will drive normally until I stop again at a red light. It doesn't slip on the highway or going up hills. I am thinking maybe it's an electrical problem. Any suggestions? Maybe solenoid? No CEL lights or anything, but the ABS and parking brake lights are on if that has to do with anything?
watut is offline   Reply With Quote Quick reply to this message
Old May 1st, 2011, 04:25 PM   #2
Send a message via ICQ to hightower6969
It could be your transmission is slipping. This happened on my old 88 accord6 LXi. Have you changed anything in your car in the past couple of years? You really don't need abs unless you want it. I didn't want to pay for a used or new abs, but I think it's your sensor that is messed up. It may also be your timing belt is off a little. How long you planning to keep this car?
hightower6969 is offline   Reply With Quote Quick reply to this message
Old May 13th, 2011, 09:48 AM   #3
Have you kept up with the transmission fluid exchange? It's more than likely your trans going out soon.
buckevan is offline   Reply With Quote Quick reply to this message
