Clicking noise when turning? - Honda Accord Forum : V6 Performance Accord Forums
Old February 19th, 2004, 08:59 PM   #1
It does this turning in both directions. Is this difficult to fix? CV joints? drive axles??
canadaccord95 is offline   Reply With Quote Quick reply to this message
Old February 20th, 2004, 07:24 AM   #2
sounds like cv joints. either way I would say find out which side it is and replace the whole axle. Its easier and you are better off in the end.
laststarburning is offline   Reply With Quote Quick reply to this message
Old February 20th, 2004, 01:53 PM   #3
i would say cv joints.
enginerd04 is offline   Reply With Quote Quick reply to this message
Old February 20th, 2004, 01:56 PM   #4
DJ2000
AxisAccord's Avatar
i third the CV joints
AxisAccord is offline   Reply With Quote Quick reply to this message
Old February 20th, 2004, 02:14 PM   #5
Whitesides's Avatar
Send a message via AIM to Whitesides
I'll fourth CV joints and second replacing the whole axle.
Whitesides is offline   Reply With Quote Quick reply to this message
Old February 25th, 2004, 05:56 PM   #6
Large Member
CV joint. I had it happen in an '88 Civic and a '90 Accord. You've worn the outer axle splines out and they're slipping against the splines of the center axle, hence the clicking noise. Its actually something you can replace yourself with a buddy. Took my buddy and I about 3 hours to do and we'd never done it before. Get new axles and new CV boots. It'll only get worse if you let it go, too.
Gallo is offline   Reply With Quote Quick reply to this message
Old February 26th, 2004, 05:44 AM   #7
Shifting 5 Gears Baby !!
cowgodv6's Avatar
it's winter time ...
I would say go for an oil change at local walmart
while on the lift have the mechanic jump into the car - turn the wheels left and right in drive and reverse
I suspect CV's or passenger axle boot torn up ..
My Rides :
95 Accord EX-R V6 ( C27M5 ) 5 Speed feels so good !!!
93 Civic Si Coupe ( D16Z8 )
92 Civic LX 4 door Winter Beater - Wife`s winter car (scrapped)
92 Accord EX - Winter Beater
