95 accord automatic transmission problems - Honda Accord Forum : V6 Performance Accord Forums
Old May 29th, 2014, 07:38 PM   #1
bozos_si's Avatar
I have a 95 accord 4 cylinder automatic. Going from park to either reverse or drive it has a delay engagement. It will go into gear and start going but then about a second later it fully engages. It is only from park that it does this. If it is in drive it goes through all the other gears fine. That is the best way I can describe it. This is the second accord I have had that does this. I have a buddy that has an odyssey that is the same way. I am just curious as to if anyone else has this problem and if they fixed it what did you do? I am thinking that it is either the shift solenoid or the lock up solenoid. Maybe even both. Anyone have a clue?
Old June 6th, 2014, 11:36 PM   #2
bozos_si's Avatar
No one knows? Someone has to know something. I know its a common issue.
Old June 7th, 2014, 12:01 AM   #3
The Jester
Going to say, either solenoids for that specific actuation, or the clutch pack that gets engaged on 1st.
