Flushing/Changing all fluids - Honda Accord Forum : V6 Performance Accord Forums
Old May 19th, 2003, 07:30 AM   #1
Just got a wrecked 95 V6 and want to flush/change everything because I have no idea when anything was done last. Anybody know how much engine and tranny oil these babies require? Anything else recommend besides engine oil/filter, tranny fluid and coolant?
jamal-188 is offline   Reply With Quote Quick reply to this message
Old May 19th, 2003, 11:13 AM   #2
engine oil will require about 4.5 quarts and tranny fluid just flush it out and put it in until it fill to the middle of the marker.
you should also change plugs and wires to new ones not "high performance", making sure there is no leaks, checking brake and power steering fluid, you will probably want to run your gas real low and run some fuel injector cleaners just in case you probably checked the rest oh and for oil change since it was damaged i would change it twice within a one week period just to see if there are other problems with the engine as head gasket leaks and what not anyways hope that helps WAR
Old May 24th, 2003, 09:36 AM   #3
If its been in a wreck, there could be tons wrong with it. Its best to go to honda and spent some money to have them look through the whole thing.
Bender is offline   Reply With Quote Quick reply to this message
Old May 25th, 2003, 03:53 AM   #4
What do you guys think could be wrong, it wasn't in that bad of a wreck
