97 Honda Accord Ex shifting problem - Honda Accord Forum : V6 Performance Accord Forums
Old October 19th, 2014, 06:41 PM   #1
bozos_si's Avatar
I have a 97 accord ex 4 cylinder auto that I just picked up. The problem is if you floor it in gear it wont rev past 5500 RMP and it wont shift. If you put it in neutral and floor it the car will redline. If you put it down in 1st and floor it and let it go to 5500 and you shift it yourself to the next gear it will shift fine. If you drive it normal it runs fine and shifts fine. Anyone have any idea what would cause it to not reach redline? Im sure because it is not reaching redline is the cause of the car not shifting to the next gear as well. Any ideas will help.
Old October 21st, 2014, 06:48 AM   #2
bozos_si's Avatar
I did an oil change, cleaned the plugs, distributor cap and rotor. Ran the codes on the car. One came up egr clogged, The other came up P0715 Trouble Code Input/Turbine Speed Sensor Circuit Malfunction. I cleared the codes and took it for a drive. Car redlined and shifted perfectly and then the check engine light came back on. Car still runs fine and shifts great so I dont think it is any problem with the transmission itself. No "D" lights blinking either. What would you guys suggest I do next? I have a 95 accord so i can swap parts to try and figure out the problem. Should I try swapping ECU's first?
