Busted Antenna - Honda Accord Forum : V6 Performance Accord Forums
Old May 24th, 2004, 04:47 PM   #1
Busted Antenna
Hi Does anyone know how fix a busted radio antenna...
when i turn the radio on it goes up than just stops half way and makes a huge grinding sound...
i'd rather just remove or at least stop it from going up when i turn my radio on...
any suggestions?
thanx in advance...
BpGoldv6 is offline   Reply With Quote Quick reply to this message
Old May 24th, 2004, 04:58 PM   #2
bryan <3's bomex
mastadulog's Avatar
i dont know man, i have one of those windshield antennas, maybe you should get one of those
Old May 24th, 2004, 06:41 PM   #3
'96-97 had windshield antennas....lucky bastards
but like mastadulog said you could get a windshield antenna,
i think i remember a long time ago someone somewhere
saying you could buy one from radio shack and mount it
wherever you want. that way you could just shave off the old
external one
DaRude1 is offline   Reply With Quote Quick reply to this message
Old May 24th, 2004, 07:04 PM   #4
the Lost Sol
KhanhCord's Avatar
yeup. Oh how i love my 97. no need to worry abt antenna going up n down.
To fix the grinding problem u'd have to go outside ur car EVERYTIME u turn radio on or off and kinda twist it left <->rite so that the antena can go all the way up or down.
Old May 24th, 2004, 07:14 PM   #5
:dusts off the ol' haynes manual:
12-7
Antenna - removal and installation
[list=1][*]open the trunk lid or liftgate and remove the left side inner trim panel for access to the antenna assembly.[*]trace the lead from the antenna down to the connector and unplug it. (caution: pull on metal terminals when separating this connector. do not pull on the cable or damage to the cable may occur)[*]remove the locknut, spacer and rubber washer[*]turn on the radio. as the antenna extends, withdraw it and the antenna drive cable from the fender[*]carefully insert the cable of the new antenna into the hole with the drive teeth facing towards the vehicle. you can verify that the drive teeth are properly engaged with the antenna motor drive gear by carefully moving the cable up and down[*]clean the antenna housing threads and insert the antenna into the housing. install the bushing, spacer and locknut. secure the locknut securely.[*]verify the antenna fully extends and retracts when the stereo is turned off and on respectivly. is the antenna sticks, the locknut may be over-tightened. loosen it until the antenna can move up and down freely.[/list=1]
hmm too bad i didnt see that last line until the end, maybe that is your problem. try loosening the locknut first
also check your fuse boxes, there maybe a fuse to pull to disable it.
jimc is offline   Reply With Quote Quick reply to this message
Old May 25th, 2004, 02:14 AM   #6
mine went out too. Luckly it went out on its way up so now it stays up. Its all good.
Old May 25th, 2004, 08:25 PM   #7
Thanx alot guys
I appreciate it.
