fog light install - Honda Accord Forum : V6 Performance Accord Forums
Old October 28th, 2004, 05:53 AM   #1
rectum damn near killed m
oviphagy's Avatar
Send a message via AIM to oviphagy Send a message via Yahoo to oviphagy
fog light install
so i have a stock '95 EX V-6 front bumper and i want to install some factory foglights. my question is do i have to do any cuttiing to put them in? if not how easy are they to install? thx
oviphagy is offline   Reply With Quote Quick reply to this message
Old October 29th, 2004, 05:08 AM   #2
Shifting 5 Gears Baby !!
cowgodv6's Avatar
no if you get the OEM or OEM replicas they will bolt right on ... lie down on your back and look up in the top of the bumper frame, you'll already see the mounts and cuts there
Old October 29th, 2004, 02:05 PM   #3
oviphagy's Avatar
thanks found them. cant wait to install them.
life= break in, then theft, recover, theft, recover.....
Old November 16th, 2004, 05:28 AM   #4
oviphagy's Avatar
jezus! so much for the instructions and it being right. im guessing that they were for a i4 model. the V6 is entirely differnt insdtall. had to pull my car apart to get the darn things in. took me all day to find all the screws and bolts and plastic tabs that i had to pop off to get the bumper cover off. but once i did it was maybe a half hour to actually get the wiring harness and lights installed and then to reinstall the bumper took about another hour. ill post picks of the install here in a few days and some warning if you are trying to do a factory install. (cuz it sucks).
Old November 16th, 2004, 10:39 AM   #5
cowgodv6's Avatar
that's odd because on my bumper it's bolt on application cause it's an option
you can mount the OEM mounts directly - run the wiring along the side near the battery and punch a hole in the firewall to mount the dash optional button
I've seen it done ... dude ... are you sure you got the right OEM replacement
Old November 16th, 2004, 12:08 PM   #6
oviphagy's Avatar
the lights went into the factory spots but the 4 main bolts (2 bolts, 2 hex head) and the several small/ minor ones that it told me to undo did nothing to help me take the bumper off. ill post the picks of what i had to remove/unscrew to get my bumper off soon. the kit also has a factory switch for the interior of the car and goes to the free spot to the right of the hazard light switch above the radio. but thats about where the similarities ended for my install.
Old November 28th, 2004, 08:07 PM   #7
Q
accord6's Avatar
have any pics? how is the output? i don't know whether or not to buy these or retrofit a pair of mini fog projectors into the bumper lights
i have tested it out already and it does not melt the lights...
Old November 29th, 2004, 12:02 PM   #8
oviphagy's Avatar
not sure on the output cuz i had to drop it off at mechanics to get the 90000 work done on it and i havent gotten it back yet. and as a side note be careful buying from procarparts on ebay. they are the ones who sold me the kit and when they did the relay w/ the kit was bad and i was also missing the relay bracket from the box. as soon as i get the car back ill let you know. but that looks sweet mounted into the bumper lights. what wattage are they?
Old December 2nd, 2004, 07:19 AM   #9
NorCal's Accord C.F.whore
iakona's Avatar
yeah, the front bumper is a PITA to remove. bolts under the headlights, in the fenders, under the radiator, etc.
not fun.
iakona is offline   Reply With Quote Quick reply to this message
Old December 5th, 2004, 11:04 PM   #10
Q
accord6's Avatar
thanks they're 55W.
Old December 7th, 2004, 07:31 PM   #11
oviphagy's Avatar
here is where you can see the pics
so bumper #1 is the pain in the a** right side that i had to cut some of the plastic bolts to get the bumper off.
bumper 2 is where you need a 6" or longer phillips screwdrive to get the bumper light out
bumper 3 is shows where you need to shave down the tab so the lights will fit in correctly
bumper 4 is where the instructions said to undo the hex head and normal bolt (that did nothing to loosen my bumper)
bumper 5 is shows some of the easier to get to plastic tabs
bumper 6 is where the plastic tabs are for the drivers side which you can wiggle the leadlight around enough to get a phillips screwdriver into to undo
bumper 7 is the 3 in the center under the grill which has to be removed to get at (the easiest to undo)
bumper 8 is the 5 screws that you have to undo to get the grill out
bumper 9 is where i scraped down to bare metal to ground the passenger side light
bumper 10 is just shows where most of the damn plastic screws go and notice the 4th from the left is the one i had to cut to get out cuz the light doesnt move enough to get to it
bumper 11 is where the passenger light is and there is less room to get to the screws
well hope that helps somebody let me know if i can answer anymore questions for ya.
Old December 7th, 2004, 07:39 PM   #12
Q
accord6's Avatar
there's a faster way to remove the bumper... i was doing it the way you did yours but i found out it was easier to remove the front bumper support too. 6 screws and 2 plastic bolts. time: < 5 minutes
Old December 7th, 2004, 08:26 PM   #13
oviphagy's Avatar
was it the same ones that i mentioned in shot bumper 4? (2 hex head and 2 normal bolts on each side?) i tried those originally and got no wiggle of the bumper so i went the other route
Old December 7th, 2004, 09:28 PM   #14
Q
accord6's Avatar
yeah on each side, it's 2 hex head in the bumper signal, 1 hex head connecting the front bumper and wheel well fender, and 1 plastic screw under the bumper
the first attempt was hard. i had to wriggle the bumper upward hard for it to budge.
the horizontal arrow is wrong. theres another hex bolt to the left of it.
Old December 11th, 2004, 02:38 PM   #15
Q
accord6's Avatar
Old December 16th, 2004, 10:19 AM   #16
oviphagy's Avatar
where did that page come from? what manual?
Old December 16th, 2004, 11:38 PM   #17
Q
accord6's Avatar
saw it torontoaccords.com while browsing through there
