o2 sensor - Honda Accord Forum : V6 Performance Accord Forums
Old November 2nd, 2004, 02:16 PM   #1
o2 sensor
whats up yall?! I took my accord in the other day to check out the check engine light that came on and they told me it was the o2 sensor, but they didnt say which of the two. is there any way of knowing for sure which one to change out and how easy it is to change them out. If it helps I have noticed a drop in my mpg and its a bit sluggish on acceleration. Any info would help, Thanks in advance
LSUTiger is offline   Reply With Quote Quick reply to this message
Old November 3rd, 2004, 04:51 AM   #2
Shifting 5 Gears Baby !!
cowgodv6's Avatar
check the code
it will tell you primary or secondary
the check engine light does not just "tell you" ok dude it's an o2 sensor
you have to count how many times the check engine flashes on ignition LOCK - not starting the car, just in the ignition position
