d4 light blinking - Honda Accord Forum : V6 Performance Accord Forums
Old March 17th, 2005, 03:46 PM   #1
d4 light blinking
my light is blinking can anyone tell me why
tresdad is offline   Reply With Quote Quick reply to this message
Old March 17th, 2005, 03:50 PM   #2
Old Member
Du3ce's Avatar
ur tranny is going bad
2007 Accord EX-L V6
Old March 17th, 2005, 03:57 PM   #3
just got a new one put in a month ago
Old March 17th, 2005, 04:01 PM   #4
Old Member
Du3ce's Avatar
yeah your tranny isnt "new" its rebuilbt, it probably gave out again, go back to the dealership and have them check it.
Old March 17th, 2005, 04:08 PM   #5
so what is the blinking a warning that it has a problem should i just say its blinking or that i think its going out
Old March 17th, 2005, 04:14 PM   #6
Old Member
Du3ce's Avatar
yes, also do a search on the topic, it has been discussed before
Old March 17th, 2005, 07:15 PM   #7
bryan <3's bomex
mastadulog's Avatar
yep, definitely something to do with the tranny
Old March 23rd, 2005, 09:49 PM   #8
check tranny fluid first
Old March 24th, 2005, 05:46 AM   #9
Shifting 5 Gears Baby !!
cowgodv6's Avatar
check oil levels
mine does that now, since my tranny swap - there are like 4 pin connectors that mount to the automatic tranny - all my 4 connectors are not hooked up to anything
maybe they did not connect one fully when they worked on your car recently and it's came a bit loose because of vibration
Old March 31st, 2005, 08:03 PM   #10
what a blinking D4 light means is that its computer has detected an error in the transmission' system. It may be a shift solonoid, the torque converter solonoid or mabe even a loose wire. Just because the light is blinking dessent mean that the tranney is shot. Think of it as the transmission's check engine light. If the check engine light comes on is your motor shot? NO. Get it diagnoced at the dealer. Who knows it may be somthing minor.
97accord-ex-v6 is offline   Reply With Quote Quick reply to this message
