something wrong with me engine? - Honda Accord Forum : V6 Performance Accord Forums
Old June 25th, 2003, 06:31 AM   #1
bryan <3's bomex
mastadulog's Avatar
every once in a while, after i turn off my engine, i hear a loud fan noise coming from my engine. is this normal? i know it's not because of overheating because i check the temp gauge once in a while and its always halfway towards the cold side.
-97 Accord V6-
aim: bpdulog
photos:
myspace:
hincity:
Old June 25th, 2003, 02:38 PM   #2
If its hot outside or if you run it hot enough, those fans will kick on to help the cool down process. thats normal, nothing to worry about.
akord 97 is offline   Reply With Quote Quick reply to this message
Old June 29th, 2003, 08:29 PM   #3
Its the radiator fan
roosplash is offline   Reply With Quote Quick reply to this message
Old July 5th, 2003, 03:34 PM   #4
its normal it should turn off evenentualy but if its still on after 20 mins there might be a problem
Old February 1st, 2005, 12:54 PM   #5
mine has been on for 40 minutes and the temp outside is only 70 degrees
i only drove my car 5 miles from school back to my house at like 50mph and the thing
hasn't turned off unless i disconnect the battery
what could be the cause?
DaRude1 is offline   Reply With Quote Quick reply to this message
Old February 1st, 2005, 02:58 PM   #6
bryan <3's bomex
mastadulog's Avatar
whats the engine temp meter say? check your oil level?
Old February 1st, 2005, 03:22 PM   #7
temp is under the half way mark, so the engine is cool
oil was just changed 2 days ago
thought it was the radiator switch, but it is not.....it has to do w/ the cooling fan i guess but those two are not one and the same
it will only stop when i disconnect it....any other suggestions? relay?
Old February 2nd, 2005, 06:51 AM   #8
rectum damn near killed m
oviphagy's Avatar
Send a message via AIM to oviphagy Send a message via Yahoo to oviphagy
take it to a mechanic must be a relay somewhere that wont turn it off when its cooled down enough to trigger the switch off (engine temp sensor?)
life= break in, then theft, recover, theft, recover.....
oviphagy is offline   Reply With Quote Quick reply to this message
Old February 2nd, 2005, 02:15 PM   #9
man, i'm really trying to avoid the mechanic
i just took my car in the other week because of some electrical problems, now this crap
it's relatively cool right now so i just disconnected it as a temporary solution
Old February 4th, 2005, 05:34 AM   #10
Shifting 5 Gears Baby !!
cowgodv6's Avatar
it sounds like you still have an eletrical problem
check all grounds and make sure that if he says the job is done you check it while you're there, since you were there last week at least he will remember what he was facking with
Old February 4th, 2005, 01:55 PM   #11
Check your coolant temperature sensor and also the fan relays to make sure they are not broken.
EX-JAY is offline   Reply With Quote Quick reply to this message
Old February 14th, 2005, 04:21 PM   #12
my fan never turns on when I turn my car off.
Old February 16th, 2005, 05:35 AM   #13
cowgodv6's Avatar
you have an issue with your stereo wiring for sure
there is a constant power feed in the dash ...
you must have crossed a wire because that is the ONLY way to have constant power
does the fan spin fast like if the car is on? or does it spin slower cause the draw is lower ?
I'm sure you have a feed patched into the fan relay or the fan control under the stereo ...
