bad alternator? - Honda Accord Forum : V6 Performance Accord Forums
Old June 4th, 2005, 09:57 PM   #1
bad alternator?
hey a squeeekie noise is coming out of my engine. first i thought it was the belts that were either ot of place or lose. or it could b the a/c. but i just replaced the a/c. so it couldnt be the a/c. my teacher told me that it was coming from the alternator, a bearing bust have been busted. first it was a grinding sound . and now its a squeekie sound. sometimes it stops and then it starts again. any1 has or had the same problems?
jonnytran is offline   Reply With Quote Quick reply to this message
Old June 4th, 2005, 10:30 PM   #2
bryan <3's bomex
mastadulog's Avatar
yup, my alternator busted twice
Old June 4th, 2005, 11:56 PM   #3
how much did u fixed it for? i asked the store and they want 270 for the alternator only. theyd give me 70 bux back when i return them the bad alternator. any1 know where i can get a good deal? or get mines rebuild?
Old June 5th, 2005, 06:04 PM   #4
bryan <3's bomex
mastadulog's Avatar
i got my alternator rebuilt. 60 for labor and 160 for the parts. it busted again after 3 months but they took care of me. just goto any mechanic and see what they'll charge.
Old June 11th, 2005, 02:26 PM   #5
take a long screwdriver and place the tip on the alternator and your ear on the handle to confirm where the squeek is comming from.
Old June 11th, 2005, 05:52 PM   #6
that trick also works well with a piece of wood like a ruler, and it works on any oart of the engine, great when main bearings go and you wanna know which ones are bad
Old June 12th, 2005, 01:53 AM   #7
many people have told me its the alternator. and they say its gonna blow soon. i should get it fixed b4 it danages other parts. all i need is a new alternator. u guys know if there are any cheap ones? they list 2 kinds of alternator. one is 160 the other is bout 300 do they both work? http://oem.overnightautoparts.com/pa...art=Alternator
Old June 12th, 2005, 09:51 AM   #8
bryan <3's bomex
mastadulog's Avatar
the 300 dollars one is an oem that was remanufactured. just get the bosch
Old June 12th, 2005, 06:44 PM   #9
thnx! ill get the bosh
Old June 19th, 2005, 10:29 AM   #10
I suspect one of the bearings in my alternator is bad. Have any of you guys changed your bearing's by yourself? If so what is the level of difficulty?
john is offline   Reply With Quote Quick reply to this message
Old July 2nd, 2005, 04:13 PM   #11
bryan <3's bomex
mastadulog's Avatar
my alternator is dying for a 3rd time, im just gonna get a new one. voltage reading is 13.88 at idle
Old July 29th, 2005, 11:24 PM   #12
I had the squeaky problem, it was the belt. It all went away when I got my timing belt done cause they replace all the drive belts too. If it's the alt, might as well get a new one before it dies on you.
04MonteLS is offline   Reply With Quote Quick reply to this message
