problem with brakes - Honda Accord Forum : V6 Performance Accord Forums
Old August 4th, 2005, 12:43 PM   #1
Send a message via AIM to mobettabin
problem with brakes
lately i've been having a problem when braking. I have to push the brake peddle ALL the way down for a complete stop. sometimes, my car moves a little even when the peddle is down. one day, i was parallel parking and i had the peddle COMPLETELY down, and, while in drive, the car moved forward so much that i acutally hit the car in front of me. I couldnt believe what had just happened. any ideas on what the problem could be? i just got new brake pads, rotors and front calipers put in within the last 4 months.
mobettabin is offline   Reply With Quote Quick reply to this message
Old August 4th, 2005, 03:55 PM   #2
check the brake fluid, if it's low add some, if it's empty have someone fiigure out where it went, unless you can do that yourself.
Old August 4th, 2005, 04:09 PM   #3
Accord_V6_400m's Avatar
Obviously that hydraulic pressure isn't reaching the pads, so check for brake fluid level and any kinks in the lines.
Old August 4th, 2005, 09:48 PM   #4
exactly what they said ^^^^^^^^^
kaos is offline   Reply With Quote Quick reply to this message
Old August 5th, 2005, 01:07 PM   #5
Shifting 5 Gears Baby !!
cowgodv6's Avatar
do a full brake flush
then re-diagnose
having old ass oils suck
Old August 5th, 2005, 01:51 PM   #6
constantly in pursuit
hammer03's Avatar
maybe have em bleed and refill the brakes. if there is air in the lines, that can happen
Old August 5th, 2005, 03:11 PM   #7
typicaly that results in a spongy feeling brake pedal
Old August 5th, 2005, 04:44 PM   #8
Large Member
I had this same thing happen to an old Celica I owned. Turned out the master cylinder was leaking brake fluid. I wouldn't drive your car in that condition because the problem will only get worse. Get it fixed right away.
Gallo is offline   Reply With Quote Quick reply to this message
