URGENT!!! Windows wont go up!! - Honda Accord Forum : V6 Performance Accord Forums
Old August 12th, 2005, 11:30 PM   #1
Ok well I get in my car tonight go make my way home from a buddys house and I roll down my windows as usuall during a nice night and then I go to roll them back up and nothing happens (except my drivers window does go up). This really is ironic b/c i was just looking at getting new motors and regulators for the two front windows b/c they move up so slow after being used so much (I would rather have windows down then use AC in town).
So I check the fuses for the power window relay and it is perfectly fine........what am i missing or do i get to replace the whole switch board in the drivers door????
***And the dealer wanted $174 a piece for window regulators and labor would be $164 for both to be installed so that makes a total of $500+........just to have faster windows.....CAN I SAY RIP OFF!!!!
Powder11 is offline   Reply With Quote Quick reply to this message
Old August 13th, 2005, 12:53 AM   #2
ive got the slow window issue, im not sure but if you take apart the door you might be able to either crank the mechanism back up or detach the window from the mechanism just to make it stay up till its fixed.
ethlar is offline   Reply With Quote Quick reply to this message
Old August 13th, 2005, 02:18 PM   #3
i had the regulator go followed by the switch a week later, i paid 500 for both, but my mechanic didn;t charge me labor for the 2nd fix
Old August 18th, 2005, 08:52 AM   #4
Shifting 5 Gears Baby !!
cowgodv6's Avatar
clean your window tracks
they short outthe modulators / relays because they get full of crap
it use to take me like 15 seconds to close my windows
now it takes like 8 seconds - never changed anything
Old August 18th, 2005, 10:23 PM   #5
is there an easy way to get the door panels off or is it tough no matter what???
and are there any hidden fasteners that i should know about to help it go smoothly???
Old August 18th, 2005, 10:52 PM   #6
you have to remove the screw in the interior handle, slide it foreward and pull out, disconnect the electrical connections and the metal bar for the door mechanism. remove the screw in the bottom of the hand hold and remove that. (only on front doors) pull off the black cover for the side view mirror and use a flat head screw driver on the little circular cap like thing near the hinge, the rest of the door is held on with pop rivets, i like to start with a corner and work my way around with the screw driver. then lift up and out, be careful about the wire for the courtesy light, unplug that too and put the panel somewhere.
the same goes for the back doors but remove the black thing at the back of the doors and i dont thing the circular cap thing is on them.
the drivers door works the same as the passenger door but the window controls make it a little tricky be patient and it should come out fine.
i can try to scan the pages from my haynes manual if you want
Old August 18th, 2005, 11:09 PM   #7
any pictures would help me out more thanks
Old August 22nd, 2005, 03:10 PM   #8
its looking like i cant get the pictures, computer with the scanner was zapped by lightning or something and wont take the scanner anymore
Old April 25th, 2007, 08:05 PM   #9
A n g u s D e i
itchthys's Avatar
Send a message via AIM to itchthys
BUMP THIS. It happened to my car and I DONT know what to do!!!!!!
itchthys is offline   Reply With Quote Quick reply to this message
Old April 26th, 2007, 06:28 AM   #10
Take out your window switches and theyre likely clogged with crap. Get a toothbrush and rubbing alochol and go to town. Get the inside of the switches relly clean, let it dry a few mins and put it back...
Should work, but you might need new ones...
E
Old April 26th, 2007, 07:20 AM   #11
bryan <3's bomex
mastadulog's Avatar
i have this problem on my drivers side window, its probably the regulator
-97 Accord V6-
aim: bpdulog
photos:
myspace:
hincity:
