95 V-6 Diagnostic tool? - Honda Accord Forum : V6 Performance Accord Forums
Old August 15th, 2005, 08:56 AM   #1
rectum damn near killed m
oviphagy's Avatar
Send a message via AIM to oviphagy Send a message via Yahoo to oviphagy
Unhappy 95 V-6 Diagnostic tool?
I have an ABS sensor thats lit up on my dash and need to get the diagonstic tool to figure out whats wrong? anybody have 1 they are willing to sell? I tried to take it to my mechanic but he was unable to get the correct code to figure it out.
oviphagy is offline   Reply With Quote Quick reply to this message
Old August 15th, 2005, 09:42 PM   #2
in another really recent post someone said autozone pulls diagnostic codes for free
Old August 16th, 2005, 05:34 AM   #3
oviphagy's Avatar
thanks. i was reading that thread also and went last night to autozone, but they could only get the 2 digit code and not the 5 digit OBDII code for me. so im going to try elsewhere to see what the light means.
life= break in, then theft, recover, theft, recover.....
Old August 16th, 2005, 05:23 PM   #4
Try disconnecting the battery for a few minutes first. Usually what I do if light pops on the dash is diconnect the battery cable, If after I reconnect the cable and the light pops again then I take it to get the codes pulled
roosplash is offline   Reply With Quote Quick reply to this message
Old August 18th, 2005, 05:29 AM   #5
Shifting 5 Gears Baby !!
cowgodv6's Avatar
the abs sensor is turning on because there is a problem
could be a sensor malfunctioning, could be air in the brake lines, could be low on oil, could be low on oil pressure in the abs pump ... there are only about 10-12 codes that can be read by the abs sensors
first, do a full brake flush and bleed out the brakes
then see if the sensor still gives an error
have fun, I've had the same issue on my ride for 2 years on and off, It's the last thing on my mind, in fact the car brakes a lot better with the abs off
Old August 18th, 2005, 10:14 PM   #6
lol only when the roads are dry
