fuel injectors - Honda Accord Forum : V6 Performance Accord Forums
Old November 13th, 2005, 03:07 AM   #1
Send a message via ICQ to hightower6969
fuel injectors
Hey ya'll,
I was wondering how many fuel injectors does a 96 v6 have? I was thinking of changing the stock ones to the accels. What are your takes on it...
thanks...
hightower6969 is offline   Reply With Quote Quick reply to this message
Old November 13th, 2005, 06:12 AM   #2
Im not 100% positive but Im guessing 6. Pull off your black Valve Cover and take a look.
4mytoys is offline   Reply With Quote Quick reply to this message
Old November 13th, 2005, 10:37 AM   #3
Dont take off the valve cover. IT has 6. 1 for each cilinder you need to take off the black cover on the top unhook the cruze control cable from the throtel body (mark its position) then take out ur fuel pump fuse. BLue one i think under dash 15 amp. Then crank it for like 5 seconds. Then jsut take the fuel rale loose, and pull out ur injectors. Put new ones in with lubed gaskets and butten it back up.! Bamo Done. Will take you mabe an hour and a half.
97accord-ex-v6 is offline   Reply With Quote Quick reply to this message
Old November 13th, 2005, 11:40 AM   #4
thats waht I meant. Just take off the cover.
Old January 3rd, 2006, 07:29 PM   #5
YeuEmMaiMai's Avatar
to releive the fuel pressure all you have to do is open the gas cap. ALL of the accord engines have 1 fuel injector per cylander and the 94 and newer cars are sequential multi port fuel injected (SMPFI)
YeuEmMaiMai is offline   Reply With Quote Quick reply to this message
