Alternator Q - Honda Accord Forum : V6 Performance Accord Forums
Old January 5th, 2006, 11:51 AM   #1
Alternator Q
Hello,
I have a question about the alternator in my car. Its a 97 accord ex v6. What is the factory spec on the oem alt as far as amps?
97accord-ex-v6 is offline   Reply With Quote Quick reply to this message
Old January 5th, 2006, 12:01 PM   #2
HONDA_99's Avatar
90Amp
Old January 6th, 2006, 12:57 PM   #3
ok thanks. I got mine tested yesterday and it peaked at 74 amps @ 2000 rpm. Is this normal or is my alt going?
Old January 6th, 2006, 01:06 PM   #4
HONDA_99's Avatar
how do you know that it peaked at 74Amps?
Old January 6th, 2006, 01:26 PM   #5
I had the guy at autozone test it. And the battery. The battery is still very good.
Old January 6th, 2006, 02:25 PM   #6
HONDA_99's Avatar
You alternator is fine.
Machine that they use in AutoZone don't check alternators for maximum output it checks if alternator in working order.
Electrical machines like alternators and motors are designed for some maximum load, if you exceed that mark it doesn't mean machine will not produce (amps) its just mean it will fail prematurely.
Old January 7th, 2006, 12:48 PM   #7
Ok. Thanks. I dont put 100% faith in there machine, after all they do test hundreds of em with it..... but theres did have a reading for peak amperage. I saw it my self. And yes ur right running it that high will wear it out prematurly. Any ways I was jsut curious because I know my battery is in very good condition and it likes to sit at about 12.5 volts with the engine and everything off. I just did not want to lose a good battery to sulfation.
But it charges at 14.44 volts and sure has the amps so im not as concerned about it.
Thanks for the help.
